FX-60 CCB2E 0536RPMW + DFI NF4 UT SLI-DR benchmark and mini review adventures.
Yup, was crazy enough to get myself one of these going to cover some of the cost with selling off my Opteron 170 CCBWE 0544XPMW http://i4memory.com/showthread.php?t=1803 and eventually my Opteron 146 CAYBE 0540FPBW
Room ambient:
- room temp right now is between 30.1 to 31.8C
The cpu:
Thanks to k00lance at xtremesystems.org, the FX-60 arrived from USA brand new unopened retail box. The cpu was perfect condition, but same can't be said for the inside green protection foam which must of had a bad day
Still going to cool cpu with Corsair Hydrocool 200EX Water
- Pics are off Hydrocool 200 model but same as 200EX except EX model has fan filter on exhaust fan by default and slightly revised waterblock lapping on EX model
- Tubing is 6mm inner diameter based or 1/4" OD - puny i know
System:
FX-60 CCB2E 0536RPMW using Corsair Hydrocool 200EX
DFI NF4 UT SLI-DR R.AB0 1114-3 bios
512mb HIS X1800XT
4x 80GB Hitachi 7K80 SATA II raid 0
1x 250GB Maxtor Maxline Plus2 PATA
LiteOn 165H DVD-ROM
FDD
1KW PC Power & Cooling SLI psu
Memory used:
2x 1GB OCZ PC4000EB Platinum dual channel 3-3-2-8 rated ram
@13x 200mhz 3-3-2-5 7-14-2-2-2-3 at 2.64v
VID = AUTO
VID Special = AUTO
chipset = 1.5v
LDT = 1.3v
LDT 3x
CPC = Enabled
CAS Latency(CL) = 3
RAS to CAS(Trcd) = 3
Min RAS# Active time(Tras) = 5
Row Precharge Time(Trp) = 2
Row Cycle Time(Trc) = 7
Row Refresh Cycle Time(Trfc) = 14
Row to Row Delay(Trrd) = 2
Write Recovery Time(Twr) = 2
Write to Read Delay(Twtr) = 2
Read to Write Delay(Trwt) = 3
Refresh Period (Tref) = 1552
Write CAS Latency(Twcl) = 1
DRAM Bank Interleave = Enabled
Skew = AUTO
Skew Value = 0
DRAM Drive Strength = Level 8
DRAM Data Drive Strength = Level 2
Max Async Latency = 7ns
DDRAM Response Time = Normal
Read Preamble Time = 5ns
Idle Cycle Limit = 16
Dynamic Counter = Enabled
R/W Queue Bypass = 16x
Bypass Max = 7x
32 byte Granularity = Disable(8burst)
Results:
- Swapped out my Opteron 170 and plucked in FX-60 and used AS5 TIM with Hydrocool 200EX block.
- Bios idle temps were 3-5C higher with FX-60 @2600mhz 1.312v vs Opteron 170 @2600mhz 1.312v = 36-38C vs 31-33C
- Windows idle temps were 3-4C higher with FX-60 @2600mhz 1.312v vs Opteron 170 @2600mhz 1.312v = 33-36C vs 29-33C
Some stock screenies
@2600mhz 1.312v idle
very short dual stressprime small ffts and blend just to see what idle vs load temps are
dual cpuburn K7 for 33+ mins - yup hot cpu with 45C load temps!
Memtest86+
- very preliminary tests just to get an idea of what cpu range is.
First test is at 13x233HTT = 3029mhz at 1.312v stock vcore with 2GB OCZ PC4000EB @233mhz 3-3-2-5 at 2.64v with 2753MB/s memtest reported bandwidth and ran with no probs until it came to test #7 had errors. So upping vcore to see what the cpu likes
Overclocking:
Decided 3029mhz will be my first overclock to aim for. It booted into windows at 1.312v stock vcore but the apps were flaky when loading. So jumped straight to 1.408v for benching
@3029mhz at 1.408v
13x 233mhz 3-3-2-5 7-14 2223 at 2.64v
CPUZ Validated http://valid.x86-secret.com/show_oc.php?id=76841
Super Pi v1.4 mod
Single 8M & 32M
Dual 8M & 32M
Systool 32M PI with parrallel processing
Very happy with this cpu so far, even better than my FX-57 0516WPMW oc'ing wise. Not sure about memory controller wise yet as it's still too early to tell![]()
damn post office
