Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Settings Databse: 2GB G.Skill HZ (Please Contribute!)
    Oct 2005
    Post Settings Databse: 2GB G.Skill HZ (Please Contribute!)
    There have been many threads with this information posted all over this forum. The goal of this thread is to combine all of the stable settings in to one easy to follow Excel file. I think this will make it easy for us to not only troubleshoot our memory, but to find trends that result in better overclocks!
    Product Link: F1-4000USU2-2GBHZ
    Your memory must be 32M SUPER PI stable and running at settings other than stock!
    Please contribute the following:
    1. A64 Screenshot
    2. CPU-Z Screenshot (Showing Memory)
    3. Voltage
    4. ACTUALTref Value (3684 instead of 100 * 3.9)
    5. ACTUAL Drive strengths... (8/3, 8/2, 8/1, 7/3, 7/2...)
    As always, screen shots of A64 Tweaker and Bios configurations will be helpful! I will update the database as often as possible.
    Please also list your motherboard and bios!
    NOTE: You can now use the tabs at the bottom of Excel to find the minmum, average, maximum and weighted averages of all the settings in the database! That is, you can find the weighted average of each setting- so someone's stable settings at 300 Mhz will have counted more than someone's stable settings at 270 Mhz!
    UPDATED 2/17/06!
    Slight revisions with TONS of NEW FEATURES!
    Attached Files Attached Files
    Bandwidth Freak
    Dec 2003
    Not really special, but rock stable and freaking low voltage
    - Venice 3000+
    - DFI NF4 Ultra-D (BIOS 623-3)
    VOLTAGE 2.57v (MBM)
    SPEED 280MHz
    CPC 1
    TRC 7
    TCL 3
    TRCD 4
    TRAS 8
    TRP 4
    TRFC 14
    TRRD 2
    TWR 2
    TWTR 2
    TRTW 3
    TREF 100MHz 1.95us
    SKEK CONTROL off
    SKEW VALUE 0
    DRIVE STRENGTH 7
    DATA STRENGTH 2
    DRAM Response Time normal
    Max Async Latency 8ns
    Read Preamble Time 5ns
    Dynamic Counter enable
    Oct 2005
    Thanks! Updated!
    XS_THE_MACHINE
    Jul 2005
    Exton, PA
    Good idea, I should have mine tomorrow and hopefully game stable at near max speed by the next day
    Rig #1 | Opteron 165 (2898 @ 1.35v) | DFI nF4 Ultra-D | GSkill ZX 2x1GB | HIS X1900XT 512MB | Seasonic S12 550w in Antec P160
    http://www.last.fm/user/repoman0/
    Oct 2005
    Great Idea...is it possible to get a thread like this for 1gbff series? I cannot find much on specific settings for my ram, and tried the settings from the ddr600 thread. As soon as I think im stable I'll get an error somewhere.
    Oct 2005
    Its difficult because even if you have the same chips, all ram is essentially different. I think if we can get enough data collected we can start to compile it and see what we can find.
    Oct 2005
    True, my old pc2700 512 chip works fine with optimized defaults, and gskill 2x512 will cause errors. But passed over 8hrs of memtest in windows and dos with 300*8, 1:1 1T. Trying it again, with lower vcore and settings from the gskill site. Maybe the cpu was too hot with gaming, but cpu temp wasnt above 40 degrees, unless the gauge is way off.
    Feb 2006
    Toronto, Ontario and USA
    here are the BIOS settings im using:
    DRAM FREQUENCY SET: 200 (1:1)
    COMMAND PER CLOCK: ENABLE (1T)
    CAS: 3
    TRCD: 4
    TRAS: 8
    TRP: 4
    TRC: 7
    TRFC: 13
    TRRD: 2
    TER: 2
    TWTR: 2
    TRWT: 3
    TREF: 3684
    TWCL: 1
    DRAM BANK INTERLEAVE: ENABLE
    DQS SKEW CONTROL: AUTO
    DQS SKEW VALUE: 0
    DRAM DRIVE STRENGTH: 8
    DARM DATE DRIVE STRENGTH: 3
    MAX ASYNC LATENCY: 8NS
    DARM RESPONSE: NORMAL
    READ PREAMBLE TIME: 5NS
    IDLECYCLE LIMIT: 256
    DYNAMIC COUNTER: ENABLE
    R/W QUEUE BYPASS:16
    BYPASS MAX: 7
    32 BYTE GRANULARITY: DISABLE
    its prime stable and everything @ 262 MHz (2.6v). im running 262x11 right now. just about FX-57 speeds
    Intel Q6600 G0
    DFI LANPARTY DK P35-T2RS
    4gb GSkill PC8000 PQ
    XFX 7800GT 256mb
    320gb Seagate SATA
    2x 750gb WD SATA
    NEC 3550a DVD-RW
    Toshiba DVD-ROM
    Dell 2005fpw Ultrasharp
    TT Big Typhoon + Silverstone FM121 120mm
    Antec Super Lan Boy
    Oct 2005
    Going to update this tonight, fix some typos and make a few extra notes. Stay tuned!
    Xtreme Mentor
    Aug 2005
    Boston, MA, USA
    Note that for the shot below I had to have the modules in the right order, one module is weaker and needs to be closer to the CPU.
    I should test what each module is doing someday...
    I didn't do superpi, but the prime in the background is running for hours.
    Motherboard DFI SLI-DR, BIOS 623-3.
    I gained these setting by not using DFI's autodetection, but by working from my TCCD settings.
    I didn't record which CPU I used, sorry.
    Oct 2005
    Quote Originally Posted by blazin-asian
    i will post pics of my BIOS when i get back from work.
    EDIT: sorry, i'll post them sometime next week. i have a lot of schoolwork due on monday
    Speed / Voltage?
    32m Stable?
    XS_THE_MACHINE
    Jul 2005
    Exton, PA
    I think everyone should post their actual TREF and drive/data strength as well..
    Oct 2005
    UPDATED 2/16/06!
    I've made it very easy to contribute settings instead of having to list out a bunch of values. I will no longer be collecting data from other threads, in order to be listed you will have to make a post with the necessary criteria.
    All users listed in the database at this time have been sent a private message and asked to verify thier settings and provide any missing information.
    I have also restructured the database slightly and fixed minor typos and errors.
    Dec 2005
    Before this database gets too big, could you PLEASE go back and add the type of motherboard and cpu to each listing?
    I'm really struggling to get mine stable above 270, and every set of settings is always unique to the mobo/RAM combo, so adding those fields would be MUCH appreciated.
    Also, the data/drive strength settings really need to be spelled out numerically, or perhaps even "AUTO"...
    Thanks for putting this together! hopefully I'll be able to contribute if I can ever get mine to run a single damn memtest without errors above 270! lol...
    - palehorse -
    CASE: Antec Three Hundred Two
    CPU: Intel Ivy Bridge i5-3570K (OC'd to 4.2)
    GPU: (2) Powercoler HD7870 Myst 2GB (Tahiti) in Crossfire! (OC'd to 1100/1550)
    SSD: Samsung 840 Series 250GB
    MOBO: Asrock Z77 Extreme4 ATX
    RAM: Crucial 2x8GB Ballistix Sport (OC'd to 1866)
    PSU: Corsair TX750M
    COOLING: Cooler Master Hyper212 EVO
    G.Skill USA Tech
    Sep 2005
    mine is a bit wrong
    i use DDS 7 and DDDS 3
    also my MAL is 8ns, Read is 5NS
    thx
    also tomorrow i will random pick 5 pairs for 300 pair of 0602week and test the max, this is the best info for you guys! and i guarantee those are no going to be handpick kits
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    XS_THE_MACHINE
    Jul 2005
    Exton, PA
    Here's mine.. max of these sticks are 258-259 Fortunately they at least hold 3-4-3-8 timings up to the max...
    Actual TREF is 3684 and Drive/data are 7/1.
    Maybe I'll take the heatspreaders off
  18. #18
    Dec 2003
    Denmark
    Quote Originally Posted by G.S Technician
    mine is a bit wrong
    thx
    Well, I hope you mean this...
    Also, could be interesting to see your findings on those 14 pairs you went through before posting the great OC results on the 15th pair....that is if you saved that info...?
    Q6600 G0
    ASUS Maximus Formula (non-SE) rev 1.03G (BIOS 0907)
    4 X 2 GB G.Skill F2-8000CL5D-4GBPQ
    Inno3D 7800GT
    Seasonic 600W PSU
    WC: Laing DCC Ultra -> Alphacool Nexxos XP > EK-NB S-MAX -> BlackIceII -> Alphacool NexXxoS NVXP- -> EK NB/SB ASUS 3 -> ThermoChill PA120.3 -> Bay-Res
  19. #19
    -100C Club
    Oct 2005
    Essex UK
    First Up these Sticks was looking very BAD at first.
    I had trouble even getting 260Mhz Stable and 270Mhz wouldnt even post with all others settings posted here so.
    Now i have them Stable at 268Mhz 3-4-4-8
    DFI Expert/Opty 146 CABYE @ 2.95Ghz
    TREF is 3684
    Drive/data are 7/1.
    Also Note these sticks needed 2.64v (MBM5 Reading) To do anythink. Trwt must be at 3 to even post.
    Im currently testing 3-4-3-8 270Mhz ok So post more latter.
  20. #20
    -100C Club
    Oct 2005
    Essex UK
    Ok update results
    I played with the timmings and increased the Vdimm to 2.67v as this was required to hit 3-4-3-6 270Mhz. Also tho any more of an increase resulted in SUPER PI 32mb fail.
    I managed to tighten some other values and still keep 32MB pass. Im looping 3Dmark now for Game test.
  21. #21
    Oct 2005
    Quote Originally Posted by 4Qman
    Ok update results
    Which bios / mobo are you using?
  22. #22
    -100C Club
    Oct 2005
    Essex UK
    DFI Expert 12/7
    146 2.92Ghz
    Vdimm (MBM5) 2.53v
    TREF is 3684
    Drive/data are 7/1.
    These Sticks looked to be a complete disaster from the word go. I had soo much trouble to even get them to hit 260Mhz 3-4-4-8.
    Well ive now got some wicked results and they are really starting to shine compared to what they was.
    They Pass Super PI 32mb and Im still Priming
  23. #23
    Feb 2006
    just updated my results. check post #8.
    im still tweaking so i'll post some updates later.
    Intel Q6600 G0
    XFX 7800GT 256mb
    320gb Seagate SATA
    2x 750gb WD SATA
    NEC 3550a DVD-RW
    Toshiba DVD-ROM
    Antec Super Lan Boy
  24. #24
    Oct 2005
    UPDATED 2/17/06!
    CHECK OUT THE NEW TABS!!
  25. #25
    Dec 2005
    no offense, and I REALLY appreciate your efforts, but the entire DB is still pretty useless without the motherboard listed... or is it there somewhere and I'm just blind?
    - palehorse -
    PSU: Corsair TX750M
