Been testing the board all weekend.
There is alot of space for all type coolers.
No more serial ports, its using the same type of heatpipe cooling as the asus an32-sli. It gets fairly hot. Going to have to put a fan on it it reaches about 68c
up to 1.8vcore, 3.2vdimm, nb volts have 2 settings on up to 1.4 the other up to 2.0.
They are alot of options in the bios for the ram.
The bad thing is it keeps resetting to cas 3 when using bh5 on every reboot.
If you use cas 2.5 then it will stay at every reboot.
Using a 3700+ and some ocz 3200vx I was able to 11*260 stable using 1.6v and a 166divider for the ram at 2/2/2/5
I was able to get some 2*512 crucial ballistix at 265 235/3/3/8 stable at 265 1:1 using 10*265 had to lower the multiplier.
Going to get an opteron this week and give it a go.
Also get some gskill.
Re those TMZ and KzG capacitors any good.
When running I kept the LDT at 600 for stability.
The board definitely needs another bios to solve the bh5/utt factor.
ABit has that +/- 10-60 mv for the vdimm I guess its for stability because it doesnt raise the vdimm past 3.2v.
