This thread is dedicated to optimizing your Super Pi 1M times per Mhz. The goal.. Get the lowest SP1M time at a given Mhz.
To standardize this, I came up with a rather simple formula so that ALL scores will be comparable. With my method, someone at 3GHz Can compare their score with someone who is at 2.8GHz or even 4Ghz. Please keep in mind that these scores are only comparable with other Athlon64 based systems. Comparing a prescott on a Time to MHz basis would be rediculous.
Here are the rules.
1. All scores submitted must have a CPU clock of atleast 2.4GHz.
2. Score must be accompanied by a Screenshot with CPUZ (main window) and A64 Tweaker open.
3. Super Pi Mod 1.4 MUST be used. The older verions and SEE2 / SEE3 versions will NOT be accepted.
4. Only 1 score, being the highest of your scores, will be added to the listing.
5. Post in the according format. Scores not posted in this format will NOT be posted. " 41.044 --- dinos22 ------------- Opteron 144 "
5a. The format is as follows. Time (to 3 decimal places) three dashes "---" Hyperlink to SP1M time. appx 10 dashes "----------" and finally your CPU and if it is up for question, the core type (IE. FX55 SD or FX55 Claw)
Here is the Formula
Your Time in Seconds * Your Mhz (please use as many decimal places of accuracy as possible) / 2000 = Your score
Example
27.703 * 2951.7 / 2000 = 40.88547255
Lower Scores Are Better!
I will be keeping the listing as up to date as possible so that people do not need to go through the pages of posts. All scores I will have the users name hyperlinked with the screenshot of the SP1M Run with CPUZ and A64 Tweaker. Please remember that if the requirements are NOT met, that the score will NOT be posted.
P.S. I removed the numbers, in an attempt to retain my sanity during organization of the scores.
Scores - A64
39.535 --- funkflix----------- Opteron 146
39.669 --- corvus_corax ------- Opteron 146
39.945 --- T_M ---------- Opteron 146
40.331 --- s7e9h3n-------------FX55 /56
40.395 --- bachus_anonym --- Opteron 146
40.453 --- ^don.k's^ ----------- 3700+ SD
40.476 --- FriGidi ----------- Opteron 146
40.481 --- dinos22 ------------- Opteron 165
40.595 --- overcrash86 -------- 3000+ Venice
40.623 --- Malph----------Opteron148
40.820 --- eva2000 ------------- Opteron 170
40.885 --- MaxxxRacer ------- Opteron 146
40.897 --- farooqm ------------- Opteron 146
40.966 --- before ------------ FX-55SD
41.021 --- largon -------------Opteron 146
41.055 --- aicjofs ---------- Opteron 144
41.101 --- Jaan----------Venice 3200+
41.115 --- Pyr0 -------------- X24400
41.296 --- krampak ------------- Opteron 148
41.463 --- 0verl0ad ---------- Opteron 144
41.522 --- Vapor ------------ X24400
41.699 --- DevanG ------------- Winchester 3000+
41.913 --- GOESA ------------ Opteron 146
42.322 --- Budwise ---------- Opteron 170 DC
44.991 --- grilll ------------ 3500+ Venice
Scores - AXP
1. 50.224 --- Morgoth
2.
3.
4.
