Well I was doing little bit experiments otherwise I am completely stable at 10x250 vcore:1.595 / vdimm:2.6.
What I did last night is try to use vdimm: 2.5 rather than 2.6. Here is the screen shot after 11 complete passes (almost 7 hours):
Do you think it is a "random" error? Error in test #6 in pass 3, and after that 8 more complete passes with no errors - puzzled definitely...
I left my machine for a 9-hour prime marathon - I will check it out later tonight. In the meantime, I would appreciate any comments...
BTW:
@g.skill technician: If you have some settings that is 260+ (prime stable) can you post some of them here.
__________________
Lanparty nf4 Ultra-d / Bios 5-10 fix1
X2 3800 CCBWE 0532 MPMW/SI-120 with 120mm thunderblade
2x1024 G.Skill HZ (UCCC) PC-4000
Sapphire X800 GTO^2 (bios flashed & 4 pipes unlocked - 495/1080)
SB Audigy2
WDD cavier - ide 160gb
Lite-on sohc5232K
OCZ modstream 450w
