Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: FX 60 & X1900XTX - A Few Trials
    Jun 2005
    Istanbul - Turkey
    Test System:
    A64 FX60 536 SPMW Cooling by Vapochill LS -45 Evap , İdle -12 Load +5
    DFI Lan Party EXPERT SLI
    Geil One BH5 2X512MB
    Sapphire X1900XTX Cooling by Waterbox(Chilled Water Cooling) +6 Block , +22Gpu
    Asus Rampage II Extreme - Intel Core i7 920 - 3x2 GB Corsair Dominator 1600MHz -1792MB Zotac GTX 295 - 500 GB Seagate 7200.12 - 1 TB Seagate 7200.11 - 500 GB WD Hdd - 16x Nec Sata DVD-RW - 26" Samsung T260 - Logitech Pro Keyboard - G5 Mouse - Razermat Control Pad - Lian-Li V2000 Case - Tagan 700Watt BZ Psu - Logitech Z5500 Speakers
    Nov 2005
    congratulations
    what the stepting your cpu muhahhhahah
    ** hi ozan last night ı leaved early sorry but you know
    my sun is ill we will make new test all together at weekend at my home
    ı will ready my oc. worktable for ln2 hihihihihihi
    Jun 2005
    Istanbul - Turkey
    I know your situation my friend. I'll be ready whenever you want. We'll push these babies to their limits
    Jun 2005
    Congratulations my friend
    XIP
    Nov 2004
    NYC
    Nice scores there Ozan
    Jun 2005
    Istanbul - Turkey
    The only drawback we encountered was the low fsb limit of the fx60 under phase. If we could get at least 240-250 mhz fsb I think we could get a lot better 3dmark scores especially from 2001. However our fx60's fsb limit under vapo seems to be approximately 230 mhz
    XIP
    Nov 2004
    NYC
    You're right around 230-240ish htt @-37C evap temp or -46C on Vapo's lcd.
    Did you try with MPS multiprocessor? It will give you xtra heat load.
    Also Major did some testing with 233 divider.....http://www.xtremesystems.org/forums/...ighlight=major
    Jun 2005
    Istanbul - Turkey
    No actually we didn't try MPS Multiprocessor. It was only standard ACPI Multiprocessor in device manager. Would it make a difference about the fsb limit?
    Live Long And Overclock
    Sep 2004
    Very Nice !!!
    Though that FX60 doesnt help you any in 01
    Perkam
    XIP
    Nov 2004
    NYC
    Quote Originally Posted by Ozan Baseski
    It gives xtra heat load, so you can have xtra time to set up clockgen and gpu tweaks before it freezes up in windows.
    Major's tweak with 266 divider seems to work good with FX60 and single stage
    Jun 2005
    Istanbul - Turkey
    Well I suppose raising the mem divider above 200 could help. I didn't think of that
    Champion
    Jun 2002
    lab501.ro
    Your scores seem a little low for those clocks, you might want to bump that memory a little ... here are my first tests, 24/7 settings and no LOD tweak:
    And 2001 with higher clocks and LOD tweaked:
    Jun 2005
    Istanbul - Turkey
    Our problem was fx60 couldn't make above 230 mhz when using phase change. What was your cooling when you make 250 fsb at 3ghz for example. If it's air or water we could have easily done that.
    Other than that I'd like to know how could you make lod adjustments on x1900xtx. I know that ati tray tools last version (at least the last I know) don't recognize these cards. I was doing the lod tweak with the x1800xt but not with the x1900xtx
    Champion
    Jun 2002
    lab501.ro
    Everything was on stock cooling. My problem was with /12 divider for memory, the memory was clocking ~20Mhz lower than usual so for clocking the CPU higher i had to use /13.
    You adjust LOD with latest version of ATI Tool, settings/driver tweaks/lod something.
    Jun 2005
    Turkey / ANK
    avesome ozancım..
    Q6600 1.390v 3.8G Vid: 1.2125 Thermalright Ultra-120 Extreme .DFI LanParty DK P35-T2RS. Crucial Ballistix Tracer 8500 2x1GB.. Seagate 410As Raid0 .. Sapphire HD4870 512mb & Cooling Thermalright HR-03 GT.. 19 LG 1950SQ .. Silverstone OP850 watt. Case Gigabyte Auro3D
    Jun 2005
    Istanbul - Turkey
    I decided to give the system a last shot. And choose 233 divider from the bios for the ram and redo the 2001 test. It really affected very much
    The max. validation
    Champion
    Jun 2002
    lab501.ro
    Stop using Overclocker and use ATI Tool instead, you will see an improvement in scores (even if the memory won't clock the same); Overclocker automatically increases timings when raising the memory clock.
  18. #18
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I'm glad to see someone else confirm that the coldbug is related to HTT and NOT ram clock.
    If you don't mind I'm going to start a thread about it and link to your results along with mine.
    I started a thread about the coldbug and using the 233 & 250 dividers to overcome it, it can be found HERE
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
  19. #19
    Xtreme Mentor
    Feb 2004
    The Netherlands
    Quote Originally Posted by Major
    I started a thread about the coldbug and using the 233 & 250 dividers to overcome it, it can be found here
    it's vdimm related. if he'd use TCCD, coldbug will not be an issue. better yet, kunaak's 2.2v ram
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
  20. #20
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Quote Originally Posted by biohead
    I has nothing to do with Vdimm, Vldt, or Vcore. Its stricktly a HTT/temp issue
  21. #21
    Jun 2005
    Istanbul - Turkey
    I agree with you Major. Cold bug is directly related to the cpu's htt speed. Of course you can use our scores in your topic
  22. #22
    May 2005
    Camping your spawn :)
    Verry nteresting major, im sure alot of 60 ownere r gona be verry happy with this news once it arrives all ovet the place..
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
  23. #23
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    nice results and I'm really impressed how all of you always searching for new tweaks getting the coldbug issue outa the way ^^
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
  24. #24
    Mar 2005
    Well what can you do IF you cant even get the thing to boot under a VAPO LS??? Use it on water or air to set say 16 X200 or 17X200 in the bios , then reboot???? Cause afte a few runs @ 3.4, my chip wont even boot under Vapo,@ 200X15 undr water though.
  25. #25
    Mar 2005
    DFI NF4 UT Lanparty SLI-D btw, tried official 11/14 bios and FX60 Beta.I'll make a sig with specs.
