How I did it:
- Went to here: http://boinc.bakerlab.org/rosetta/cr...count_form.php
- Input needed info.
- Downloaded the BOINC Installer: http://boinc.berkeley.edu/download.php
- Install it and let it get up to date/etc.
- When you are asked which project you would like to be attached to, this is the link you should put in the box: http://boinc.bakerlab.org/rosetta
- Downloaded the optimized BOINC files for more performance (*note - you will need to shut down rosetta (boinc manager) to install the updates): http://www.guntec.de/Crunch3r/boincx86.html
**NOTE: When you install it may take time to download workunits if the servers are busy. I suggest setting your buffer to at minimum 0.5 days of work.. mine are currently set at 1.1 days but that may increase after more testing and depending on the servers.
Extra Info (performance, buffering, etc)
To increase your work Cache go into your R@H pref's here: http://boinc.bakerlab.org/rosetta/pr...obal&updated=1 and change "Connect to network about every" from 0.1 to what you want. The resulting WU buffer will depend on the performance of your machine.
I have set my client to use no more than 50% of my virtual memory.. is there a way we can bench how this setting changes performance?
Leave applications in memory while preempted? - which setting is optimal for performance?
.. its pretty much that easyYou can set your team, user name, etc while doing the first two steps then you just need to put in your user name and pass when you install and its all done.
Add any info you got guys, I just tossed this together in about 4 minutes as a quick guide for those who need it.
External Monitoring applications:
BoincView: http://boincview.amanheis.de/
EDIT(s)
01/22/06
Added BoincView
01/01/06
Added rosetta@home link to put into box to attach to the project.
updated recommended buffer time (0.5 days suggested min).
12/31/05
optimized BOINC clients are good, disreguard last edit.
changed buffering: buffered wu's are dependant on your machines performance so setting 0.5 doesnt give you 4wu's only.
12/30/05
update - "buffer more to 1" gives 7 wu's.
added how to buffer more wu's, testing.
added vm change
added leaving app in memory while cpu is busy
removed question on how to increase WU cache.
05/14/06
updated how to install optimized files.
