Folks, time to offically introduce Team Group's another power 2GB set Xtreem series,
that is, Overclocking DDR 500MHz Dual Channel Cronus series UCCC
From the official webiste, its specifications shows as followed:
Model / Speed:PC4000 DDR500MHz
Capacity: Dual Channel Mode
CL rated: 3
Team Group part number: TXDR2048M500HC3DC
Official description:
" The Team Xtreem UCCC series is a line of high-performance memory modules bringing you advanced speed
grades, and low latencies, and especially designed for performance enthusiasts who want to challenge to
the limits of performance without worrying about data loss or corruption, mysterious intermittent
errors and display problems, or worse-the dreaded BSOD!
The modules are based on the Samsung UCCC memory IC, a new generation chip produced under
o.11 micron processing. This memory IC achieves very high frequencies (more than 500MHZ, against a
standard of 400MHZ), at a low voltage(less than 2.7V under 500MHZ operation).
In order to achieve maximum performance, the SPD of Xtreem UCCC series is specially designed under
500MHZ CL=3-4-4-8 in dual channel mode. In BIOS on motherboard, only FSB item needs to be changed from
200MHZ to 250MHZ.
The ‘Xtreem UCCC’ series ensures extreme performance without the fear of unexpected interruptions.
And, remember, each Xtreem module (as with any TeamGroup ram module) is lifetime- and satisfaction! -
guaranteed.
*Warranty Void in cases of manmade failure or natural disasters."
So, that's see the module standard and Some overclocking stabilities bench:
The Ram set:
well I told you guys before, 0552 UCCC has somethig fun to do..sit tight
Please note, this ram is rated @ DDR500 3-4-4-8 2.7v
Let's see what can I do
Testbed:
Motherboard: DFI NF4 Ultra-D, bios 1114
OS : Windows XP sp2
Video card: Asus NV 6200 TC
Cooling: PCICE Single stage -50c loaded
CPU: AMD 4600+
PSU : SilverStone 600w ST60F
HD: Western Digital 2500KS Raid 0
Let 's see the super pi mod ver.1.5
oops, looks like I set it as 3-4-3-8
1m:
8m:
now because i use dual core processor, so by running dual 32m, I will enclose digital camera shots
, 2 shots for ddr500. Hope that would verify my results.
1. run 1
2. finished:
windows captured:
Well here you go, now, how many vdimm you assume this can be run about DDR600?
check it out.
All the benches are non- reboot running.
1m:
8m:
now, let's bring it on dual 32m, now, I have 5 pics from digital camera
and I show everything I can.
initial run~5th:
6~11
12~17
18~22
23~finished:
Windows cap:
now, some more extra...
DDR620...spi 1m and cpu verify..
Take ca guess, will I break WR for 2gb set database?
Thank you for all those who love TeamGroup.
OPB
..sit tight
Got my set yesterday.. they both work individually at 280 at least with 2.63v (didnt try farther Mhz), but I can't get dual channel over ~273 without tons of errors in test 5. (>15000/pass). I think my mem controller is t3h suck
Or maybe it's the mobo. Though I still haven't brought them up to the rated voltage..
Not bad sticks at all but something in my setup can't handle it.
