Results 1 to 19 of 19
Thread: VDroop Mod for Asus P5LD2-Deluxe 945P
    Feb 2005
    Hi,
    is there also an VDroop outside for this Motherboard?
    Or is the Modification the same like the P5WD2?
    Thank you.
    Sincerly,
    Treepitt
    Sorry for my bad english.
    Xtreme Vmod mod
    Aug 2004
    Cornwall/Newcastle uni, UK
    Can you post a picture of the CPU area of the board please.
    Feb 2005
    Wink Pic´s
    Here are some pictures. Hope the quality is ok.
    When better quality is needed, then i will post.
    Sincerly
    treepitt
    Feb 2005
    Exclamation
    Here are more Pictures!
    Xtreme Vmod mod
    Aug 2004
    Can you tell me whats written on the chip I've circled. Could you also try to get a close up, high res photo of the chip please.
    Feb 2005
    Exclamation
    Can you post me the Picture of the chip you´ve circled?
    Thanx!
    Xtreme Vmod mod
    Aug 2004
    Sorry, I forgot to attach the picture. I've attached it to this post now
    Feb 2005
    Hi Persivore,
    so now i have the exact description of the chip:
    ADP3181
    J#0515
    654514.1
    and here the high res pic
    Quote Originally Posted by persivore
    Nov 2005
    On da battefield
    The ADP3181 is functionally similiar to the older ADP3180. I do not know if the entire pin out is exact, but I do know that the CSSUM (pin 17) and CSCOMP (pin 18) on both chips are the same...and thats whats important.
    The Vdroop can be modified by connecting a VR between pins 17 and 18 on the ADP3180/81. I do not know the value of the VR, you will need to check the resistance between these 2 pins to figure that out.
    Also, you will want to solder the VR pins to other spots on the board versus trying to solder to the actual ADP3181 IC. This is the same thing we do on the P4C800 boards. Do a "short-circuit" test on the board to find places that are directly connected to the these pins and solder there. It looks like there are plenty of solder pads available above the chip...this is very good as that makes things much easier, and avoids the risk of cross soldering (bridging) other components together during the mod.
    Dec 2004
    what happends does any one find droop mod for this MB--
    becauce I have the same problem
    Xtreme Mentor
    May 2003
    Engineering Lab - NCSU
    Quote Originally Posted by milen_bg
    The Vdroop mod is explained in the post above yours mate.
    Someone just needs to take a resistance reading to verify what value the resistance needs to be.
    I like my women the way I like my processors...naked.
    I am not the HellFire that writes bios files. I work strictly on voltage modifications.
    Feb 2005
    Okay, must i check the resistance between pins 17 and 18 on the ADP3180/81 when power is on or off?
    When i check the resistance if the power is off, then i have an resistance @ 200K at the circuit analyzer of 129 - 133K.
    When the power is on, the circuit analyzer show nothing!?
    And now ?
    Greetings @ all
    Feb 2005
    Push
    Dec 2004
    finaly I found this link
    http://www.ocforums.com/showthread.php?t=440135
    and think it will be the same mod
    but what value to put the VR
    Xtreme Vmod mod
    Aug 2004
    That mod looks ok. Try using a 50k VR and adjust it until there is no droop between load/idle. Setting the variable resistor to 28k has been found to be the best value on most boards, but it could be different on this board.
    Feb 2005
    Question
    @ persivore & Calderbrae: if i test the solution with an 50K vr could i damage the board?
    @ milen_bg: do you have test the solution?
    Xtreme Vmod mod
    Aug 2004
    Quote Originally Posted by treepeter
    When doing any mod, there is always a risk, but using a 50k VR shouldn't damage the board.
  18. #18
    Feb 2005
    Exclamation VDROOP Mod Asus P5LD2-Dlx DONE!
    So Dudes,
    i did the VDROOP-Mod with 50K VR @ 45K Ohm!
    Runs very great! The Mobo does only a very little droop!
    Thanx a lot @ all in this thread!
    Greets
  19. #19
    Jan 2007
    Denmark
    Picture of mod?
    Hey Treepeter.
    Any chance of you posting a picture of the mod?
    I have the same board, and I just bought myself some watercooling.
    I would like to test it out on the board with a pressy, and the vdroop-mod would be very helpfull to get the CPU stable.
    Thanks in advance
