Please post your results here and I will post them/edit this thread. The goal here is to make an accurate data base to compare stepping’s, so people have an idea of which are good and which are crap.
A few things before you post:
1) Post your results in this format, i.e.: CABYE 0536 GPMW - 2900 MHz - 1.452v AIR - your Username
2) Include a screen shot that clearly shows CPU speed/voltage along with proof of stability in one.
3) Please don’t post some thing that is only stable for 20 minutes, examples of acceptable test would be 32m of SuperPi, or at least 1 one hour of Prime95. If you have another test go ahead and post and it will be posted here if acceptable.
Thanks for contributing to this guys.
Opteron 144:
CABNE 0530 APMW - 3330Mhz -1.536v Vapo - dogsx2
CABNE 0540 BPMW - 2600Mhz - 1.500v H20 - don_vercetti
CABNE 0540 APMW - 2901Mhz - 1.648v H20 - perry_78
CABYE 0536 GPMW - 2906Mhz - 1.552v AIR - Fr3ak
CABYE 0540 APMW - 3100MHz - 1.568V H2O - starostise
CAB2E 0546 FPMW - 2700MHz - 1.43V AIR - 5days
Opteron 146:
CABNE 0528 APMW - 3070 Mhz - 1.500v AIR - dogsx2
CABNE 0530 APMW - 3580 Mhz - 1.712v Vapo - bachus_anonym
CABNE 0530 APMW - 3504 Mhz - 1.840v Dry Ice -afireinside
CABYE 0540 FPAW - 2800mhz - 1.400v AIR - Mindfield
CABYE 0540 APMW - 2928 Mhz - 1.488v AIR - Ozan Baseski
CABYE 0540 FPAW - 3443 Mhz - 1.778v Phase Change - ncsa
CABYE 0540 FPAW - 3100 Mhz - 1.600v H20 - dogsx2
CABYE 0540 FPBW - 3280 Mhz - 1.540v Vapo - Gufy
CABYE 0540 FPBW - 3000 Mhz - 1.550v AIR - pcfreak
CABYE 0540 FPBW - 3315 Mhz - 1.648v AIR - Dani
CABYE 0540 FPBW - 3012 MHz - 1.520v - AIR - Monge
CABYE 0540 FPMW - 3000 Mhz - 1.450v H2O - Jupiler
CABYE 0540 FPMW - 3504 Mhz - 1.712v PhaseChange - loc.0
CABYE 0540 FPMW - 3000 Mhz - 1.488v AIR - Set
CABYE 0540 FPAW - 3000 Mhz - 1.616v AIR - 4QMan
CAB2E 0540 FPMW - 2920 MHz - 1.360v AIR - 5days
CABNE 0545 BPMW - 2919 MHz - 1.550v AIR- Big.Wayne
CABNE 0545 BPMW - 2920 Mhz - 1.540v AIR - 4QMan
CAB2E 0546 FPAW - 2900 Mhz - 1.584v AIR - 003
CAB2E 0546 FPAW - 2900 Mhz - 1.584v AIR - Earthman
CAB2E 0546 GPAW - 3004 Mhz - 1.584v AIR - 865pe
CAB2E 054 6GPAW - 3020 MHz - 1.520v AIR - Monge
CABQE 0547 GPMW - 2921 Mhz - 1.40v stock cooler - Absolute_0
CACJE 0546 BPMW - 2850MHz - 1.595v Air - szukalski
Opteron 148:
CABYE 0528 GPMW - 3070 Mhz -1.552v AIR - dogxs2
CABYE 0528 GPMW - 2863 Mhz - 1.45v AIR - 4X4N
CABYE 0540 GPMW - 3150 Mhz -1.504v H20 - dogxs2
CABYE 0540 FPBW - 3133 Mhz -1.600v AIR - CRUSH-ER
CABYE 0542 FPMW - 3180 MHz - 1.65v- Water - Malph
CABYE 0543 FPMW - 3103Mhz - 1.595v Air - szukalski
CAB2E 0546 BPMW - 3005 Mhz - 1.640v H20 - Fhqwhgads6680
CAB2E 0546 PPMW - 2990 Mhz - 1.560v H20 - Eldonko
CAB2E 0547 GPMW - 3196 Mhz -1.600v H20 - Absolute_0
CAB2E O547 GPMW - 3024 Mhz - 1.552v AIR - Daveb2012
CACJE 0546 BPMW - 2940 Mhz - 1.630v AIR - AaronATX
CACJE 0546 APAW - 3008 Mhz - 1.584v AIR - Benny Lodewijk
Opteron 154:
AABCE 0522 TPMW - 3750Mhz - 1.648V Autocascade - s7e9h3n
