Review to come....![]()
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
wow...show us some temps as soon as you can
E3110@3.6Ghz || Gigabyte P45-DS3 || 2GB Cellshock 6400 || Asus HD4850||
So the exhaust is pointing to the pci-e Slot? mhh
Back in the phase change world
Originally Posted by Jort
Yup.Or in the case of the DFI mobos right onto the chipset / chipset cooler.
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
wtf were they thinking there.....and then the hot air just bounces back.....i'm gobsmacked....someone please tell me there is a logical explanation for this stupid ideaOriginally Posted by dnottis
Originally Posted by dinos22
QFT![]()
Sry for thread crap but a review from TechPowerup. You shoudl probably see similar results.
http://www.techpowerup.com/reviews/A...ng/AcceleroX2/
Originally Posted by IYP
oh, a closer look at the package...x1900 series compatible![]()
what does that meanOriginally Posted by chinkgai
quoted for truth
i read that review at techpowerup...isnt it kind of irrelevant to compare to the xt since the xl doesnt exhaust the hot air out like the xt does? nice review though. good pics...looks like the quality has improved cuz i really was unhappy with the last arctic cooling product i used, which was with the x800 series
that being said, i cant wait for ur review dnottis!
The XL doesnt put out nearly the heat of an X1800XT, especially when the X1800XT is overclocked. I have it installed and am gathering results.Originally Posted by live2game2003
I can run max CCC or the PE bios with my Zalman VF-700 - I wont yet say how the Accelero fares at 700/800![]()
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
DFI UT X58-T3eH8 (being replaced with Giga UD5)
Core i7 920 D0 mostly stable @ 4Ghz
TRUE 120
6GB OCZ Platinum 7-7-7 (still in testing
XFX 4890 1GB @ 1050/1190
Corsair HX850W
CM Cosmos S
Still testing...
oooh yeah u got the zalman!
dont forget to compare at different fan speeds for all the coolers please!
we all know how u hate the stock at 100 percent...but jes walk out of the room or turn up a radio or something
edit: just read that review over at ngohq...
maybe someone should tell them about the thermalright v-1We will find out how the first GPU cooler with heat pipes technology performs.
sorry man still don't get the meaning of your comment.......must be something in the hot Sydney air todayOriginally Posted by chinkgai
QFT is an accronym for Quoted For Truth
i "quoted you for truth" = i agree with you and u speak the truth.
sorry for confusion......didn't know about that acronymOriginally Posted by chinkgai
hehe, didn't say it was a good review, just that its a review.Originally Posted by chinkgai
TRUE 120
Corsair HX850W
CM Cosmos S
Still testing...
I wonder why they didnt do any overclocking tests? Wonder if his results were as dismal as mine?![]()
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
......yeah pump some voltage on RAM and core and let's see what happensOriginally Posted by dnottis
from what i can see if you are runnin STOCK clocks you will benefit from quieter cooling on GFX card........might send the chipset temp and fan into overdrive on DFI but that's another matter isn't it![]()
interesting to see your results dnottis
try undervolting the X1800XT mem i was pleasantly surprised it clocked much higher
SIOUX said to under to 2.034v which helped him and i tried it with stock heatsink on my HIS X1800XT didn't do much
then i went water and tried lower at 1.985v mem and went from 936 to 963mhz artifact free and 972-981 with slight artifact in GT3 in 3d2k05 - before any higher than 936 would lock up 3dmarks heh
I just received an email from my marketing contact at AC. They shipped the coolers with washers attached - this was a mistake and they need to be removed. This spacing is most likely causing contact issues with the core and memory.
You can see them here...
I'll have to re-attach and try it later.
Funny - the other sites that already posted reviews would have just gotten this info as well....
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
isnt stock 1.8 for the mem? thats what it says in the overclocking tool...do i have to manually set it to 2.0ish volts?
interesting about the washers...
Mine did the same thing! I was clocking my mem @ 880 with ~1.97volts (both buffers and mem).Originally Posted by eva2000
1.Athlon 64 X2 3800+ @ 2.75Ghz 305x9 1.75v RAM 1:1 - Sapphire X1800XT @ 760/909
SuperPI 1M: 30.407 @ 2860 Mhz DDR636|3DMark01: 38390|3DMark03: 20585|3DMark05: 11234|3DMark06: 5039|
2.Opteron CAB2E 0540 FPMW @ 3216Mhz 321.6x10 1.6v RAM 5:6 (2GB OCZ DDR500)|SuperPI 1M: 26.109| 3DMark01 40456)| More coming soon...
stock is 2.097v
x1800 oc'ing tool displays incorrect mem voltage
