Gonna make a data base so I need people on phase to post in this format. Oc's and cpu type are not needed so please just post in this fashion >>>>> Highlighting the 3rd and 4th and what temps you run at.
ONLY 90NM cpu's please. Also cpu temps not evap temps. Please dont post 0 degree core temps most cold bugged cpu's can do that easily. Also as steven pointed out these are benchable cpu's at these temps that we want posted not screenshot cpu's. *EDIT* I started adding cpu's that did bug for comparison purposes.
BC code
s7e9h3n CABCE - none
fatty CABCE -20 idle
BF code
BG code
K404 CABGE no coldbug down to -30 idle
PoL CABGE -27º
Kesnel CABGE -34c
thorlite CABGE -25 >bugged
eldonko CABGE no cold bug to -32C <-cant function under dice
BH code
El Snorro CABHE -25 cpu temp, no bug so far
Chew* LDBHE -56
Chew* LDBHE -10
Desertshooter LDBHE -32
Absolute 0 CDBHE -20
s7e9h3n AABHE - none
s7e9h3n ADBHE - none
BI code
PoL CBBID -41º
fatty CBBID -20
BL code
s7e9h3n CBBLE - none
s7e9h3n CBBLE - -90c
s7e9h3n LBBLE - couldn't test that low at the time, but ~-27C was fine
kiwi LBBLE -40C
BN code
ThorLite CABNE idle -28C, load -4C, bugged at idle temps and htt >305
Ozan Baseski CABNE - (-28°C)idle
chefnr1 CABNE -69 idle measured on side of IHS
tarrcm CABNE ice -50C idle/-24C load = BUG
DUMO CABNE -68
Ben805 CABNE -25
Kesnel CABNE -29c
BW code
DesertShooter CCBWE -30 CPU Temp
del_fuego CCBWE Works down to -26
PoL CCBWE -26º
stone_cold_Jimi CCBWE bugs below -26C and above 255 HTT.
Eldonko CCBWE no cold bug to -32C. Dice testing next week.
Ben805 CCBWE -25
Thorlite CCBWE -28
s7e9h3n ACBWE -35C
kiwi LBBWE, idle -35C, load -20C, bugged at idle temps
mr lobber CBBWE 0530TPMW, idle -45C, load -30C (coldbugs at -50)
thorlite CCBWE 0522 TPMW idles fine in windows at -27
the stilt CCBWE -35 (can't try colder?)
misteroadster CCBWE -Cold bug @ 355HT -5° cpu.
BY code
kiwi CABYE idle -27C, load -5C, bugged at idle temps and htt >325
boblemagnifique CABYE -55 max htt 270 though....
boblemagnifique CABYE -30°
tarrcm CABYE phase -30C idle/-6C load = no bug ice not tested yet
Desertshooter CABYE -25
C-Buzz CABYE -40
Kesnel CABYE -30c
thorlite CABYE -25 > bugged
B2 code
rekin CAB2E Bugged
Dogimann KAB2E Bugged
Kesnel CAB2E bugged around -10c
the stilt CAB2E Coldbugged even at -10c
funkflix CAB2E coldbugged at +14°C
K404 CAB2E Bugged at -25 idle and still bugged at -5 loaded
CJ code
Dogimann CACJE Bugged
Dynasty CACJE -10 C in bios temp > bugged
