XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 02-16-2006, 02:46 AM   #1
windwithme
windwithme's Avatar
OC King of Multi-media integrated motherboard - DFI RS482 Infinity
All-in-one motherboards are always ordinary - Cheaper, Limited extended ability, and Normal performance.
February, DFI launched RS482 Infinity, which is ATI RS482+SB450 chipset in
AMD939 platform.
New INFINITY packing, very shining.
Accessories
This is a board for multi-media demand.
It owns ATI SurroundView for 4 monitors display as you have an extra ATI VGA card. It also bundles the multimedia cables.
The board is u-ATX. However, the upgradeability and features are very complete.
Besides built-in ATI X300 GPU, it has 1 PCI-E 16X for external VGA card, GbE LAN, 7.1 audio and 2 PCIs.
4 SATA devices.
Both chips have heat-sink. That’s quite and temperature is under 40 ℃
IDE and memory slots
Around the CPU, most caps are Japanese made. The components are discrete level.
Some parts are OST caps. Anyway, the OST quality is acceptable.
IO part is another great design.
Except X300 GPU, it also has DVI-D!
Left side has S-Viedo which supports HDTV as well and S/PDIF
User’s manual is always the weakness of DFI.
Recently, from DFI RDX200/EXPERT to Vensu/RX482, DFI increase the user manuals’ content.
The Legend...Collecting 7 colors crystal cats, miracle will happen!!!
Just as expected...Miracle happened...DFI OC blood makes everyone eye-opening.
All-in-one motherboard reached DDR600 1T in Pi 1M!!!!!
I cannot believe in 2006, most impressive product of windwithme is this
all-in-one motherboard.
I am shocked...
It can beat other brands discrete hi-end boards.
It is quite close to DFI own LANParty series.
Other test is coming soon.
I will unmask the BIOS OC options, built-in X300 performance in 3DMark
I won’t be long...........
RS482 BIOS Introduction
After checking these OC items, you will not believe this is the BIOS for All in one motherboard
Main OC Interface
Under main OC Interface
CPU Ratio Items
HT Items
FSB 200~400. The range is quite wide and you can reach it
CPU Voltage 0.800V~1.850V
DRAM Voltage 2.5~3.2V
DRAM divided frequency options are vary. If your memory is not good enough, you
can OC your CPU to FSB 300 and your memory in DDR400
More DRAM options are the winning weapons for DFI to beat the others
So many DRAMD tunning, there are only DFI own LanParty series and MSI recent Diamond PLUS can compete.
Built-in ATI X300 can share 32/64/128MB main memory
BIOS hardware control interface has very friendly intelligent monitors.
Performance Test
Configuration
AMD 939 Opteron 146
DFI RS482 Infinity
GSkill 1GBFF/2GBHZ
ELSA 6600GT / built–in X300
MAXTOR 30GB 5400 rpm
Enlight 420W
Reached 2GBHZ DDR580 1T
This HZ pair can only reach DDR530~550 in others nF4 mainstream or middle-high boards
Built-in VGA test. Core speed 300Mhz and memory speed in200Mhz(DDR400) ; share 64MB main memory
3DMARK2001SE
3DMARK2003
6600GT performance
3DMARK2003
3DMARK2005
Collect 7 colors crystal cats again..... Miracle comes again...
2GB DDR600 1T enter to Windows!!!
Just spend NTD 3300.
Good
1.Great Packing and Plenty Accessories
2.Components usage is very good
3.Great extended ability – 4 SATA, 2 PCI, 1 PCI-E 16X
4.Wonderful multimedia features. 8 channel audio with S/PDIF. Add one more ATI VGA card can reach 4 monitors.
5.Even good performance in add-on VGA cards
6.BIOS OC tuning features are rich. It can reach CPU 300FSB and sync with memory. The OC ability is close to top level OC motherboards.
7.Built-in X300 display core. This is the top built-in VGA in K8 platform (X300SE market price is over 1500NTD..)
Bad
1. No SATAII (This is the ATI’s problem)
As per this motherboard’s price, the features are cannot be beaten.
It includes OC, silent, multimedia and cheap.
This is perfect board for DIY users. Windwithme is glad to recommend RS482
Infinity to all of you.
windwithme is offline   Reply With Quote
Old 02-16-2006, 02:58 AM   #2
jrw
Send a message via MSN to jrw
OMFG.
Bring us more!
What's max HTT?
jrw is offline   Reply With Quote
Old 02-16-2006, 03:01 AM   #3
dogsx2
I am shocked...
I'm shocked too, very Xtreme?
dogsx2 is offline   Reply With Quote
Old 02-16-2006, 03:03 AM   #4
Vapor
Back to watercooling
Vapor's Avatar
OMFG....how much? This would be great for dedicated crunchers with an X2 or dual core Opty!
Vapor is offline   Reply With Quote
Old 02-16-2006, 03:13 AM   #5
perkam
Live Long And Overclock
perkam's Avatar
Send a message via MSN to perkam Send a message via Yahoo to perkam
This should be pretty cheap...less than $150 for sure.
Perkam
perkam is offline   Reply With Quote
Old 02-16-2006, 03:18 AM   #6
FragTek
Banned
FragTek's Avatar
Send a message via ICQ to FragTek Send a message via AIM to FragTek Send a message via MSN to FragTek Send a message via Yahoo to FragTek
Wow... Now that's a sweet board for the price. Wonder when we will start seeing them in the states?
FragTek is offline   Reply With Quote
Old 02-16-2006, 03:32 AM   #7
gundamit
gundamit's Avatar
Shamino OC'ed the onboard video in his VR-Zone review. Can you confirm the 83% OC he saw. Might be okay for some games at 640x480. He also saw 320HTT. Not bad for a HTPC board.
__________________
Bench rig now in constant change, with scraps thrown to my game rig. 2x8800GTX + e8400 = 29K 3DMark05
gundamit is offline   Reply With Quote
Old 02-16-2006, 03:37 AM   #8
RichUK
Wow look at the battery holder.
Nice board.
RichUK is offline   Reply With Quote
Old 02-16-2006, 04:16 AM   #9
Mr. Tinker
Mr. Tinker's Avatar
This board has been looking pretty good since the VR-Zone review. I wish I had $ to build a new HTPC right now.
__________________
ebay under aws983s, heatware under Mr. Tinker.
Mr. Tinker is offline   Reply With Quote
Old 02-16-2006, 09:41 AM   #10
DaWaN
DaWaN's Avatar
Send a message via MSN to DaWaN
Seems to be a great value board, better than all Asus board that have 1T problems.....
But the Red pcb color makes it looks like a MSI
__________________
My Rig:
Intel Core 2 Duo E6400
2x512mb Micron PC3200 OEM D9DQW "Fatbody"
Biostar TForce P965 Deluxe
MSI/Medion GeForce 6700XL (Cheap )
Chieftec 360W (in search for someting better)
WD 160GB S-ATA
DaWaN is offline   Reply With Quote
Old 02-16-2006, 09:48 AM   #11
Ychocky
Very cool m-atx board, I love the dual monitor outputs.
I wish board makers would mount the CMOS like it's mounted here. Great space saver.
Ychocky is offline   Reply With Quote
Old 02-16-2006, 12:05 PM   #12
althes
Xtreme Mentor
Thats a very nice board
__________________
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
althes is offline   Reply With Quote
Old 02-16-2006, 04:28 PM   #13
dimasdw
dimasdw's Avatar
Send a message via MSN to dimasdw Send a message via Yahoo to dimasdw
wow a OCable Micro ATX Board...
__________________
dimasdw is offline   Reply With Quote
Old 02-16-2006, 05:34 PM   #14
soundx98
soundx98's Avatar
Send a message via MSN to soundx98
,Wow look at the battery holder.
Very Nice Touch
__________________
soundx98 is offline   Reply With Quote
Old 02-17-2006, 07:16 AM   #15
windwithme
windwithme's Avatar
Main OC Interface
CPU Ratio Items
HT Items
Performance Test
Configuration
AMD 939 Opteron 146
DFI RS482 Infinity
GSkill 1GBFF/2GBHZ
Enlight 420W
3DMARK2001SE
3DMARK2003
6600GT performance
3DMARK2003
3DMARK2005
Good
Bad
Old 02-17-2006, 07:27 AM   #16
Phantasia
Phantasia's Avatar
Excelent review!
__________________
ASrock 939Dual-Sata2
AMD 3700+ AC by XP90/Vantec Tornado
512*2 DDR 400 V-Data 2-2-2-6
Gecube 9000pro 256Mb
160gb Seagate IDE
80gb Seagate IDE
Powered by Enermax Liberty 400w
Phantasia is offline   Reply With Quote
Old 02-17-2006, 08:05 AM   #17
Golias
Golias's Avatar
It's going to be (if everything is confirmed) the Micro-ATX board to get.
Nevertheless the Biostar 6100-939 is also a great board, i have taken it to 315 but at 2T. If this DFI is able to get to 320 or even 300 at 1T i'm switching boards.
The non SATA 2 support is bad, given the new HDD's that are coming out.
Now the absolute m-atx board would have the SB600 southbridge chipset and a better placement of components (like the Biostar), that ATX cable is going to be awfull for most m-atx cases, like Q-pack and the Silverstone Sugo SG01. All this and 300 with 1T mem support.
__________________
Silverstone Sugo SG01B
Biostar TForce 6100-939 (Bios A12)
Opteron 148 (CAB2E BPMW)
Saphire X800 GTO2 @ X850 XT
Gskill 4800 FF (1 of only 50 in the World)
Geil One TCCD (Max: Testing)
Geil Ultra-X PC3200 (Max: 287 2.5-4-4-8 2T @2.75v)
Enermax Liberty 500W
TFT HP 2035 20"
Golias is offline   Reply With Quote
Old 02-17-2006, 08:28 AM   #18
althes
Xtreme Mentor
I like it very much
__________________
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
Old 02-17-2006, 03:14 PM   #19
Frodin
I am Xtreme
Looks like a solid semi-budget mobo with a solid chipset (I can fully live with the low USB performance of the SB450) and a very good bios. Now I just need to know if it will run with a 20- pin PSU...
__________________
Obsolescence be thy name
Frodin is offline   Reply With Quote
Old 02-18-2006, 01:38 AM   #20
Phantasia
Phantasia's Avatar
Is there any problem in using an micro ATX board on a normal computer? On a ATX case?
__________________
160gb Seagate IDE
80gb Seagate IDE
Old 02-18-2006, 06:00 AM   #21
amrgb
amrgb's Avatar
Of course not. All (that I know of) ATX cases can mount a mATX board. Actually, right now I'm thinking the same as you
PS: cumprimentos para Portugal
__________________
Originally Posted by krille
Ouchy, go die please, thanks.
amrgb is offline   Reply With Quote
Old 02-18-2006, 06:23 AM   #22
killzone
killzone's Avatar
Send a message via AIM to killzone Send a message via MSN to killzone Send a message via Yahoo to killzone
hows the usb working on this board?? still crappy and if so think this will ever be fixed, to totally honest im not reall sure what the problem is. is it just slow to transfer data or will it efect your key board and mouse, if its a slow data transfer problem only i think i can live with it
killzone is offline   Reply With Quote
Old 02-18-2006, 08:14 AM   #23
-aDaM^
Banned
neato
-aDaM^ is offline   Reply With Quote
Old 02-18-2006, 08:21 AM   #24
Frodin
I am Xtreme
It has a comparably slow data transfer rate through USB, check this review of the DFI UT RDX200 that also has the SB450 southbridgehttp://www.anandtech.com/mb/showdoc.aspx?i=2572&p=11 and it lacks SATA2. I can't see how the comparably slow transfer rate could affect mouse/keyboard performance. It's good enough for me, I don't transfer alot of data through USB.
__________________
Old 02-18-2006, 08:26 AM   #25
Frodin
I am Xtreme
By the way, windwithme, is your Enlight 420w PSU 20- or 24- pin? Perhaps it's this one? http://www.bigbruin.com/html/enlight...upply_revi.htm
I couldn't find it at the enlight website.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
