Page 1 of 16 123411 ... LastLast
Results 1 to 25 of 384
Thread: AOpen i975X YDGa Problem Solving thread
    ln2nl
    Jun 2004
    The Netherlands
    Ok guys,
    We have problems we have to work out. As many people will get this problem
    Problems occure: stuck FSB
    when?
    No difference between:
    - step 4 and step 8 cpu's
    - Pci-e clocks to even 140mhz
    - pci-e voltage to max
    - Northbridge voltage to max
    - vcore voltage with mods to even 1.6v
    - Many differrent ddr2 sticks from different brands
    - Cooling from better aircooling to even -190°c and no difference
    - I changed the cooling paste on the northbridge cooler
    - I placed a big fan on the northbrigde cooler
    - from sample bios to the beta bios
    - placed memmory in other dimm's
    - i ran single channel
    - i used clockgen so in windows on the fly overclocking
    - i used many memmory settings
    So what would it be..
    Hicookie has the same problems as me.
    We both have a Rev 00A bord (he has retail. i have sample)
    If you have an other rev.. please post
    please post comments in order to help if you have tested!
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Xtreme Cruncher
    Jul 2005
    London - UK
    maybe in need of more VCCA like the dothans?
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    The un-extreme XIP
    Jul 2004
    i doubt it, there would be a larger range of instability then
    i'm guessing bios. newegg is showing 1066fsb support, so they better update it soon!
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    ln2nl
    Jun 2004
    The Netherlands
    i got the newest beta bios.. still doesnt change the problem.
    *EDITed by IFMU*
    Forum Policies
    Xtreme Cruncher
    Jul 2005
    London - UK
    Check what week your PLL was made and see if there's a dodgy week or something...
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by cirthix
    well... I know that with my dothan it booted fine 255 but 256 was a NO GO
    Mr Fantasic
    Apr 2004
    Quote Originally Posted by lawrywild
    yes but that problem was to do with vcca on the adapter.
    ln2nl
    Jun 2004
    The Netherlands
    or its the rev of the baord.. or the 1066 support wich also means an other rev.
    it cant be something else!
    *EDITed by IFMU*
    Forum Policies
    Mr Fantasic
    Apr 2004
    Quote Originally Posted by Waus-mod
    maybe
    I hope it isnt
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by ibby
    there wasn't a problem at all... it just needed more.
    the adapter supplied stock voltages perfectly.
    These Yonahs still use a VCCA supply so it's no different.
    Xtreme Cruncher
    Jul 2005
    London - UK
    Here we are:
    well if the "PLL Supply Voltage" was increased, FSB wall may increase right?
    ln2nl
    Jun 2004
    The Netherlands
    the main weird thing is that our boards are stuck... and the ones from tarosa and tam are out of the box doing 275mhz. So i still say its the revision.
    *EDITed by IFMU*
    Forum Policies
    Xtreme Cruncher
    Jul 2005
    London - UK
    yeh, true say..
    Jan 2005
    Canberra, Australia
    I have the same prob, stuck at 224FSB.
    Tried NB volts, PCI vid card, 2 sticks of ram, better chipset cooling and a few bios settings, no luck.
    Jan 2005
    Canberra, Australia
    Finished PI 1M @ 225FSB!!!
    And she's still stable!!!
    Did a few changes, just gonna check which one worked or if I just got lucky and it's gonna freeze at 226...
    nup 226 froze at loop 3 - but she's getting better.
    What clockgen are we using?
    May 2003
    Hopatcong, NJ
    lol, what did you do to get an increase of 1FSB wwwww?
    Some random bios changes? Just curious
    'Gaming' AMD FX-6300 @ 4.5GHz | Asus M5A97 | 16GB DDR3 2133MHz | GTX760 2GB + Antec Kuhler620 mod | Crucial m4 64GB + WD Blue 2x1TB Str
    'HTPC' AMD A8-3820 @ 3.5GHz | Biostar TA75A+ | 4GB DDR3 | Momentus XT 500GB | Radeon 7950 3GB
    'Twitch' AMD 720BE @ 3.5GHz | Gigabyte GA-78LMT-S2P | 4GB DDR3 | Avermedia Game Broadcaster
    Desktop Audio: Optical Out > Matrix mini DAC > Virtue Audio ONE.2 > Tannoy Reveal Monitors + Energy Encore 8 Sub
    HTPC: Optoma HD131XE Projector + Yamaha RX-V463 + 3.2 Speaker Setup
    Jan 2005
    Canberra, Australia
    Quote Originally Posted by Ramen
    I set tRas to 12 (Cpuz 16) - definately on 12 though, my sticks won't do tRas above 12.
    However when I raised Vcore to 1.5V it was unstable at 225 again.
    Trying again at 1.4 atm,
    yep seems stable enough, just finished two 1M loops...and died on 3rd
  18. #18
    ln2nl
    Jun 2004
    The Netherlands
    i had the same wwwwww... but youre still to a wall sometimes.
    *EDITed by IFMU*
    Forum Policies
  19. #19
    ln2nl
    Jun 2004
    The Netherlands
    doesnt matter! he tried 8 differnt brands. and hicookie also tried other brands.
    update @ startpost.
    *EDITed by IFMU*
    Forum Policies
  20. #20
    ln2nl
    Jun 2004
    The Netherlands
    The working boards are out of the box performing like that... our's not.
    *EDITed by IFMU*
    Forum Policies
  21. #21
    Xtreme Cruncher
    Jul 2005
    London - UK
    I stick to my VCCA comment...
  22. #22
    ln2nl
    Jun 2004
    The Netherlands
    but if it is the vcca who do the other boards go so high out of the box
    *EDITed by IFMU*
    Forum Policies
  23. #23
    Xtreme Cruncher
    Jul 2005
    London - UK
    improved VCCA supply
  24. #24
    ln2nl
    Jun 2004
    The Netherlands
    they didnt mod anything according to prjapan
    *EDITed by IFMU*
    Forum Policies
  25. #25
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Could you guys plese try to boot at 1:1 CPU:Ram in case the mobo has some issues with the deviders?........
    ALSO EVEN 275MHz are not enough......
    INTEL PWA FOR EVER
    Dr. Who my arss...
