What's the highest load temp for an Opteron you would be comfortable with, supposing that voltage is relatively low (< 1.5v)?
~50...
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
Yeah even if they're specced for higher, it's usually not good for stable clocks anyways. A to the edge overclock and 55C have not been friends on my Athlon chips. AMD's like the temps for maximum clocking. Maybe give or take a few degrees, I know some dual core and air guys are running them warmer these days.
do you have an independent probe on your opt 170 or is it a board sensor,,, not all boards give accurate temps for optys,,,, also what cooler is it and what mhz and vcore,,,
ABIT IP35 PRO
Intel Q6600 GO L737B @ 3.6ghz
G. Skill DDR2 1000 - 4 gigs
150 gig Raptor (OS)
300 gig Seagate (Storage) 500 gig Freeagent (storage)
EVGA 8800 Ultra
Ultra X3 1000 Watt
X-fi Fatal1ty FPS
Watercooled: D-Tek Fuzion MCP655 Micro Res PA 120.3
EX 8800 Full Cover Block
Dell Ultra Sharp 24" LCD
board sensorOriginally Posted by demonbane23
big typhoon
2.6GHz
stock vcore, showing as 1.344 in CPUZ
55 C load
more info here
http://www.xtremesystems.org/forums/...ad.php?t=83894
Originally Posted by Ender17
at 2.6 ghz and stock vcore 1.344 you should be under 55c load with Big Typhoon I would think,, maybe high 40's if that,,,, you can try to reseat the HS and put on some new AS5 ,,,,
also you got 2.6 ghz at stock vcore on an opt 170,, what freakish stepping is this?
ABIT IP35 PRO
150 gig Raptor (OS)
EVGA 8800 Ultra
Ultra X3 1000 Watt
X-fi Fatal1ty FPS
as long as its under 60 it shouldn't harm your cpu, although that being said I have noticed with all of my 90nm a64's that over 50 starts being unstable when ocing. I believe I read somewhere that for every 10 degrees or so it you take off it doubles the lifespan(don't quote me on that lol) but the point is...cooler = more cpu life
Heatware | Ebay:Crazymullen | If you are unsure what Fhqwhgads means You are REQUIRED to go HERE| Powered by Centon Ram
IMHO Waste is a computer going to a landfill having done actual computations less than 90% of it's life. 90% of the computers powered on right now are idle or powered off; what a waste! [/B]
Is it a coincidence that your wifes pc is called Uranus?
I would like to concur. In a cool ~25c room I get ~ 45c from my 175 with a TTBT and its stock fan when I have it oc'd to 2640 @ 1.36v BIOS/1.39v CPUZOriginally Posted by demonbane23
I have a 170 also at 2.6ghz stock volts. Mine is under an xp-120 and my load temps stay under 40c so I would say those temps are kinda high. I would expect better from a BT.
Intel Core i7 920 3841A777
DFI LP DK X58-T3eH6
6GB OCZ Platinum DDR3 1600 OCZ3P1600LV6GK
Zotac 8800GT ZT-88TES3P-FCP
PC Power & Cooling S75QB 750W
i have the same problem as you with 1.4v i get temps of 54C with a big typhoon. i think our opterons just don't have proper ihs contact
Same stepping as mine too, so much for that theory.Originally Posted by jsriolo
Can you go higher than 2.6GHz?
Alot of these Opterons are misreporting temps. Believe me. Feel the heatsink for yourself or use check it with a temp probe. 55-60C is definitely hot to the touch and your heatsink will be pretty hot if it is really running that hot.
YUP
OK, I took the side panel off and felt the HSF as best I could (P180 is super cramped). I couldn't find a spot that was even remotely hot. The heatpipes were a bit warm, but nothing uncomfortable in the least.Originally Posted by CRUSH-ER
I also noticed my temps dropped about 5 C with the side panel off.
I've never used a temp probe, how exactly do they work?
I won't dispute that, heat is the enemy. But how long to you plan to depend on the CPU you are currently using? I am looking at a drawer full of old but still functional CPUs that tell me that even if I get only half or maybe even a quarter of the usual life span of a cpu (10 years? 7?) I will probably be upgrading again before it dies, maybe even twiceOriginally Posted by Fhqwhgads6680
. I care about heat for overclocking stability but the affect on MTBF rarely crosses my mind anymore, just part of the hobby. Now businesses and typical users who look at computer spending as an investment are a whole other matter as they very well could be using the same hardware 5 years from now.
I'm going to say 50c, but it really makes no difference as the tempature readings the dual core optys report back are totally incorrect.
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
so it this a pretty widespread thing?
hadn't seen anything about it, but I haven't searched either
37C.. anything More would be unacceptable for meOriginally Posted by Ender17
Heck I don't even get 40C with my overclock at full load![]()
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
wow, nice tempsOriginally Posted by nn_step
