Results 1 to 25 of 37
Thread: Mushkin 2GB XP4000 Redline CE-5 – Test Results
Threaded View
    Apr 2005
    Calgary, AB
    Hey guys, I recently got a set of the “new” Redline XP4000 (part #991493) to test. This stuff uses Infineon CE-5 chips which seem to clock better than CE-6 and as far as I can see have no 3d stability issues. The RAM came from Mushkin and is a retail set, not hand picked; I’ve been told the recent batch of CE-5 is clocking quite well. I am going to share my results, suggested timings/tweeks, and impressions of the mem. First off a pic of the RAM:
    Test bed:
    DFI LP NF4 Ultra D (BIOS 0704-2BTA)
    FX-57
    BFG GeForce 7800GTX @ 540/1385
    OCZ PowerStream 520W
    Windows Server 2003
    Cooling - Custom H20
    I started at DDR510 and 2.65v and once I got the drive strength and secondaries nailed down moving up from there was easy. Unlike XP4000 UCCC chips, CE-5 scales somewhat with voltage. 2.67v got DDR560, 2.77v got DDR566.
    Secondary timings and drive strength are important w/ this RAM, the wrong drive strength or 1 secondary off and you cant boot. See the settings below or my tweeker screenie to see what settings worked for me. *Note these settings are the TIGHTEST possible that still maintain stability at the speeds I am running the RAM. Some can be relaxed a bit, YRMV. Also what settings work for me may differ slightly for you because of system differences.*
    BIOS Settings:
    Command Per Clock Enable
    TCL-3.0
    TRCD-03
    TRAS-06
    TRP-2
    TRC-7
    tRFC-13
    TRRD-02
    tWR-02
    tWTR-01
    TRWT-03
    tREF-4708
    tWCL-01
    DRAM Bank Interleave-enabled
    DQS Skew Control - auto
    DQS Skew Value- 0
    DRAM Drive Strength - Level 7
    DRAM Data Drive Strength - Level 3
    Max Async Latency- 8ns
    DRAM Response Time - Normal
    Read preamble Time- 5ns
    Idle Cycle Limit- 00clks
    Dyanamic Counter - Enable
    r/w Queue bypass: 16X
    Bypass Max - 07X
    32 Byte Granularity - Auto
    Vdimm-2.6v + 0.03v in BIOS
    OCing summary
    3-3-2
    2.69v – 280Mhz
    2.80v – 283Mhz
    2.88v – 287Mhz
    2.5-3-2
    2.95v - 260Mhz
    *Notes*
    • Voltages are actual as measured by DMM
    • Results are 32M and 3DMark 05 stable
    • See next post for screenshots
    MB Reviewer for HWC
    Team OCX Bench Team
