Results 1 to 16 of 16
Thread: DFI Expert Video/Boot Issues
Threaded View
    Xtreme Cruncher
    Jun 2005
    MA, United States
    I decided to start working on overclocking my video card today. I turned off the PC, upped the potentiometer (7800gt volt mod) a little bit and booted (raised memory from 2.18 to 2.19, in the past I ran 2.3). I shut down and turn it one or two more times and try to boot. The computer won't post and the mobo is stuck on the 2nd LED Diag, which refers to video. Now I am thinking I just fried my card. I slapped in 2 different PCI cards and the same problem occured, except one card booted at first but after a BSOD it rebooted and the same problem occurs. I am assuming it is now the motherboard but I have no clue where to start. I've seen others with video problems on this motherboard too, I've tried clearing CMOS, switching out my memory, took out all my add in cards, etc
    Any suggestions?
    Edit:
    When I boot, all 4 of the LED Diags flash on and off, I don't know if this is normal either
    Edit2:
    Well I got it to boot, I took out everything, let it sit for 10 minutes to discharge completely, and booted with just the video card in, but the problem is intermittent, upon rebooting or changing the BIOS settings it started doing it again... It also happened when I added another stick of ram in the other OJ slot. I would like to note that I am using some crappy 512mb kingston value memory
    Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
