I decided to install an NV5 Silencer Revision 3 on my 7900GT.
Stock Cooler Removed, Core and memory cleaning with isopropyl alcohol.
G71 core, nice and shiny.
Silencer Installed, Notice the problem yet?
Yeap, the silencer is too long.
Had to modify my case a little...
Temps Idle dropped from 45C to 38C. Load temps dropped from 67C to 50C while running RTHDRIBL for 5 minutes...
Thats with the core at 560mhz and the memory at 1800mhz.
As far as noise goes, I cant hear my computer at all anymore. The silencer is well, silent!
Im about to go test a modified 7900GT bios that has 1.4volts applied to the core and see how I do now I have aftermarket cooling. Ive tried the bios with stock cooling and I got to 600mhz core, but I had tiny artifacts in 3dmark03.
