Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
Thread: Proth's P5WD2 Vdroop Ghetto MOD
    Jan 2006
    New Jersey U.S.A.
    This mod is for those timid or over caffienated people that don't want to take a soldering gun to your mobo. This is no joke and works quite well. The goal is to lower the resistance of the Analog Devices droop circuitry from about 75k to 40k ohms. The PIC below has a "proper" vdroop mod, so please ignore the wires and pot which isn't required. Should be able to do this mod without removing the mobo.
    Sharpen a #2 or any other soft lead pencil really sharp. Jam the tip of the pencil between Pins 17 and 18 of the Buck Boost converter/regulator. Rotate the pencil while applying slight downward pressure, then snap off tip of lead so it remains jammed between the pins. Low risk, should keep droop under 20 millivolts: Maybe FUGGER can make a GHETTO section, cause I have a lot of ideas on cooling and cases.
    955 @ 5362 MHz on DD RBX @ 1.58v
    P5WD2-E Vcore mod, Vdim mod.
    8000ul @ 4,3,3,8 1170MHz @ 2.7v
    ATI 1900xtx, modded DDx18 / Modded EXOS II w/ Alphacool 1510
    Zippy 6850P
    May 2006
    Thanks for this easy mod! I' ve just done it, works fine...
    Jan 2006
    New Jersey U.S.A.
    Zippy 6850P
    Feb 2006
    Nice mod! Beatiful actually since it´ll probably get someone to try ghetto.
    I´m so addicted to this, it´s like the freeride category of modding. Just you and the hw and stuff not ment to go inside a computer. Not just replacing stuff with better preforming parts and (carefully...) putting together again. Ghetto is so underestimated... It´s the real deal.
    Quote Originally Posted by proth
    Go ghettosection now! And proth: keep up the good work!
    ---GO GHETTO NOW!---
    -150c Club Member
    May 2005
    Northeast, USA
    You could then add a drop of nail polish as well.
    If you have a cooling question or concern feel free to contact me.
    Sep 2005
    UK
    awsome, works wonders for my 930, which is much worse than my old 920.
    Workstation:
    3960X | 32GB G.Skill 2133 | Asus Rampage IV Extreme
    3*EVGA GTX580 HC2 3GB | 3*Dell U3011
    4*Crucial M4 256GB R0 | 6*3TB WD Green R6
    Areca 1680ix-24 + 4GB | 2*Pioneer BDR-205 | Enermax Plat 1500W
    Internal W/C | PC-P80 | G19 | G700 | G27
    Destop Audio:
    Squeezebox Duet | Beresford TC-7520 Caiman modded | NAD M3 | MA RX8 | HD650 | ATH-ES7
    Man Cave:
    PT-AT5000E | TXP65VT30 | PR-SC5509 | PA-MC5500 | MA GX300*2, GXFX*4, GXC350 | 2*BK Monolith+
    Gaming on the go:
    Alienware M18x
    i7 2920XM | 16GB DDR3 1600
    2*6990 | WLED 1080P
    2*Crucial M4 256GB | BD-RW
    BT 375 | Intel 6300 | 330W PSU
    2011 Audi R8 V10 Ibis White ABT Tuned - 600HP
    Mar 2006
    This worked great for me till I replaced with the VR.
    Pentium D 920 @ Max 5.0ghz
    P5WD2 E Premium
    Mushkin EM 991403
    Dual HC TDX custom water.
    Jan 2006
    After doing the pencil mod what should the resitance between 17 and 18 be??? mine is 1.4kOhm isnt that a little low? Dont wanna power it up until i know.
    I)ickie
    p.s. this is with a p5nd2-SLI but it has the same ADP3181 so i assume it works the same
    Rig 1: Core 2 Quad q6600 under TR Ultra 120 ex, ASUS P5E Deluxe, 4x1Gb Crucial Balistix DDR2 667, 4870, 1TB samsung F1, Stacker 810, HX620
    Rig 2: E6700 under Big Typhoon, P5b Deluxe Wifi, 2x2gb Gskill Pq, MSI 4850, Seagate 250gb 7200.10, NZXT Apollo, vx450
    Rig 3: AMD64 3000+ under Ultra90, DFI NF3 UT 250g, 2x1Gb DDR 400, 7300gt DDR3, 160gb Hitachi Deskstar
    Rig 4: m1730 core2 p9500, 2x8800gtx, 4gb DDR2, 2x250gb, Blu Ray
    Rig 5: ASUS n10jc Atom @ 2.0ghz, 9300gs, 2gb DDR2, 160gb
    Banned
    Sep 2005
    East Coast USA
    so thios WILL NOT work for a regular old P5WD2?
    EDIT: YES it will
    Sep 2004
    Brazil
    Quote Originally Posted by n00b 0f l337
    I guess it would lower the resistance too much . Right ?
    E6600@3.3Ghz
    P5B-Dlx ( 0711 bios )
    BBA X1900XTX
    4x512 Corsair 5400UL
    "They couldn't hit an elephant at
    this distance" (last words of Gen.
    John Sedgwick, Spotsylvania 1864) "
    Jan 2006
    It works on my p5nd2-SLI great. Just need a board with the adp3181. Of course the points for soldering might be diff. Correct me if im wrongt but you just need points with 0 resistance to pins 17 and 18. The pencil mod should still be the same. But check resistance before you boot because i had to do a fair bit of fiddling to get resistance between 20 and 30.
    I)ickie
    Dec 2005
    Just to add to the list. I did this pencil vdroop mod on my P5WD2-Pre and P5LD2 both of which has the adp3181 buck controller. No vdroop in any of those mobos now. But my vcore now is set at least .1v higher than whats set in the bios. But thats no problem. I just reduced the vcore at the bios and both machines are happy campers now.
    Dec 2004
    Santiago, Chile
    Quote Originally Posted by greenwar
    It happens with hardmods and ghetto mods
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    sorry to ask this here, is there a pencil mod for the P4C800-E
    im getting up to 0.07v droop and its killing my overclocking.
    my P5WD2-E Prem does the same so i plan on doing the pencil mod to that, thats for sure!
    one thing to remember guys is that pencil led when used for certain things such as this doesnt last forever. i mean i doubt it would degrade fast enough for any of us to see it happen but i just throw that out there for anyone who wants to know.
    i have yet to see a properly done pencil mod go bad but it can happen.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Jan 2006
    Quote Originally Posted by Lestat
    I agree but the good thing about a pencil mod like this is its not gonna kill anything if it does.
    I)ickie
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    i have some pencils here but i cant tell if they are #2.
    i put my DMM on OHM's and put the lead on in between the positive and negative leads of the DMM. the DMM then reads 0.02......
    is this about right or should a #2 pencil read ????
    someone do that and tell me.
    i mean thats my understanding of checking for ohms. turn the DMM to the ohm setting and test whatever your testing. i know when i touch the + and - keads of the DMM together WITHOUT the lead between them the reading was way way higher, so i figure the lead is offering resistance. and 0.02 Ohm of resistance.
    am i correct on this ?
    sorry electrical stuff has always been a weakness of mine.
    Heat Ebay Feedback
    Jan 2006
    New Jersey U.S.A.
    That pencil should work fine. The P4C800 uses a different chip so the pencil mod will not work on it. My kid runs the P4C800 and it's been modded with a resistor, fixed the droop big time. There are a lot of PICS around on how to do this.
    Zippy 6850P
  18. #18
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    proth i sent you a pm about what we talked about before
    hey this whole pencil mod actually reverses the droop.
    meaning
    now instead of drooping the vcore INCREASES..... uhhh.... i'm not sure i understand how or why ?
    idle its nice and steady though.
    i was unable to actually break off the lead between the pins though cuz they are so close together so i just did the best i could.
    not to mention the vcore is now 0.10v higher than what i set in the bios.
    the bios is 1.35 the vcore in windows with every application i can find says its 1.45v or a little higher.
    here are some pics
ID:	47477   Click image for larger version.
ID:	47478   Click image for larger version.
    Heat Ebay Feedback
  19. #19
    Nov 2005
    I have a quick question about voltage readings. I measured my volts from the mosfet to the ground and got 1.25idle/ 1.15 load, but windows reads 1.45 solid. This is on a vdrooped P5WD2-P and P4 630 set to 1.37 in bios. Is that mosfet reading to far off? If so, then why? I just got done modding this board so I'm testing everything out.
  20. #20
    Jul 2004
    denmark
    might be a silly question ,but where does one buy these lead pencils from?anyone wonna send me a small piece off one and nice finding there proth.
    Gigabyte X38T-DQ6/2x1gb xtreme/2x2900xt
    E6850@ 4500
    1000w psu/vapo Ls/2x74gb raptor raid.
  21. #21
    Banned
    Sep 2005
    East Coast USA
    meaning
    here are some pics
    I am experiencing the same thing, instead of dropping, it actually rises.
  22. #22
    Mar 2005
    Australia
    Quote Originally Posted by vanovich
    any pencil will work. The graphite in the pencil conducts electricity
    Opteron 170 @ 3.0Ghz on air, Opteron 144 @ 3.1Ghz on air
  23. #23
    Jul 2004
    denmark
    i tried it with the pencil and got some wird results. the voltage opped like0,1 from what i gave it .the drop under load is much better now .lets say im 1,4 in biose .probe shows 1.5 then when i load the cpu it goes to 1,52 which is ok .the thing is ,that befor ,the pc was stable at 5,2 mhz ,and now im barely stable at 5,1 . wierd wouldnt you say .
    E6850@ 4500
  24. #24
    Jun 2005
    I dont know yet, but I think it works on P5P800 Se to, I had big drops and now les with the mod... I tried this because the P5P800 Se has the same IC number.
  25. #25
    Oct 2005
    Denmark
    weird vanovich... Thats why I wont make the mod
    Asus Rampage II Gene - i7 920 D0 Lapped - Lapped Noctua NH12U-F
    Sapphire HD4870 X2 - 6GB Corsair Dominator GT@T1 - Windows 7 x64
    2 x WD Velociraptor 150GB Raid 0 - 500GB Samsung T166
    Antec ThreeHundred - Samsung A656 40"- TX650W
