7700cu, all air cooling from italy![]()
Hardware: 3800x2, 512x2 vitesta pc 4000, asus a8vdeluxe via kt800pro, air cooling (zalman 7700cu), zalman 400watt.
oS: windows xp mediacenter 2005
ADA3800DAASCD CCB2E 0541XPMW
-3000mhz 1.550 volt superpì 32mb (bad timing 'cause 3:2 cas 3-4-4-8 t1 disabled, I test it only to verify stability).
-3066mhz 1.568volt cinebench 2003
- 2730mhz 1.350volt (windows 1.325) double prime 95
Actually I'm making 2700mhz 1.300volt (lower than default) rock solid cpu
Only screen@3100mhz
MY poor system@full air
