Results 1 to 7 of 7
Thread: What IC's does the Mushkin Extreme Performance memory use?
    Banned
    May 2005
    Virginia, USA
    Question What IC's does the Mushkin Extreme Performance memory use?
    Just wondering if anyone know which IC's this RAM uses off the top of their head? Trying to figure how much voltage is safe to run through it. I was thinking that it's UCCC but possibly UTT?
    It's this stick here on Newegg:
    http://www.newegg.com/Product/Produc...82E16820146353
    Thanks in advance!
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    V2 is supposed to be Samsung stuff.
    For those of you about to post:
    Banned
    May 2005
    Virginia, USA
    Quote Originally Posted by craig588
    Thanks mate, I had a feeling it was UCCC. This stuff clocks pretty darn good, just need to get my LN2 tube hooked up to this DTR now.
    Jun 2005
    hey, what UCCC are you talking about?
    this Mushkin is 2-2-2 stuff, so it should be TCCD or TCC5.
    [SIGPIC][/SIGPIC]
    Banned
    May 2005
    Virginia, USA
    Quote Originally Posted by high5
    Then it must be TCC5 because I'm positive it's not TCCD.
    Xtreme Cruncher
    Mar 2005
    Send Duonger a PM - he usually has pretty good details (works for Mushkin)
    Bloodrage || 920 @ 3.2Ghz || TRUE Black
    3x 2GB HyperX 2000 || @ 2000Mhz 7.7.7
    2x 300GB WD VR Raid 0 || 2x 2TB Samsung F3 Raid 0
    LG 10x BD-R || LG 22x DVD/RW
    MSI GE 470 || LG 246WP
    Sonar X-Fi || Klipsch 5.1
    Lycosa || Mamba || Exact Mat
    CM ATCS 840 || Seasonic M12D
    Server 2008 R2 x64
    Banned
    May 2005
    Virginia, USA
    Quote Originally Posted by gr8golf
    Will do, thx gr8golf!
