I figured I'd share some of my homemade tools with you guys, never know who has some use for them. If you have any special requests let me know and if it sounds like fun I might just code it
http://www.radeonx.com/snqtools.zip
A64 OC Calculator v0.2
Tool for suggesting overclocked settings.
Based on Gogar's A64 OC Optimizer: http://math.gogar.com/athlon64.cgi
I added some stuff like filter out similar results.Grabber v1.0
Makes a screenshot and saves it as a BMP file.
The screenshot is automatically saved in the directory grabber was run from.
Date and time stamp are included in the name of the file.(and yes, I am obsessed with size-optimizing, even tho all 3 could be much smaller)RTLaunch v1.0
Launches something with realtime priority. Can be quite handy while benching
Just drag the exe onto rtlaunch.exe and it will start it with rt priority.
Or create a batch file: rtlaunch whatever.exe /a /b /c
and it will launch "whatever.exe /a /b /c"
