Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: 805 D Asus P5nd2 sli preliminary results
    Mar 2005
    Hi guys this is mainly for the people interested in this thread:
    http://www.xtremesystems.org/forums/...ad.php?t=94746
    so i'm posting the results of my experimentation so far. I did have the p5ld2 but had issues with it so sent it back for rma and got the sli board in the meantime and funnily enough i'm getting a better overclock. One question though, my ram is patriot 667 stuff but i'm baffled as to how this ddr2 speed is worked out, am I right in assuming you divide by 2 as with ddr1 to get the true speed? the bios is really confusing as i've got 667 dialled in for the seperate memory clock but its not right (see cpu-z), i've had amd for years and the last p4 i has was a 1.6a so this ddr2 thing has me a little thrown. The reason I ask this is because super-pi seems too slow at 36secs for 1m. From what I can see the cpu is not throttling
    http://img231.imageshack.us/my.php?i...ntitled8mr.jpg
    Will post some 3dmarks with my x800gto in a bit.
    Setup:
    p d 805
    asus p5nd2 sli (not deluxe, extreme or anything just bog standard cheapo)
    2x 1gb patriot ddr2 667
    c3d x800gto @ 16 pixel pipes 500/500
    Feb 2004
    Finland
    Yes you divide the 667 by 2 and you get true speed. 36secs for 1M seems rather low.
    [i5 2500K, ASrock extreme3 gen3, Corsair Vengeance LP 8GB 1600MHz, Palit GTX570 Sonic Platinum, CM HAF932, Antec Truepower New 650w]
    Mar 2005
    I've now got the cpu and ram running 1:1 but it cant bench now, blue screens. Cpu-z reads the memory at 200mhz so thats still only 400 ddr and going by the way the motherboard accepts ram frequency entered it cant use ddr 667. eg to get 200mhz you dial in 800 in the bios with the limit being 1200, so that means 667/2 =333.5 x4 (to get frequency how the bios likes it )= 1334 which is above the bios max .
    Feb 2004
    Finland
    If your memory runs 200MHz its no wonder that the super pi 1M run is that low.
    Mar 2005
    Quote Originally Posted by Nazu
    My sentiments exactly, I cant figure out for the life of me why the bios wont let me select the right speed. I've got it at 667, cpuz shows it at 166 . There are no selectable ratios within the bios. The only options are fsb speed and dram speed which are not presets. ie you have to manually enter what you want.
    Jan 2005
    Northern VA
    Do you get alot of cpu voltage droop?
    What does it do on higher volts?
    Thanks man
    Mar 2005
    Quote Originally Posted by vapb400
    Thanks man
    Still trying to figure out whats happening with the memory, either cpuz is wrong or this beta bios has a bug. The memory is set at 667 in the bios (options are 400-1200) any higher than 800 and I cant boot. The cpu is set to 800 (this equates to 200mhz). At 4ghz with the memory at 667 I get a woeful 36s superpi 1m which suggests to me cpu-z is reading the memory right (reads at 166mhz) and the bios is at fault. If I leave the ram at auto and just try and up the cpu fsb the memory goes way out of sync and beyond spec. I'm getting pee'd off now
    Mar 2005
    Strive for peace w/Acts of War
    why are you running the system on "single" channel?
    So, can it clock higher than 199fsb?
    ASUS P5B Deluxe P965 BIOS 1236 | Intel Core 2 Quad Q6600 G0 8MBL2 @ 3.15GHZ | G.Skill DDR2 800 F2-6400PHU2-2GBHZ & XTreem DDR 800 D9GMH - 4GB RAM Total | 4:5 Ratio @ 350fsbx9 | Tuniq Tower 120 | BFG GeForce 9800GTX | Seagate 2x 250GB Perpendicular HDDs RAID-0 | PC Power & Cooling Silencer 750W EPS12V | Samsung TOC T240 24" LCD Monitor |
    Mar 2005
    Quote Originally Posted by Nasgul
    I only had one stick in whilst trying to figure out whats happening with the memory, I dont know if it can go past 199fsb yet.
    Mar 2005
    Well I dont have a clue whats going off here, still got the memory issue even with a change of sticks (corsair). Cpu-z reads it at 166mhz, bios says 667, cpu at 3980mhz. Tried 3dmark 01 with the 16 pipe gto at 500/500 and it comes out at 22XXX so theres clearly a problem. Any suggestions guys?
    Xtreme 3DTeam Member
    Jul 2003
    Mason, MI... USA
    Davvy, alittle offtopic from what you're wondering but i have a question/comment on the chips performance.
    I've got one of these 805's here on a I945 board and it's throttling badly using the stock cooler in an open case with a boxfan blowing alot of air over the MB/CPU. Whenever it touches 64c it cuts the clocks back alot according to RMClock(link).
    Under dual SP2004 at 3.2ghz it's in a constant state of throttle with default voltage. I was just wondering if yours is doing it too given your greater clocks and giving you some funny looking benchmark scores.
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
    Mar 2005
    Quote Originally Posted by Poki
    Thats why I sent the p5ld2 back. I got a thermaltake big typhoon and even with the voltages at stock the cpu was idling around 60 degrees c even out of the case. For some reason it was in a constant state of being over volted . Thanks for the suggestion though, i'll have a look and post back in a bit.
    Mar 2005
    I cant even post at 3.5ghz now nevermind 3.98, this board is a buggy pos
    Dec 2004
    This is mine on the STOCK HEATSINK, I should be recieving my watercooling gear by the end of the week to see how far I can push this.
    Mar 2005
    On the p5nd2 sli?
    Jan 2006
    Quote Originally Posted by thegreek
    WOW!
    4Ghz on stock. What stepping do you have. There doesnt seem to be much info on which steppings are good.
    I)ickie
    Rig 1: Core 2 Quad q6600 under TR Ultra 120 ex, ASUS P5E Deluxe, 4x1Gb Crucial Balistix DDR2 667, 4870, 1TB samsung F1, Stacker 810, HX620
    Rig 2: E6700 under Big Typhoon, P5b Deluxe Wifi, 2x2gb Gskill Pq, MSI 4850, Seagate 250gb 7200.10, NZXT Apollo, vx450
    Rig 3: AMD64 3000+ under Ultra90, DFI NF3 UT 250g, 2x1Gb DDR 400, 7300gt DDR3, 160gb Hitachi Deskstar
    Rig 4: m1730 core2 p9500, 2x8800gtx, 4gb DDR2, 2x250gb, Blu Ray
    Rig 5: ASUS n10jc Atom @ 2.0ghz, 9300gs, 2gb DDR2, 160gb
    Mar 2006
    Quote Originally Posted by I)ickie
    WOW!
    I)ickie
    As CPUZ states, it is BO which is the second stage in the smithfield I think. Which has seemed to be great for overclocking.
    Pentium D 920 @ Max 5.0ghz
    P5WD2 E Premium
    Mushkin EM 991403
    Dual HC TDX custom water.
  18. #18
    Feb 2005
    be careful bro. , last week i blowed a p5nd2-sli , vcore goes down at load very much . give it back soon and buy a P5LD2
    INTEL 920 4000mhz daily ~ ASUS P5WD2-premium ~ 2*512 DDR2 533mhz Kingston ~ Winfast 6600GT ~ Tagan 580w
    ~ Antec Soho File Server Case ~ Samsung 120GB SATA ~ LG DVDRW ~ Avermedia TV203 ~ SB AUDIGY2 ZS ~ Megaworks THX550 ~
  19. #19
    Jul 2003
    Mason, MI... USA
    The one i've got here will do 4ghz also i'm sure. The MB is a Gigabyte and will only allow a max FSB of 194 (3880MHz) with this 533bus CPU.
    It's kinda funny watching it squirm under load switching between the 14x and 20x multis with the stock cooler which heatsoaks bad.... It takes a good minute for the temp to peak which makes me think a better cooler would work much better. I'm dropping it off to the new owner today or i'd throw it under water to see what it can really do.
    Overall i'm impressed with it for a value CPU, it does multitask quite well!
    E6550 stuck at 3150
    V-DATA 2x1gb
  20. #20
    Mar 2005
    I've given up with the sli board, cant figure out what is going off ram wise. Its going back and i'm reclaiming a new p5ld2 or going for the p5wd2. The only thing thats bothering me with the p5wd2 is its a lot of money (£100) only to have to switch it again to get a conroe. Unless I just sit tight with what i've got until then.
  21. #21
    Mar 2005
    Quote Originally Posted by bahadir_bado
    Have you still got a working one, If so would you have a look at what speed cpuz says your ram is at when the cpu is at 4ghz and the ram at 533?
  22. #22
    Aug 2003
    This cpu seems to be a celeron with dual core. Theres no way you can raise the fsb abour 200mhz.
  23. #23
    Oct 2004
    Canada
    Quote Originally Posted by elec999
    No.......not true.
    Do a quick look through the Intel section and you`ll see that quite a few people are well beyond 200fsb with the D805.
  24. #24
    Mar 2006
    Erm, what? I cant see any likeness to a celeron at all, apart from the price.
  25. #25
    Sep 2005
    Toronto, Canada
    WOW!
    I)ickie
    [sry to threadcrap]
    <<-----^^ im loving all of these new avatars
    [end threadcrap]
    this 805 is making me want to "upgrade" currently running a p4p800e-dlx/3.0e thinking of snagging 1 of these 805's and a p5p800se. any thoughts?
    q9550 @ 444 x 8.5 1.3v - Venomous X
    p5q DLX
    Ocz RPR 1066 4 x 2g @ 1066
    eah5870 V2 @ 920/1250 - HR-03gt
    Antec Fusion Remote MAX
    Xonar HDAV1.3
    Ocz zx850w
