Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 129
Thread: Full Cover blocks
    Mar 2005
    Slovenia - EU
    Arrow Full Cover blocks
    Hi!
    I have made a few blocks, and I would like to share some pictures with you.
    7800 GT/GTX 256/512
    Prepared for SLI:
    Bottom view:
    Detail of cooling the mosfets:
    X1800 XT/XL also for X1900 series
    Prepared for Crossfire:
    X800/X850 series:
    Cooling bridge for back-side rams:
    Have attatched pictures of new version NF4 water block and other stuff.
ID:	42218   Click image for larger version.
ID:	42219   Click image for larger version.
ID:	42220   Click image for larger version.
ID:	42221   Click image for larger version.
    Oct 2005
    Good idea for v/reg cooling, I really like it! What about performance?
    Unoriginal Macho Energy
    Dec 2002
    Very nice blocks there! Those fittings, are they 1/4" BSP thread? If so, I need to get hold of some of them!
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Nov 2005
    Los Angeles, CA
    damn those blocks look incredibly nice. good job!
    Mar 2005
    Slovenia - EU
    Quote Originally Posted by nikhsub1
    Yes, thread is G1/4".
    I like them because they have integrated o-ring and are like DD said high flow fittings. The biggest hole as possible for minimum flow restriction.
    Dec 2002
    Quote Originally Posted by Eddy_EK
    OK, now where can i get some of them?
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    Eddy's website. http://www.cerkovnik.si/indexh2o_e.htm
    Eddy, we should really come up with a more effecient design for the core cooling. What are your thoughts on a high count micro channel that is not wavy?
    It would cost more to CNC, but would certainly cool, better and if done right would have a minimal increase in restriction.
    Mar 2005
    Slovenia - EU
    I am sure my desing has good cooling performance.
    The waved channels increase turbolence and cooling area.
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    would there be a brass/derlin top version? I'm allergic to plexi tops. after my last..................No Comment.
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
    Dec 2002
    Im talking about the barbs... I want the ones on the far right of this picture, looks like the oring is integrated with the barb, or is it a seperate piece? http://www.xtremesystems.org/forums/...8&d=1137097674
    May 2003
    Denmark
    Thoses blockes looks amazing!!!
    How can the GTX block be for both for the 256 and 512 version?
    DD had to make a serparate 512 block due to some changes ram pad designs...
    Anybody who knows the specific difference in mm between the 256 and 512 ram designs?
    My mate is making a block for my 512 megs but he only has a 256 megs GTX... And I'm not sending my GTX 512 in the UK mail... 30% of all letters/parcels doesn't reach it correct receiver....
    Many thanks in advance!
    /Thomas
    Feb 2005
    Denmark
    AFIK the mem modules on the 512mb version are larger, and because of that they need a larger surface area for the mem modules for the 512mb version.. It should be the only difference.. The 512MB version also works for the 256MB version..
    Playing station: DFI UT X48 T3R @ EK NB // Q6600 @ 3,2GhZ @ True (soon Dtek V1) // 280gtx (soon EK 280gtx) // 2*2GB Gskill 12800 CL7 // Corsair HX1000 // 250GB ES.2 - 160GB T166 - 2*160WD RE // Lian Li V2000B // Swiftech 240+360 - 2*DDC 1
    Servers: ASUS Crosshair // X2 3800+ // 2*1GB Gskill PC6400 HZ // R3650 // IBM workstation
    Laptop: Znote 4200, running on 5th year now
    Aug 2004
    Los Angeles, Ca USA
    Eddy, my comment might have come off a little harsh, and if it did, I'm sorry.
    While I'm sure that your design is quite effecient, there is always room for improvement, and I deffinetly see a good way to improve performance with your full cover waterblocks.
    If your not interested, thats fine, but if u are, lmk.
    Oct 2005
    Newcastle, UK
    Very nice!
    From the looks of the pictures with comparing the DD X18 block, it's quite difficult as DD's contains acute angles but not as restrictive on the core
    Is there any comparisons between your work and DD's?
    How much do they cost?
    Mar 2005
    houston TX USA
    very nice, very nice indeed, i was also going to make a suggestion, but then i realized, it me a complete waterflow annihalator
    emptiness
    Mar 2005
    Slovenia - EU
    Quote Originally Posted by MaxxxRacer
    Of corse I am interessed in approvement, but I think that high count micro channels just makes the block more expensive to make. I think that my full cover water blocks cools better than any other.
    Aug 2004
    Los Angeles, Ca USA
    It will indeed make it more expensive, but you can never bee too far ahead of the competition.
  18. #18
    Aug 2003
    FunLand
    Couldnt see them at your site yet, so any idea what the prices are ( in €'s ) for normal X1800-model ? If its not too bad ill buy one straight away... been looking for one that can use 1/2" tubes, but really hard to find those in europe ( or they are REALLLY expensive ).
    PTK
    Ps. On the SLI/Crossfire editions, shoudnt the fitting barbs on each side of the block to make the tubing bit easier to route ? Kinda like in this DD pic here... http://www.dangerdenstore.com/files/..._side_800w.jpg ? Ofc your setup allows people to use 2 different cooling circulations for both cards.
    Intel Core 2 Duo E6000 @ 3.6Ghz
    Asus P5W DH
    4x1GB PC6400 Rhino 4-4-3-9 1:1
    2x74.3GB Raptors + 300GB Maxtor 16MB
    Sapphire Radeon X1900XT 512MB
  19. #19
    Mar 2005
    Slovenia - EU
    Quote Originally Posted by PTK
    PTK
    I will update the homepage during this weekend.
    Yes, but that is just for motherboard versions with wide gap between pci express slots. And yes it is easyer to route tubing.
  20. #20
    beefin' it up!
    Dec 2004
    WPI
    Eddy, will there be a new 6800 block now? an all-copper one rather than an alumi/copper mix?
  21. #21
    Mar 2005
    Slovenia - EU
    Quote Originally Posted by Bloody_Sorcerer
    I tink (havent tried yet) that it fits on 6800 series too...
    I saw alphacool sels the same block for all 6800 and 7800 graphic cards.
  22. #22
    Mar 2005
    Slovenia - EU
    These blocks were first sample, mounted on 7800 GTX 256:
    Sapphire X800 GTO 2:
  23. #23
    XS in Sin City
    Dec 2004
    Las Vegas
    Wow, nice alternative to the blocks on the market right now for the NV stuffs...
  24. #24
    May 2005
    Italy(Mantova)
    very nice block.
    it seems to be very well designed to mount on a 7800
  25. #25
    Aug 2004
    Los Angeles, Ca USA
    I like the X800 block. dont see many of those around.
