Results 1 to 10 of 10
Thread: Possible to access Mac bios?
    Oct 2005
    Orinda, CA
    Well, I have an old eMac G4 700MHz hanging around, and I was wondering how do access the bios? It has 1GB of PC133 memory (that I stuck in)... I mainly use the compy for folding, and I know it needs a preformance boost, only pumping out 1WU per week. The OS is 10.15 and I also have OS9 installed. If I can't get into the bios, is there software I can use?
    Main Rig ---> E6700, Biostar TForce 965PT, 2x512 Micron D9's, Custom Watcooling, 520w OCZ Powerstream
    Rig 2---> P4 640 @ 4GHz, DFI LanParty 875P-T, 512MB crap, Sunbeam NUUO 550w
    My Old Rig --->2.4AE @4.15GHz , semi Stable, yes 1.75GHz OC ...
    Heat 42-0
    Quote Originally Posted by nn_step
    because Intel likes their odds just like they like their sandwiches.. Stacked..
    Xtreme CCIE
    Dec 2004
    Atlanta, GA
    Not sure about whether you can access the Mac equivalent of BIOS... but I know Macs don't have BIOS's in the same capacity that you think of PC's Basic Input Output System. Personally I don't think there is anything you can do, but I'm not sure about 3rd party software.
    Oct 2005
    Orinda, CA
    Humm, that's what I assumed.. I guess most of the mac OCing was done by volt mods (ie. the mac mini) and stuff like that. Bummer.
    Heat 42-0
    The un-extreme XIP
    Jul 2004
    mac overclocking is done by changing the multipliers by resoldering 0ohm resistors on the pcb of the cpu
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Join XS WCG or \/ !!
    Dec 2005
    Earth:\USA\OHIO
    Not for the faint of heart. Check out www.xlr8yourmac.com is a good place to start. You can always do a replacement chip in it.
    Got an Xtreme System? Bring it here! <----
    Dec 2005
    Earth:\USA\OHIO
    Sorry forgot the direct link to the rate your upgrade experiance. http://forums.xlr8yourmac.com/cpureview.lasso
    Oct 2005
    Orinda, CA
    Quote Originally Posted by mysticmerlin
    Sweet thanks a ton
    Heat 42-0
    Dec 2005
    Earth:\USA\OHIO
    Not a prob. Just courious what version Mac it is. Like Quick silver or mirror drive or what?.
    Mar 2006
    He says it's an eMac. You know, one of the last all-in-ones? And cirthix is right, with a few exceptions in the ol' grey era that used jumpering on the motherboard to set clock & bus speed, the way to overclock most Macs is via changing SM resistor packs -- not a job for the faint of heart.
    Macs don't have a BIOS, they use something called OpenFirmware. And even then, there's no way to access timings & the like there. The Mac is not a tweaker's platform by any stretch of the imagination
    FAB
    Dec 2005
    Earth:\USA\OHIO
    Quote Originally Posted by JeffTracy
    Thanks for pointing that out. I was not paying attention. Welcome to the forums. Nice to see new Macies in here.
