what's the best air cooling to cool opty 165?
![[XC]melymel is offline](images/statusicon/user-offline.png)
			Heatsink wise its between the old XS favourite the Thermaltake Big Typhoon or Tuniq Tower (also maybe the Sythe Ninja). Everyone has their own favourites but I personally like the TTBT as its simple and effective with an easily changable fan, although there have been very good reviews about the Tuniq Tower but i personally haven't ever owned one so can't commen.
The best air cooling in the way of efficency is Scythe Ninja + 2x120mm fans @1-2k rpm. Nothing can match that.
If you`re looking for quiet + effective - Scythe Ninja + 2x120mm fans @ <1k rpm or Thermaltake Big Typhoon.
			I fairly extensively looked at 4 top heatsinks (XP-120, Scythe Ninja, Tuniq Tower, Big Typhoon).
I submit 2 important considerations:
1) Noise tolerance. If you can tolerate medium speed 120mm fans (80-100cfm), look to the Tuniq Tower (with stock fan) or Big Typhoon (buy your own fan).
If you want noise-be-damned cooling, the BT pulled away from the pack in my testing, but you'll have to spring for your own fan. Out of the box, the Tuniq Tower had some very good results for me.
If you need quiet operation, the Scythe Ninja with a low rpm fan, Tuniq Tower (included fan bus), and Big Typhoon are good choices.
2) Airflow of your case. Tower style coolers are generally located for airflow across the motherboard, whereas the Big Typhoon works great if you have a sidepanel fresh air duct. If you have good cross motherboard airflow, you can even operate the Scythe Ninja fanless. I do, even on a overclocked 1st generation Prescott running F@H 24/7.
navig
Navig's list of mod links ~ Exoframe Mini ~ Cabinet PC ~ Vertical Benching Station ~ Brass Tacks ~ Exoframe 2.0 ~ Project Vitis ~ Project Resilience ~ Very Low Cost Benching Station ~ The Exoframe Project ~ Jewel Box Project ~ DIY Benching Station ~ Console Project ~ Project Dark Side ~ Tower PC ~ Dual Tower PC ~ Bench Rig ~ My only standard case
			Big Typhoon would be my choice. Not only you get excellent cooling for the CPU you also cool your mobo.
Intel i7 3770K @4.7GHz (1.224v) | Gigabyte Z77X-UD5H | 8GB Samsung DDR3-1866 | EVGA GTX 780 Classified
Corsair HX850 | X-Fi Titanium HD | ATCS 840 Black
Apogee XT | DDC-2 w/ XSPC Top | XSPC RX360
			A Zalman 9500 pointed at an exhaust fan gives me great temps. Better than my Scythe Ninja, TTBT, and the others in my air cooler graveyard.
i7 920 D0 (bone stock)
Asus P6T Deluxe V2
6GB OCZ Gold DDR3 1600
Antec Quattro 850
FSP Booster X5
Crossfire HIS 4890s
X-Fi Gamer
500GB Seagate SATA 32MB Cache
Windows 7 64 Bit
Watercooled HAF932
			xp-90c w/ panaflo 92mm fan
sidewindercomputers.com
Q6600 G0, G41M-ES2H
2x2gb OCZ Reaper HPC, Windows 7 Ultimate 64-Bit
Intel 160gb X25-M, 1tb WD Caviar Black
460 eVGA GTX SC EE 1gb
Corsair 620w, Asus 24" 1920 x 1200
			Jester. I know you like that config, and I'd admit it is decent.
But you're approaching fanboyism fast when you type that under "best air cooling?"
I'd say the TTBT or the Tuniq tower, I use the tower and I'm pleased with it. The TT has gotten a fair bit of accolades here on the forums and does well in review so those two really seem the best choises atm.
Opteron 165
Dfi NF4 Expert
4x1 1GB twinmos PC 3200
XFX 7900GT 550/1500
			I don't know about the TTBT, but the xp-90c is just as good as the tuniq tower.Originally Posted by Crankster
last time i checked.
Not trying to be a fan boy or anything but I thought xp-90/c + panaflo is still the best air config.
AnandTech heatsink reviews: http://forums.anandtech.com/messagev...&enterthread=y
Q6600 G0, G41M-ES2H
			Hell, I'd use the XP-90C even if it wasn't better, just for the lack of installation issues vs. Tunig!
To be honest, I don't see Jester as any more of a fanboy than Crankster. IMHO
			I love my TT BT. 3.01 ghz at 1.52 vcore, idle/load - 26/34
Gonna mount a basic temperature probe on the side of my IHS soon to see if those temps are remotely accurate.
Core i5 750 3.8GHz@1.3v under OCZ Vendetta 2
MSI P55-GD65
3x Kingston X25-V RAID0
2x Evga 9600GT SSC SLI
G.Skill Ripjaws 2x2GB DDR3-1600
Corsair VX550w, Ghettoed Antec Super Lanboy
Heat: http://heatware.com/eval.php?id=48663
			I'm not sure which mobo you are using, but mine loves the XP-90's downward air flow; not only does it keep my cpu at 30c idle, 46c load, it also keeps the NB nice and cool. Also, install was cake
Conroe XE X6800 @ 4.07
Coolit Freezone
EVGA NF680i Mobo
2GB Corsair Dominator @ 1080
EVGA 8800GTS
WD Raptor 150G, Maxtor USB 300G
Enhance ENP-5150GH 500W
			Ive said it b4, 90mm dont kick it today for extreme overclocking, 120mm is the future for now.
			Well, for extreme overclocking, watercooling or phase change (or better) is the way to go. As for air cooling, There are some very good 90mm solutions that have it all over some 120mm coolers. Just because it's 120mm, doesen't make it automatically better.Originally Posted by humeyboy
			my choice would be the thermaltake big typhoon. i bought it recently and it is AMAZING. at stock voltage, my processor is running at almost room temperature (its at 75-76F and my house is about 70-72F). was quite easy to install except for the lack of a helpful instruction booklet...
AMD Athlon X2 3800 (272x10 32m and prime stable @1.6v) - Thermaltake Big Typhoon
DFI Lanparty SLI-D (currently running latest bios)
OCZ Modstream 520
G.Skill HZ (2x1gb) @ 3-4-4-8-1T DDR544
2x XFX GeForce 6800GT's - SLI (405/1134)
2x 80GB SATA Segate Barracuda 7200.7: RAID 0 - 320gb SATA II Segate Barracuda 7200.10 (storage)
Creative SoundBlaster X-fi
			Correct but the fact its a 120mm BT makes it great, you dont need water today esp on amd64's, the 90mm Thermalrights have seen their day only fanboys love and they are same ones who used to flame Thermaltake here.
I admit this is a great cooler(XP-90c), but sorry, it isn't the king. People beat my temperatures using a big typhoon lapped(mine is lapped as well).
PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
			Get the BT, Ninja is the worst pain in the ass to install IMO. If you like that kind of horrible rush, go ahead and get that.
DFI Lanparty NF4 Ultra-D - R. AD0
AMD Opteron 165 0610DPMW *904* - 2700Mhz @ 1.275
Scythe Ninja w/ Yate Loon @ 30 idle / 40 load
G.SKILL 2GB HZ PC4000
XFX 7900GT @ 555/900
OCZ Powerstream 520w
Western Digital Caviar SE16 WD2500KS 250GB
NEC ND-3550A
Lian Li PC-7B Plus II
Dell 2007WFP
I think most air coolers run better than 444c loadOriginally Posted by Nanometer
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
			There's a good number of us out there, but not too many, XP-90(regular) with a 120mm fan. Nice and compact, cools great, even cools your ram and other parts of the mobo. Easy install too.
I admit, mine's not too quiet, but I can't complain about its performance, I was about to buy the bit Typhoon(had it in my hands ready to checkout) but changed my mind at the last minute.
Running at 2.92ghz w. 1.42v(1.45v in bios), I get 26*/40*C idle/load. Not bad imo.
-Cpu:Opteron 170 LCBQE 0722RPBW(2.87ghz @ 1.300v)
(retired)Opteron 146 (939) CAB2E 0540
-Heatsink: Thermalright XP-90
-Fan:120mm Yate Loon 1650 RPM @ 12V, 70.5 CFM, 33dB
-Motherboard: DFI Lanparty nF4 UT Ultra-D
-Ram: Mushkin High Performance blue, 2gigs(2X1gig kit) PC3200 991434
-Hard drive: Seagate 400GB Barracuda SATA HD 7200.10(AS noisey model)
-Video card: evga 6800GS @520/1170
-Case: P180
-PSU:Enermax 535Watt EG565P-VE FMA (24P)
			I haven't had any issues installing my ninja. I would got with it or the xp90C. You can't go wrong with either one.
ASUS Rampage II
Core i7 920 D0 @ 4.2GHz
Corsair TR3X6G1600C8 3x2GB DDR3 1600MHz
Radeon 5870
Raid 0 2x1TB WD on SATA 3/4
Seagate 160GB on SATA 1
LG Bluray ROM/DVD RW
Corsair HX1000W
lolOriginally Posted by lawrywild
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
TT BT with AS5 x2 1,328V 2600GHz
full load 46°C
best Air cooler?
AMD X2 3800+ 0601 TPMW | DFI Lanparty UT nF4 SLI-DR Expert |
Point of View 7800GT | 2x1GB G.Skill HZ | Tagen TG480W-U01 |
Seagate 120GB | Aerocool T3 *25cm Fan*| Sennheiser PC160 |
			You'd do better with a penny.Originally Posted by lawrywild
im @ 38c load w/ my cnps 9500, room is @ 22c, cant say muhc 2 the others but the artic cooling stuff suxx :P
