Hey all,
Just got my Ek x1900 water block in the mail. Here are a few pics.![]()
Block came in excellent shape. Base does have some very minor milling marks. But a quick 30 second lap job solved that problem. Milling marks were very slight, and might not have affected temps. I did not do a before and after test.
As you can see temps for gpu are 44c, which is 2c cooler than with my Maze4. Ambient temp is 21.5c. Minor quibble with the mosfet cooler. Didn't come with mounting screws, so I used a couple from the stock heatsink unit. Also while temps for mosfets are better, not as good as I thought they would be. But again a minor quibble.
For some reason a steel shim was placed between where the mosfet cooler and the block attach. When doing test mountings I found the shim to be unnecesary and so didn't use it.
All in all, this block rocks. Build and finish are top notch. Packaging was fine, with the block placed in bubble wrap and securely placed inside a well taped box. Comes with easy to understand and follow directions, for those who need them.![]()
On a scale of 1 to 10 the Ek x1900 gets a 9.5, excellent but not perfect.
I highly reccommend the Ek x1900 block...
