Results 1 to 23 of 23
Thread: 7600GS Vmod needed :)
    May 2005
    Talking 7600GS Vmod needed :)
    Hello
    I want to mod my card, but i don;t know why. I tried bioses from gigabyte and eVGA but voltage and overclockability was the same. Can anybody help ?
    My GPU and memory :
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Please take a picture of these two spots.
    Attachment 46057
    Then we can help you more!
    You are as good as your samples are!
    May 2005
    Ok i got it
    Click for full size image
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    If you have multimeter you should measure resistance from pin 4. And if you could post larger picture of this area, we will know where you should solder resistor.
    Attachment 46062
    May 2005
    Where put on the multimeter cables? Ono to pin 4 , second to ????
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    ...on the ground. How experienced you are with voltage mods? Have you done it before?
    What is your max clocks now? Do you know the Vcore in 3D mode?
    May 2005
    Experimence - 3 volltmods : FX5200, FX5900 and GF6200
    My default Vcore is 1,05V - need at least 1,2 - 1,3 V like on 7600GT
    Now max GPU is only 450 - I want at least 600
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Ok. Could you try this?
    Attachment 46075
    Tell me if it works. It should!
    May 2005
    ok i will try
    May 2005
    Ya, but where to measure Vcore? I told that it's 1,05V but in bios VID table. I don't know where is measuring point Sry for my lame
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    hmmm.. Check these points.
    Attachment 46078
    May 2005
    Thanks it's 1,04V and it's very possible
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    I'm waiting results
    Apr 2006
    Does it work?
    Could you post the moded picture and oc result?
    thx~
    Apr 2006
    I posted my results with the volt mod using the pencil trick on another forum, including photos and graphs as well. The 7600GS appear to overclock fairly well at 600/485 at 1.32V.
    http://forums.guru3d.com/showthread.php?t=180831
    Thank you SF3D. I used your tips as a starting point.
    Best regards,
    Anthony Rogers
    PentiumD 805@3.4~1.3V/Big Typhoon
    Leadtek7600GS@600/485~1.32V/VF700Cu
    Gigabyte GA-8N-SLI
    2x1Gb GSkill DDR2 @ 680 4-4-4-12
    Antec Sonata II
    2 x 160Gb Seagate 7200.7 Raid 0
    400Gb Seagate 7200.7
    2 x Syba PCI ATA Raid
    BenQ DW1655
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Welcome Anthony Rogers!!!
    Could you post your results here also. I can't view them in your link. I'm interested to get one of these budget cards too.
    Apr 2006
    Quote Originally Posted by SF3D
    Thank you!
    I'd hate to double post on two forums, but I'll post the 3dMark06 plot and the table here also. I've moved the images to imageshack hosting, so maybe that work be better.
    Since I've had so much luck overclocking the Leadtek card, I'm thinking about getting another to run in SLI, before they start changing the revision or chips used, etc. I'm also planning on making a simple circuit with a switch so that I can switch the mod on and off for both cards.
    Best regards,
    Anthony Rogers
    Excerpted from post at Guru3D
    3DMark06 Plot
    Clock Frequencies and Temperature Table
    It appears that the active HSF does a fairly good job of cooling even when overclocked, as compared to the passive HS from other reviews at Newegg and below at HardwareZone. The HSF is also fairly quiet and not audible above the other fans in the PSU, Big Typhoon, and 120mm case fan
    http://www.hardwarezone.com/articles...856&cid=3&pg=9
  18. #18
    Mar 2005
    Toronto, Ontario
    THis is just VGPU mod rite? is there a VMEM mod? Anthony have you done both mods because your memory is running over a gig in your other post, and that seems quite high.
  19. #19
    Apr 2006
    Quote Originally Posted by Inteleron
    Yes, you are absolutely correct that it's too high. I have since corrected the post. Thank you for pointing out my typo.
    The maximum memory clock that I could achieve was 970 (or 485 in coolbits).
    All further replies should be directed towards the thread in at Guru3D to consolidate the discussion.
    http://forums.guru3d.com/showthread.php?p=1733608
    Best regards,
    Anthony Rogers.
  20. #20
    May 2006
    Russia, Yakutia
    To ALL
    Read and See All Volt_mod on referens: http://people.overclockers.ru/nforser/record5
  21. #21
    Nov 2003
    Longview, WA
    THat site is in Russian...LOL! Also the PCB is blue which reminds me of the non-reference PCB Galaxy version volt mod already featured here. If this is true the above site is no help.
    FX-57 @ 300x10...3,000 on AIR!
    DFI NF4 DR-SLI
    Gskill pc4400 1 gig
    2x6800 Ultras
    2x74gig Raptor Raid "O"
    PCP&C 510 SLI
  22. #22
    Jul 2006
    Finland
    Thanks Anthony! That 7600GS pencil mod works with my 7300 GT
    Sorry my bad english
  23. #23
    Jan 2006
    Belorussia Mensk
    That's reference Albatron 7600GS.
    yes, and that is american
    ______________________________
    SuperPI 1M --- |32s|
    3Dmark2003 --- |9858|
    3Dmark2005 --- |4288|
