Results 1 to 20 of 20
Thread: My first DICE Container.
    Xtreme 3D Team
    Jan 2006
    Canada
    Just got my dry ice container from the machine shop. The shop did a nice job I think anyway, dimensions are perfect and I am happy.
    Anyway heres a pic of it, its kinda dark but I will get better pictures later on. I am at work now so I cant do much.
    I am a complete nob on extreme cooling as this is my first dry ice container and will be the first time I play with dry ice or any sub zero cooling for that matter. So please be kind and any tips would be appriciated!
    ln2nl
    Jun 2004
    The Netherlands
    Nice man! but for an accurate thermal sight.. place the probe in the base!
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Xtreme 3D Team
    Jan 2006
    Canada
    Quote Originally Posted by Waus-mod
    You mean drill hole in the base to place the probe orrr just drop the probe in the container so it sits at the bottom of the container where the dry ice would be??
    Apr 2004
    Helsinki / Finland
    Nice, any pics of bottom inside?
    Wall/bottom thickness?
    Temp probe allways outside container, so close CPU's IHS as possible
    - Team Skootterit
    - SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
    Jan 2003
    Manchester, Uk
    Yeah any internal pics would be nice.
    Yeah drill a hole into the base
    Pentium M database:
    http://www.wwwwwoc.net/db1.htm
    Quote Originally Posted by MTP04
    Nice. The design is good. ABout the probe, drill a small hole big enough for probe to completely fit in THE SIDE of the lowermost button on the base. Glue the probe in there with some artic silver adhesive. This will give you good base temp readings. Then, wrap with some electrical tape to secure the probe cord around the base in case it gets jerked (it will
    Good luck with your benching
    Xtreme 3D Team
    Jan 2006
    Canada
    Quote Originally Posted by Dani
    Wall thickness is about 5mm and base is 7mm. I dont have any pics of the inside base but it is flat, no design there.
    Quote Originally Posted by k|ngp|n
    Thanks for the detailed description of mounting the probe correctly, I will get to it next time I am at the machine shop.
    Xtreme 3D Team
    Jan 2006
    Canada
    Here's a picture of it mounted on a 4600+. I will have some results later this week.
    Champion
    Jun 2003
    cape town
    cool. another 4600+ under some ice.
    is that an ldbhe stepping or something?
    Xtreme 3D Team
    Jan 2006
    Canada
    Quote Originally Posted by flytek
    Nope, its a CDBHE.
    Xtreme 3D Team
    Jan 2006
    Canada
    Got to test my dry ice container last night and today after work. I am very pleased with it so far. Here are some results with a X2 4600+ cpu. It didint seem to have a cold bug , atleast up to -51 in the bios and -52 windows is the lowest I saw and ran without problems with HTT at 320x3.
    My highest so far,
    http://valid.x86-secret.com/show_oc.php?id=70817
    Will have more results during the weekend. Anyone have any tips for Bios settings to push my CPU even further??
    Stock settings @ 1.12 VCORE
    3Ghz @ Stock VCORE
    I know these arent fast times but thought i'd show it.
    Champion
    Jun 2003
    cape town
    excellent. no cold bug!
    i read a trick that can get you another
    10-15 degrees temp reduction
    if you try ether as the alchohol you should see a further drop.
    beware you must have very good ventilation as ether is bad for your brain
    and how about some 3d benchies?
    Xtreme 3D Team
    Jan 2006
    Canada
    I did a quick read on ether from google this stuff is nasty, I dont think i'll be trying it but thanks for the tip.
    If all goes well with my GPU container I will have some 3D benchies later during the weekend.
    Beautiful job my man. COntainer, insulation, and mounting all look fantastic. If your cpu can take those temps, I bet you will be going to 3450+ when you max it out.
    Mar 2005
    Barcelona
    What's killing your scores? SP 1M should be slower at 3.3Ghz...
    Maybe memory?
    Intel Core 2 Quad Q6600
    GSkill F2-8000CL DDR2-1000 2x2GB
    Abit IP35 Pro
    XFX NVidia GeForce 6800GT @ 435/1210Mhz
    2x WD Raptor 36GB RAID 0
    Antec TruePower Quattro 1000w
    Windows Vista Ultimate x64
    Xtreme 3D Team
    Jan 2006
    Canada
    Thanks k|ngp|n! Any tips on bios tweaking to get my cpu higher?
    Maybe memory?
    These runs were solly to see how the cpu runs, the memory was on a divider. Just trying to get it all figuerd out before I get to 3d benchies.
    Dec 2005
    Chillicothe, Ohio
    nice pot and I can't wait to see those 3d benches
  18. #18
    Jan 2006
    Quote Originally Posted by PoL
    Maybe memory?
    Perhaps try lowering the multiplier and increasing FSB? (This is if you want better PI 1M scores..)
    x6.wickeD
  19. #19
    ln2nl
    Jun 2004
    The Netherlands
    Well with coldbugged chips that aint gonna hapen. Higher multi and lower fsb.
    *EDITed by IFMU*
    Forum Policies
  20. #20
    Apr 2005
    Calgary, AB
    Pot looks good MTP04
    MB Reviewer for HWC
    Team OCX Bench Team
