Guys it seems some of you are a little confused by the various DFI motherboards and what they were designed to do. I will briefly try and explain here what Oskar has done so that you will all see not all boards are made to do the same things.
NF4, ultra D, SLI D. etc.
Boards tuned purely with TCCD, so much so the first sample boards had issues with Hynix and Micron not booting, they were slightly reworked but did remain TCCD monsters. If you want a good board to clock TCCX dimms this is the board to use.
NF4 eXpert
Market was moving away from TCCD, Oskar designs a board to run 2 gig kits well and 4 dimms at 1T, boards also clock 4 dimms 2t real well and are monsters with UTT, BH5 etc etc. if you like 3d benching then the eXpert will break your records.
RDX200
Same design as eXpert although ATI RD480 chipset. Board is also good with 4dimms 1T etc but is lacking bios support, this due to RD580 board development. If you are looking for reasonable Xfire then the RDX200 may suit you.
Venus
DFI decide to treat the overclockers to something a little special, High quality caps, reworked VRM's and reworked memory traces and drive give us the best of all worlds on the NF4, DDR600+ support with TCCD and 4dimm 1t capabilities. Price was high and all boards sold real fast, in all for me this was the best NF4 board ever made, Rgone from DFI believes this also.
CFX3200
Im guessing here as my board is still on its way to me. Built off the Venus platform with even further tweaks, DDR clock skew, LDT drive tweaks etc. Should be the finest 939 we have seen from Oskar, it brings together all he has learn't over the past 2 yrs into a final 939 board. It should be good with TCCD, BH5, Micron as well as 2gig and 4gig setups 1 and 2T.
Remember though the old NF4 was tuned for TCCD so you will not probably see higher clocks as the dimms will only go as fast as the dimms will go, the DFI boards have been maxing memory now for a long time...so remain level headed about what the board will do.
I hope this helps you all understand where DFI have been going over the past 2 yrs.
__________________
Got a problem with your OCZ product....? Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
might just be my luck, but i'd like to point out that i've had pretty nice results with micron chips on my ultra-d thus far, anything from 5b C to 5b F... though i don't have an expert or venus to compare it to..
__________________
Got a fan over those memory sticks? No? Well get to it before you kill them
Is that the reason why theres so many issues running the 5v jumper or 3.3v jumper trick on the ultra-d?
The ins and outs of the issue with the 5V jumper are not for me to go into, I know i do NOT use the 5v mode and i mod the older NF4 boards for fine tuning the Vdimm and VTT.
With eXpert etc Oskar actually moved to the power design ATI used on the Grouper board, i was quite pleased with this as i actually advised ATI how i would like the Vdimm on the grouper and to have oskar copy it somewhat was an honour..LOL...i will say vdimm on eXpert, venus, RDX200 etc is real nice, fine tuning for me is just awesome and the amount of power the board can deliver is huge.
__________________
Tony AKA BigToe
Ah ok. My expert runs BH5 like a monster but with my ultra-d's even when I'm at 2.8v I get cold boot issues big time with the 5v jumper or 3.3 trick.
Next board = yonah?
__________________ Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3060mhz CPU 2550mhz NB | DDR1020 5-5-5-15 | 875/1225
My cents is thats ultra-d is realy the most pang for the bucks + its still king of bh5 clocks.
Yes Venus is very very good board and its clocks much beter with 4x512 than ultra-d. I dont realy know why someone buy the Expert board..yes if some one need room for 2 gfx the Expert board is good before rd580 are in the stores but if someone not need the room the ultra-d is the best way to go before rd580.
Tony maybe add gfx room to the Expert info + also crossfire + venus on "+ cons".
CFX3200
The CFX3200 is ATI Chipset. How is that Built off the Venus Platform?
__________________
EVGA X58 Classified 759
Intel Core i7 w3520 Bloomfield @ 4.2Ghz (21x200)
G.SKILL Perfect Storm 12GB (6 x 2GB) 1600 8-8-8-21
Cooler Master Storm Sniper
Thermaltake 1000w PSU
2-128GB gskill Titan SSD RAID 0
2-1TB Seagete 32mb RAID 0
1-1TB Western Digital
1- Plextor PX-B320SA Blue Ray
1- Plextor PX-880SA 24x DVD/RW
2- EVGA Nvidia GTX-295 Quad SLI
TRUE w/2-SCYTHE S-FLEX "SFF21G" 120mm Fans
LG 30", Hanns G 28"
