Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: G.Skill 2GBHZ with DFI Expert mobo Testing
    G.Skill USA Tech
    Sep 2005
    I know many people has some problem with DFI Expert mobo. i discussed with Oskar Wu many time about this also, but no idea....
    finally yesterday night i spend few hrs to tweak around with my new expert mobo (the 2nd batch, not the 1st batch with "cut" around sound output area).
    at first i cleared its bios and plug the 2GBHZ. it refuse to boot into bios. it freeze on DFI logo screen. then i took out one of the stick and only left one on the mobo. it boot into bios no problem. after i finished the bios seting i turn off computer and plug another one. it boots fine no problem. cleared bios and boot dual channel again... freeze. btw my bios is 1207
    ok the bios Data level is set on 3(1~15) and 1(1~4), different CPU mobo might need different level. the way i tested out is using FSB310 DDR620 with 1GBFF 2.6v 32M. since expert board is hard to go over 310 this is the great way to find the best level for me. from 1-1, 1-2, 1-3, 1-4, 2-1.... to 8-4; many level i can not even boot into windows but for 3-1 i could do 32M to loop 8. that is why i think 3-1 is the best for me.
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    G.Skill USA Tech
    Sep 2005
    DDR500 testing in expert board!
    although i knew UCCC only need little voltage to run but..... this low???
    G.Skill USA Tech
    Sep 2005
    below is overclock testing and overclock is not guarantee
    DDR520
    DDR540
    DDR560
    DDR580
    those timing is set on bios, i didn't use A64 to change any timing
    G.Skill USA Tech
    Sep 2005
    Conclusion
    expert mobo is different than ultra-D mobo
    the timing for ultra-D is very hard to run twtr 1 and trtw 2. normally we use twtr 2 and trtw 3.
    but on expert mobo, twtr 1 and trtw 2 is working fine... and if lower twtr 1 to 2, system becomes unstable and BSOD sometime the only thing to help system stable is lower trtw to 3.
    also, singel channel for 1st boot after clear bios is needed. once bios been set, dual channel is ok. (at lease in my case)
    finally! UCCC is cool for low voltage......
    also! this kit's SN# starts 06010510
    Feb 2005
    USA
    290 @2.4v....holy moly!! nice finding...I'll received my HZ tomorrow, can't wait!!
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    G.Skill USA Tech
    Sep 2005
    Quote Originally Posted by ben805
    try DDR500 low voltage 1st, increase slowly
    Dec 2004
    Hampshire, England
    sick results
    These go even higher with higher vdimm?
    Thanks for the info
    G.Skill USA Tech
    Sep 2005
    Quote Originally Posted by shuRe
    sick results
    Thanks for the info
    i try up to 2.7 but still not 300 stable! maybr max out at 295 i think
    Nov 2005
    Monza [Italy]
    WTF....only 2,4v for 290Mhz ....
    [ASUS p5b deluxe @801][Allendale E6400 @ 1.51v 420x8]
    [ x1800xt 256 1.2ns ][teamgroup pc6400 ddr840 4-4-4-10 2.25v]
    [liquidcooled by Ybris-cooling][ Antec TC 2.0 550w ][centurion 530 mod + noise isolator black]
    Feb 2005
    USA
    G.S Technician
    For Ultra-D, what bios, tref, and dram drive/data strength do you recommend? thanks.
    Xtreme X.I.P.
    Dec 2005
    it is good to see the G.S guys on here.
    My next pair is definitely going to be those G.Skills!
    I also heard you guys have excellent RMA process. I look foward to testing and using your product.
    Sep 2004
    Quote Originally Posted by irev210
    It was a bit shifty there for awhile but i'm sure it is better now.
    Thanks for the testing my next board will be the expert.
    Core i7 920 @
    MSI X58 Eclipse SLI
    6GB Mushkin Blackline
    GTX295
    Xtreme X.I.P.
    Dec 2003
    290MHz and only 2.4v is sweet! I remember using 2.5v with kit I have here, on Ultra-D and it worked great up to almost 290MHz. I wonder if it's Expert/HZ combo that work so great or maybe Ultra-D could also pull this off... But as far as I recall, Ultra-D doesn't have 2.4vdimm option...
    G.Skill USA Tech
    Sep 2005
    G.S Technician
    for ultra-d i use 7 (1~8) 3 (1~4)
    tref is 3684
    i hope this will help you
    Aug 2004
    OR, USA
    G.S Technician, Is 3684 the tref value you were using on the expert as well?
    DFI Expert @ 11*270
    Opteron 148
    2 x 1Gb OCZ Gold pc4000
    2x36Gb Raptors in raid
    nec 3540a
    x1800xt
    Viewsonic vp201s
    X-Fi and Logitech Z-5300
    Logitech mx-518 and Logitech Elite keyboard
    Antec P160W and Vapochill LS
    PPC 510 ASL
    G.Skill USA Tech
    Sep 2005
    Quote Originally Posted by neon26
    yes
    Xtreme Enthusiast Celcius's Avatar
    Dec 2004
    Texas
    Nice results man. I've got HZ on an Ultra-D and your products don't disappoint.
  18. #18
    Dec 2005
    ben, since u ar using the sam board (a8n32), could you post the resualts with this gskill's. i'm in the process of buying this kit, but i heard that asus is having some incompatibility issues with UCCC chips, and that this kit is not capable of runnig even at rated speed - 250MHz..please lemme know
  19. #19
    Mar 2005
    Mumbai, India
    Gr8 to see some official demo/help to get those 2 GB going on Expert. Nice clocks for sure at those volts. May be I am getting those then.
  20. #20
    Nov 2005
    Italy
    fine!
    i'm trying (without troubles) a pair of GBHz on my Expert mobo @250Mhz 1:1 3-4-4-8 @ 2.6v.
    i'm running my system without hdds and readers, so i can test only with memtest86+!
    now i hope to see how my memories work @2.4v!
  21. #21
    Dec 2005
    EXCELLENT! our timings are identical up to 270, and I think you just solved my problem for 280-290!
    Now if I could just leave work and go try them...
    Did they pass 32M at 280 and 290? If you didnt try, could you do so and get back to us?
    Thanks again!
    - palehorse -
    CASE: Antec Three Hundred Two
    CPU: Intel Ivy Bridge i5-3570K (OC'd to 4.2)
    GPU: (2) Powercoler HD7870 Myst 2GB (Tahiti) in Crossfire! (OC'd to 1100/1550)
    SSD: Samsung 840 Series 250GB
    MOBO: Asrock Z77 Extreme4 ATX
    RAM: Crucial 2x8GB Ballistix Sport (OC'd to 1866)
    PSU: Corsair TX750M
    COOLING: Cooler Master Hyper212 EVO
  22. #22
    Dec 2005
    Can you PLEASE explain to me the logic and/or math behind using 3684 as the TREF value?
    thanks ahead of time!
    - palehorse -
    PSU: Corsair TX750M
  23. #23
    Nov 2003
    Longview, WA
    Yoo, G.S. Tech! What about the 1st batch of GB-ZX on the Expert?
    Have you tested it on the mobo yet?
    FX-57 @ 300x10...3,000 on AIR!
    DFI NF4 DR-SLI
    Gskill pc4400 1 gig
    2x6800 Ultras
    2x74gig Raptor Raid "O"
    PCP&C 510 SLI
  24. #24
    G.Skill USA Tech
    Sep 2005
    i don't know what but 3684 is my lucky number lol
    and 2GBZX on expert it about the same as ultra d
    alos i did post the 32M for 280 290
  25. #25
    Dec 2003
    Denmark
    Hmmmm, this really blows. Got my 2 GB G.Skill today, and can't get them stable above 265
    Have tried all the settings in this thread and other threads....
    I can't believe I am THIS unlucky...first I get crappy Redlines, and now crappy gSkills too
    All you so-called technicians posting you great memory overclock result on boards like these....are you just using handpicked modules after testing alot of similar type modules to get the best OC results so people like myself will go out and buy your company's products, but not get nowhere near the same results?
    I know that hardware setups differ, etc.. but it's is really frustrating to invest in a second pair of 2X1gb modules and not have them perform nowhere near what other people are reporting...
    Sorry for the tone, but it just pisses me off that I should be this unlucky
    I was debating with myself wether to go for g.Skill or Crusial, and after reading good things about g.skill and crusial modules giving up after a few months I decided to go with g.skill....and had really hoped to be able to go to the same max as my cpu (280-285) with these modules...but no
    I haven't tested each stick individually...yet...maybe one of them is worse than the other...?
    Also, how come some values will work in A64Tweaker, but pc won't boot with the same values entered in BIOS?
    Q6600 G0
    ASUS Maximus Formula (non-SE) rev 1.03G (BIOS 0907)
    4 X 2 GB G.Skill F2-8000CL5D-4GBPQ
    Inno3D 7800GT
    Seasonic 600W PSU
    WC: Laing DCC Ultra -> Alphacool Nexxos XP > EK-NB S-MAX -> BlackIceII -> Alphacool NexXxoS NVXP- -> EK NB/SB ASUS 3 -> ThermoChill PA120.3 -> Bay-Res
