Results 1 to 14 of 14
Thread: Abit Aw8 + Centon = Stability Probs?
    Jun 2005
    Luxembourg
    Hi,
    i´m using a abit aw8 with 2 Gb centon memory, an ive a lot of stability problems. im getting one bluescreen after the other, even if i underclock the system. i think that there aere big incompatibilities with the used memory. the bios version is the newest.
    Infos about the Memory:
    Brand : Centon
    Part Number: MT47H64M8BT-37E:A
    FBGA Code: D9DQW
    are there existung modbios versions which are supporting my memory?
    THX
    Xtasy
    I love Extreme Overclocking
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Micron D9 should do good, are you running it overclocked and how far?
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jun 2005
    Luxembourg
    the memory isnt overclocked yet. i tried running the system with only one 512 mb stick but after 5 min i get a bluescreen. i dont think that the problem can anything else than the memory. do you need some special informations? or what you think can be the cause of those problems
    Brotherhood
    Apr 2005
    Land Of KADISOKA
    I think your Chipset Southbrige to hot !
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Centon Rep, USA
    Nov 2004
    CA
    Quote Originally Posted by Xtasy
    Hi,
    Brand : Centon
    FBGA Code: D9DQW
    THX
    Xtasy
    Xtasy where was it you picked up this RAM? Also have you tried any other sticks to see if it is a chipset issue? I have a system at home running that has been months now and I have not had any issues and they are clocked..
    Asus W2V 17' Widescreen
    Intel Pentium-M 2.13Ghz, 2MB L2 Cache, 533Mhz
    Mobile Intel 915PM Express chipset
    Centon 2x1GBD2-667
    ATI Mobility Radeon X700 128MB
    100GB 5400rpm
    built-in subwoofer 4.1-channel surround sound
    DVD+/- RW
    Jun 2005
    Luxembourg
    Thx 4 your answers.
    @hazzan
    i thouched the sb an it is a little bit more than handwarm, i think about 42 degres.
    @ tusacani
    no it hadnt yet a chance to try with other sticks. i bought that memory in the centon webshop. a friend will lend me his mdt memory and ill test. may be it was a problem with win 2k3?
    Edit
    if the same problem with win xp im so fed up with that :/ i dont know exactly where the problem. but i thnik ill find it out this weekend
    Centon Rep, USA
    Nov 2004
    CA
    Thx 4 your answers.
    @hazzan
    @ tusacani
    Edit
    Thanks for the update...Keep us posted as to what you find out if it is ...
    Centon 2x1GBD2-667
    100GB 5400rpm
    DVD+/- RW
    Jun 2005
    Luxembourg
    normally i should get tody 2*512 mb corsair value ddr533 to test my mainboard.
    i tested my centon ram in safe mode, an there were no restarts, even when im watching a film. in normal windows mode the system restarts after a few moments if im looking a film, but i cant surf in the internet for hours without a
    restart. i dont understand the world anymore -.-
    Fused
    Dec 2003
    Malaysia
    if you can run it on safe mode... i dont think its mobo/bios problem... maybe os or driver issue....
    Jun 2005
    Luxembourg
    hi, iknow now whats the problem. intels ing new hd technology makes the system unstable. i desactivated the onboard sound and the system doesnt reboot anymore...
    Centon Rep, USA
    Nov 2004
    CA
    So everything is fine now?
    Centon 2x1GBD2-667
    100GB 5400rpm
    DVD+/- RW
    Jun 2005
    Luxembourg
    no, still reboots, cant overclock as i thought. im going to change that mainboard against a asus p5wd2 premium, hopefully its better, but thnik that may not be to difficult..
    Jun 2002
    Las Vegas
    You can also try one stick at a time to see if one is defective.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Jun 2005
    Luxembourg
    i tried everything :/
    well thanks guys for your help
