Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Very Tiny Micro GPU cooler
    Nov 2004
    Pensacola, FL
    I've had these parts sitting around for a while...and i ganked a APC Battery BackUPS from work today (actually 2 of them) that were no good...and i gutted them, and what ya know..instant nice little casing....Gonna get a custom front bent out for it and just rivot it up and viola i think it will be good to go...
    Its a pretty tight fit, but it does fit..don't let the pics fool you. I'll be able to squeeze it in there i think w/o major issues. Besides i'm curious to see how this little compressor does on a GPU.
    I have a GTX on the way, and its time for some more OC'ing or so....so i'd figure i'd build this unit up and see what happens...
    I dunno if i'll build it or not, but hell figured i'd put some pics up and see what you guys think.
    Compressor is Danfoss TT2.5f - Spec sheet attached below
    Some Pics below, we all like pics..
    Attached Files Attached Files
    I like building Vapor phase coolers......
    ......to cool mynipples!!
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
    May 2005
    Nova Scotia,Canada
    Quote Originally Posted by gclg2000
    I see a pretty bad bang in 1 of the U turns in ur condensor. You may want to repair that or reinforce it incase it starts to leak.
    My Rig:
    Q6600 2.4Ghz@2.9Ghz Custom Liquid Cooling
    ATI X1950XTX 512mb DDR4
    MSI 975X Platinum PowerUp Edition
    2gb Kingston Hyper-X DDR2 667
    Sound Blaster Audigy2
    2 IDE HDD, 2 SATA HDD
    LG DL16XDVD Writer,52X CDROM
    OCZ 520Watt PSU 33Amp +12v
    Thermaltake Xaser III case
    Logitech Z560 4.1 400watt Surround Sound
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
    XS_THE_MACHINE
    Nov 2004
    Long Island
    Cant wait to see how this turns out. What gas are you gonna use? R410 or R402? I read that to use R410 to its potential you need a very well tuned system.
    "Victory is always possible for the person who refuses to stop fighting"
    clicks to save kids
    Memory Addict
    Aug 2002
    Brisbane, Australia
    wow nice and compact is good
    Nov 2004
    Pensacola, FL
    Quote Originally Posted by _HL4E_HalfLife_
    It's fine. The picture makes it look worse than it is.
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
    Dothan FTW!
    Jun 2004
    London, UK
    I want... would be perfect for my dothan
    .:MeltedDuron:.
    Aurora - i5 7600K@4.2GHz- Zotac GTX1070 Mini - 16gb Corsair Vengeance DDR3-3000 - Asus Prime Z270M - Fusion ioDrive Duo 1.2TB - 2x512GB Samsung Evo 970 Plus - Seagate FireCuda 2TB - HGST 4TB - Fractal Design Define Mini - Win7 and OSX 10.12
    Lenore - Xeon L5430 - Gigabyte G33M-DS2R - 2x2GB HyperX 6400 - Sapphire Radeon HD5450 - M-Audio Delta 1010 - Adaptec SCSI - 256GB Firestorm SSD - 1TB Samsung F1 - 2U rack mounted - WinXP and OSX 10.6
    Delilah - Pentium E5800 @ 4.2GHZ (VID mod) - Asrock Conroe865PE - Radeon 9800 Pro - 2x512MB GeiL Blue PC3200 - 30GB OCZ Vertex - 160GB Seagate - 2U rack mounted - Win98SE and Win2k
    Jezabel - Athlon XP 2800+ Barton @ 2100 (200*10.5) - ATi FireGL X1 256MB - Asus A7N8X-E Dlx - 2x512MB OCZ EL PC3200 - OG Antec Case - Win98SE and Win2k
    Mysti (WIP) - Pentium II 350MHz - Abit BX6 Rev2 - 4x256MB PC100 SDRAM - ATi Rage Fury Maxx - Diamond Monster 3D Voodoo2 8MB - 20GB IBM DeathStar - Still looking for the right case...
    Nov 2004
    Pensacola, FL
    Quote Originally Posted by moddolicous
    I've got some 502 but i don't think 502 is that great.
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
    Nov 2004
    Denmark
    oh nice little thing there !! looking forward to see results!
    Im allso using a BackupUPS For my cooler (: ..
    Phase Change Cooling
    Nov 2004
    Pensacola, FL
    Quote Originally Posted by Raller
    Cool, i have another one that is probally at least 70lbs heavy. It's a bigger one, but is the same size as a standard case....this little guy is only 7" wide or so.
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
    Feb 2005
    Saskatchewan, Canada, EH?
    hmm, I've got a few dead APC UPS's, unfortunatly I haven't come across a compressor and condenser small enough to fit into anything like that, they were smaller 300VA units I think *would have to go digging in the garage to find out* If my graphics card wasn't already peltier cooled, I would be persuaded to attempt this
    Nov 2004
    Pensacola, FL
    Quote Originally Posted by Bergo
    Ya this small one like i said is a tight fit, but the APC cases are good and i hope maybe many of us can start using them if ya have a dead APC that's no good.
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
    Feb 2005
    I looked into getting a few custom cases made by local company who specializes in laser cuting thin metals, but the cost for a one-off or limited quantity job was insane to say the least, I'll either end up finding a small dead appliance and using it's case, or jsut build my own out of L channel and riveted stainless or galvanized steel
    Dec 2005
    Ohhh can't wait to see the finished article
    Can someone please tell me what a HX is?
    Oct 2005
    Sugar Land, TX
    HX = heat exchanger
    beefin' it up!
    Dec 2004
    WPI
    what're you people doing with the guts of these APCs? I gutted one once and it was a goldmine of parts... everything needed for a beautiful high-current linear power supply.
    Nov 2004
    Pensacola, FL
    Started messing around with some of the tubing orientation.
    Man, its starting to get really tight, but still fits.
    I will have no intention of ever mounting this from the bottom of a case. I'm going to make the suction/evap arm come out the front of the unit, next to a power switch and pressure gauge.
    I have plenty of room in the back part of the case (on the bottom) for the wiring and etc..
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
    Nov 2004
    Pensacola, FL
    Quote Originally Posted by Bloody_Sorcerer
    Chunked them, and we have a battery disposel thing at work.
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
  18. #18
    Jul 2005
    new delhi, india
    Looking good!!
  19. #19
    Oct 2004
    Newcastle Under Lyme - Staffordshire - UK
    Wonderfull brasing and pipework
    What are you using to get such clean and polished joints?
    Tom
    "What will become of us, will we evolve"
  20. #20
    Apr 2005
    Closer than you think.
    Wow that's seriously compact!
    It's not a huge compressor, but I still think that at around the 100w heatload that it's likely going to see it'll give some surprisingly good temps.
    Love the case, and I'm impressed that you're gettingi t to fit, even with that desuperheat coil.
    All in all, a nice job so far
    I'm looking forward to how it handles on a load
    Gray
    [SIGPIC][/SIGPIC]
  21. #21
    Mar 2005
    somewhere where the 2nd compressor isn't needed
    Great idea about the APC case! His joints are not brazed yet..that's why it looks clean hehe! The worst that could appen to the condensor bend is taking is original place...I saw worst on someone's system :P Now put a slhx and put r23 in there
  22. #22
    Aug 2005
    Pretoria, South Africa
    As far as I can see its not brazed yet...
    Very Qute
  23. #23
    Oct 2004
    D'oh! I just looked at the drier with schrader valve and saw the very neat brasing. Forgot you could buy them like that
    Very neat so far anyway...
    Tom
  24. #24
    Nov 2004
    Pensacola, FL
    lol soddem
    Heat is "gclg2000"
    95-0-0
    -100C Cascade Club
  25. #25
    Xtreme Hardware Killer
    Jan 2004
    Behind you
    I have that exact some compressor, care to provide some wiring details?
    Level 80 UD Death Knight on Murmur (Beta)
