Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: 955xe@6700mhz
    Jan 2006
    İstanbul / Türkiye
    955xe@6700mhz WR
    Asus P5WD2 Premium (Vmch,vdropp,vcore)
    Corsair 5400UL v1.5
    Pc Power&Cooling 1000watt
    Samsung 80GB Sata
    Leadtek 6200
    MM-LN2 container
    My first time with this cpu. Just opened system and benchmark@6GHZ for about 2 hours. After, I begin to raise the MHZ and got only those score before my LN2 finished. Cpu can do better than this..
    Let the screenshots talk..
    I'll put the pictures soon..
    http://valid.x86-secret.com/show_oc?id=81015
    Jan 2006
    İstanbul / Türkiye
    Quote Originally Posted by Unseen
    Wow.. Nice Any 32m?
    My LN2 just finished while I was taking 2x32M@6000 .. All the spi scores will be better next time. I was just learning about the chip ..
    ln2nl
    Jun 2004
    The Netherlands
    Great... gl next time!
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Feb 2005
    Turkey - Istanbul
    Very Good Score My Friend
    ||[b] Intel i7 4770K @ Phanteks PH-TC14PE || Asus Maximus VI Hero || 16 GB Gskill TridentX @ 2400MHz || CoolerMaster CosMoS S II || Asus GTX 780 @ AC Accelero Xtreme III[size=1]|| 24" BenQ XL 2410T @ 120HZ || 256GB Samsung 840 Pro || WD Green 1 TB , WD Green 2 TB || OCZ ZX 1000W || @ [size=1]|| Creative SoundBlaster Zx - Logitech Z-2300 || Logitech G19 || Logitech G700s|| [/color] ||
    Jun 2005
    nice work
    Nov 2005
    The Netherlands
    Give us some pics of yer system ...
    Y`know : 965XE is out ...
    Jun 2003
    Netherlands
    Be carefull with that voltage!
    Crotale's CPU is starting to clock worse after using such high vcore for a while. You probably can find info about that in a few threads here @ XS.
    But nice overclock anyway
    Edit:
    Some more info about the cpu degrading:
    Quote Originally Posted by Kinc
    Crotale and I ran some 955 this weekend. It never worked as it should and now the cpu is almost dead. The resler core may be sensetive to high voltage and clocks. Since it has been geting weaker after each time.
    http://service.futuremark.com/compare?3dm06=150598
    Quote Originally Posted by crotale
    Yes, completely different plattform and different cards.
    The CPU is really degraded now 1.8vcore seems to be a little too much for the 65nm process.
    source
    | Core 2 Duo E6600 @ 5304MHz | Biostar TForce P965 Dlx | XFX 7800GT | 1GB Crucial Ballistix PC5300 CL3 |
    SPi 1M: 9.953s
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Nice chip, If I can offer you a suggestion, I believe that ram should be capable of around 750Mhz @ 3-2-2-4 timing @ 2.3v and would improve your pi score quite a bit. use 1:1 ratio on that board with tightest timing.
    My CPU is as strong as the day I got it and I have been beyond that in voltage for very long durations. Im more afraid to put this chip into an Nvidia based mobo.
    Grats, nice results
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jan 2006
    İstanbul / Türkiye
    Thank your for tihs information. With that voltage, I go up to 6800MHZ, I almost click the save button for validation but reset..
    Apr 2005
    Melbourne, Australia
    Quote Originally Posted by MuratOzsay-TR
    Corsair 5400UL v1.5
    Samsung 80GB Sata
    Leadtek 6200
    MM-LN2 container
    MuratOzsay-TR, can you run PCMark04 & 05 at or near those clocks ?
    Love to see Intel 65nm cpu's at top of class again...
    For that FSB speed and NB. what Volts are you using ?
    Thanks.
    Signature? are you kidding? with new stuff coming out every day, why bother ?
    Jun 2005
    Turkey / ANK
    6700mhz intel power
    Q6600 1.390v 3.8G Vid: 1.2125 Thermalright Ultra-120 Extreme .DFI LanParty DK P35-T2RS. Crucial Ballistix Tracer 8500 2x1GB.. Seagate 410As Raid0 .. Sapphire HD4870 512mb & Cooling Thermalright HR-03 GT.. 19 LG 1950SQ .. Silverstone OP850 watt. Case Gigabyte Auro3D
    Jan 2006
    İstanbul / Türkiye
    Quote Originally Posted by FUGGER
    Grats, nice results
    thank you.. I know, my ram is stable at 780MHZ 3-2-2-4 @ 2.3v .. But I was just learning the cpu.. what it is capable of. This is my first time with this chip.
    -150c Club Member
    May 2005
    Northeast, USA
    20X? Try anything larger yet?
    If you have a cooling question or concern feel free to contact me.
    Jun 2005
    TAIWAN
    dire,vcore@1.9v,somekind behavior of suicide.
    Xtreme Recruit
    Aug 2005
    Nice results, congrats!
    namu daishi henjo kongo
    Jan 2005
    Somewhere in Germany
    Nice results!
    Seems thats new Intel-CPU´s are getting easier to OC...
    But Yonah needs around 3 GHz to get < 20 s 1M...
    Quote Originally Posted by NEW MODEL ARMY - the attack - 1984
    Now the talking's over, plans are laid and the hour is set
    Glances round the table, eyes all shining, dark and bright
    We meet again at daybreak for the day that will be ours
    We're tomorrow's history. So just check your weapons, say your prayers.
  18. #18
    Oct 2004
    Istanbul
    Congrats Murat,
    ne demişler, boynuz kulağı geçer
  19. #19
    Dec 2005
    Nice results, congrats!CPU temperature was wrong?
  20. #20
    Jan 2006
    İstanbul / Türkiye
    Quote Originally Posted by IluvIntel
    Thanks.
    I run at 6GHZ .. In pcmark2004 Grammer Checking failed, In Pcmark2005 2 things failed in cpu tests. So no cpu score.. I will try again in my new Asus 975 board.
    NB : 1.65v .. I didnt use mod .. Board was moded but didnt need it..
  21. #21
    Champion
    Jan 2004
    Athens , Hellas
    That's some very nice PI scores ! Intel's comeback year !!!
  22. #22
    Feb 2005
    Estonia/Tallinn
    Nice work !!
  23. #23
    Xtreme Family
    Dec 2004
    Republic of Hiroshima
    Xtreme !!!!!
    Congrats Murat
    Mojo
    Family
    Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
    Criminal
    Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
    Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
    Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
    Kids
    P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
  24. #24
    Master of nebulah frost
    Dec 2004
    Dolomites(Italy)
    Impressive!!!
    A very monster this chip
    Battlefield 3: Nachthymnen666
  25. #25
    Nov 2004
    Brighton, UK
    Very nice, any idea of 3d clocks? good luck next run.
    "Bloody hell, im gonna die to Boney M"
