Results 1 to 15 of 15
Thread: Negative pings on dual core X2/Opty's?
    Mar 2004
    New York
    Hey guys.... this is a weird one:
    I did some more digging and came up with some threads about it:
    http://www.dslreports.com/forum/remark,15398295
    http://www.dfi-street.com/forum/showthread.php?t=34151
    http://forums.nvidia.com/index.php?showtopic=4978&st=80
    has anyone else had this bug or figured out a workaround? For me, a reboot clears up the bug for awhile (1-4 hours) but then it comes back. I heard its solved in Vista but I am waiting for the Feb CTP release to install that. I already tried switching between the onboard NV enet and the Marvell Yukon on my DFI expert. I am using the latest drivers, patches etc.
    The weird part is that if I set the process affinity to core#1, the problem disappears. This is confirmed by other people as well. Here's a screenshot from PingPlotter, you can see in the beginning, at the bottom all the blank area, those are negative pings. Then you can see where I set the affinity, the pings returned to normal....
    Gigabyte GA-EP45-UD3P v1.6 bios FC
    Q9650 @ 4.3ghz
    8GB HyperX 5-5-5-15
    Win7 x64 RTM
    Mar 2004
    New York
    nobody?
    Q9650 @ 4.3ghz
    8GB HyperX 5-5-5-15
    Win7 x64 RTM
    Feb 2006
    hummm............ I had the same problem and couldnt figure out what the problem was .it only happens if you have a dual core. the fix by GAR here--> http://www.xtremesystems.org/forums/...ad.php?t=81429 helped a lot the Ping issue but I remember that with my old 3200 I always had a low ping number while playing online. on the other hand everything else works so smooth that I will stay dual core for ever! never going to single core again!
    MOBO=|DFI lanparty ULTRA-D|
    CPU=| AMD A64 X2 4400+| 2.7GHZ 270FSB
    HDD=| 160GB SATA II |
    memory=| 1gb DC PATRIOT XBLKPC4800|270->3-3-3-8
    VIDEO=|X800XL PCI-e |
    New System
    MOBO=|DFI LANParty DK P35-T2RS|
    CPU=| QUAD Q6700|LAPPED 3.8Ghz 380x10 *Air
    Cooling=|TRUE-LAPPED|
    HDD=| Raptor 150X |
    memory=| G.SKILL(2 x 2GB) DDR2(PC2 8000)|
    VIDEO=|MSI8800GT|760/1800/2000
    XS News
    May 2005
    FL
    Wierd, DEF don't get that (just tryed). Im using wireless connection though, might make a difference?
    i7-3820
    SB Z
    16GB 2200
    GTX690
    1KW Lazer
    Xtreme Cruncher
    Nov 2003
    MD, USA
    That AMD hotfix works great omega...
    Could this negative pinging be the reason my friend keeps getting an AIM error after leaving it idle for a few hours? He has an opteron 165.
Name:	aim error.JPG
    3570K ● Asus V Gene ● 8GB Mushkin DDR3-2133 ● EVGA 660 Ti SC ● Seasonic X750 ● 128GB Samsung 830 SSD & External 1TB RAID1
    SupremeFX SPDIF -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> AKG K701
    Sep 2003
    Sweet you achieved what all of us are trying to do. You made your computer so fast you are going ahead in time. Sorry I have no help :o
    Feb 2006
    might wanna try this fix-> it explains it step by step and tell me if you see 2 CPU'S evebody let me know if you see two cpus! ->http://forums.amd.com/index.php?showtopic=64936
    New System
    HDD=| Raptor 150X |
    Banned
    Jun 2003
    Broomfield, CO
    /usepmtimer flag used in your boot.ini file?
    Nov 2003
    Discovering vCore-to-Strap locks
    That fixed it for me when I had that issue a while ago. (/usepmtimer)
    Q6600 G0 at 3.5 GHz 1.30v on DFI P35-T2R
    4GB OCZ PC2-9200 Reapers
    150GB WD Raptor, 2xWD 120GB RAID-0, 3x320GB HDD
    BFG 8800GTS OC at 675/2100
    Danger Den Based Water Cooling: TDX-775, 8800GPU, DD NB Block on Thermochill PA120.3 Radiator w/ DD 12V Pump
    OCZ GameXStream 850W
    MountainMods U2-UFO 18" Cube Case
    DELL 2405FPW 24" Widescreen LCD
    RME-Audio Fireface 800 based audio production
    Mar 2004
    New York
    i will try that on my next reboot. what does /usepmtimer do? I google'd and found lots of references but little explanation...
    Q9650 @ 4.3ghz
    8GB HyperX 5-5-5-15
    Win7 x64 RTM
    Xtreme Cruncher
    Nov 2003
    MD, USA
    Make sure you install that fix...
    Dec 2005
    Italy - nVeice
    wrong thread sorry
    Apr 2006
    Great timing on this thread. My bosses X2 system at work has the same issue and I had no idea how to fix it.
    c[_]
    Nov 2002
    Alberta, Canada
    stickied right at the top of this forum.
    All along the watchtower the watchmen watch the eternal return.
    Jun 2003
    Norway
    I had the problem.. also in Counter-strike I got speedhack. Emptyed a full M4A1 clip in 2sec .. suddenly I was having a blast using the para
    One more bug I had, was that when I started quickpar, winamp and mIRC would hang until it was finished. All other programs ran just fine.
    I installed the patches and followed the guide here on XS. Still the same bugs. Then... after a few weeks, when I had gotten used to the bugs or gone around them with set affinity, suddenly everything was working the way it should.
