I know some people use Car Radiators in passive setups. I bought this Koyo Race Car Radiator (US $75 Ebay) for passive cooling. I previously had a BIX, MCP350 and 3/8" Tubing. This revision inclues:
7/16" Tubing
Iwaki MD20-RZG2
Koyo Radiator
The Components:
Asus A8N SLI Deluxe
A64 Venice 3000+
3X Samsung Spinpoint 200GB HD
Ultra Wizard Case
Watercooling:
Polarflo CPU,GPU Blocks
Maze 4 Chipset block
I removed the 3.5" Bays thinking the Pump will fit in that spot, but I am not so sure it can once I put it in.
Fan/Shround in progress..
Compaired with Black Ice Xtreme
Next to Iwaki and 80mm and 92mm fan
3 Samsung Spinpoints 200gb
Hard Disk Fan Fits
Figuring out Tubing Path
Pump is not going to fit... I guess it must be mounted outside.
7/16" Tubing on 1/2" Barbs tight fit
