Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: Danger Den Water Cooling Solution
    Dec 2004
    Thumbs up Danger Den Water Cooling Solution
    Check out the new Danger Den set of waterblocks custom tailered to ATI's motherboard reference design (Sapphire Halibut shown) as well as the new X1800 series waterblock.
    The quality of the these pieces are astounding and they look fantastic. But this isn't all about looks, it mostly about function and Danger Den has done a fantastic job. One of the downsides of liquid cooling is that the removal of airflow over the power delivery circuits causes them to overheat. With this set of waterblocks this isn't a problem for neither the motherboard nor the graphics card since the blocks cover the power delivery circuits. The graphics card block contacts the memory chips as well and ensures they will remain cool.
    According to Danger Den, availability is just around the corner for everything.
    Check out the attached pictures.
    Edit: Crossfire setup coming up next week.
Name:	DD X1800XL Waterblock Front.jpg
ID:	40965   Click image for larger version.
Name:	DD X1800XL Waterblock Back.jpg
ID:	40966   Click image for larger version.
Name:	DD X1800XL Waterblock Mounted.jpg
ID:	40967   Click image for larger version.
Name:	DD Halibut + X1800XL System.jpg
    Dec 2004
    More pictures.
Name:	DD Halibut + X1800XL System3.jpg
ID:	40969   Click image for larger version.
Name:	DD Halibut + X1800XL System CPU Waterblock.jpg
ID:	40970   Click image for larger version.
Name:	DD Halibut + X1800XL System Mosfet Waterblock.jpg
ID:	40971   Click image for larger version.
Name:	DD Halibut + X1800XL System2.jpg
    XS Local
    Dec 2001
    Close to Neweggs New RMA Center, CA
    that would be hot for a clear case
    Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
    DFI SLI-DR Expert 11-25 Bios
    G-Skill 1gb GH UTT @210 2-2-2-5
    BFG 7800GT OC 485/1170 NV 5rev3
    74gb Raptor 300gb Maxtor 500gb Hitachi
    OCZ 520w SLI 3.46v 5.16v 12.64v
    Thermaltake CL-P0114 Big Typhoon
    3dmark01 3dmark05
    Heatware
    Dec 2004
    Actually it would be quite cool Sorry couldn't resist.
    Quote Originally Posted by Dissolved
    Banned
    Jun 2003
    Broomfield, CO
    a little more mass for the CPU block would probably be beneficial
    Apr 2005
    Thats nice...
    Looks like that poor card is going to tear right out of there...
    Quote Originally Posted by Craig588
    You don't count.
    If it's clean you're not pushing it correctly.
    Xtreme Enthusiast k0nsl's Avatar
    Feb 2005
    Scandinavia
    Grayskull,
    Do you know if they will produce a normal, small non-fullcover WB specifically for the new ATi GPUs? I don't like fullcover design waterblocks for GPUs. Nice setup, nonetheless.
    -k0nsl
    When you were born, you were crying and everyone around you was smiling. Live your life so that when you die, you're smiling and everyone around you is crying.
    Dec 2004
    You would think that by looking at it, but I've found that it works really good when tested with a fully overclocked CPU. No complaints here.
    Quote Originally Posted by freecableguy
    Dec 2004
    Not sure. You might want to shoot them an email and find out.
    I prefer the full coverage one. It removes the need for any fans in the system and keeps the memory really cool.
    Quote Originally Posted by k0nsl
    Grayskull,
    -k0nsl
    Nov 2002
    Michigan
    The new ATI cards use the same mounting as the Nvidia 6x/7x do, the Maze 4 GPU line of blocks work fine. As should any block with that mounting setup.
    Gigabyte GA-P35-DS3P
    Intel Q6600@3.5
    G.Skill 4GBPQx2 8GB
    ATI HD4870
    WD Raptor-X 150
    WD 36GB Rapor x2
    WD 320AAKS
    NEC 3500a DVDRW
    Corsair HX620
    X-Fi Prelude
    Apr 2005
    Wisc
    now this is what ive been looking for.
    ive been waiting for someone to make a x1800series water block that cools the memory, i hate the amount of heat these puppies produce when overclocked, or even at idle.
    ive been using a TT "bigwater" to keep it cooled down with a 120 running low to move air across the ram ( i just couldnt bare to put on heat sinks in anticipation of a good water block ).
    thanx for the info GS.... and anything good to say for the sapphire crossfire ? board, or even the PURE ?
    im waiting on a 4000+ that will be here next week, and im thinking of getting another board .
    i just dont see anone posting any user info on them
    I7 950
    EVGA760 Classified/EK Block
    6 gigs Dominator 2000CL8
    580GTX
    Corsair HX1000
    HAF 932
    EK 580GTX Block/ 2x EK Coolstream 240's
    4X Triebwerks SL's
    Apogee XT/ MCP 655
    [/url]
    -150c Club Member
    May 2005
    Northeast, USA
    Does it come in blue?
    If you have a cooling question or concern feel free to contact me.
    Feb 2005
    Scandinavia
    Thanks, I knew that, if you were directing this response to me. I guess I should've been more clear with my question. What I meant was if Danger Den would produce any new non-fullcover waterblocks for the new ATi GPUs.
    -k0nsl
    Quote Originally Posted by Adam217
    Memory Addict
    Aug 2002
    Brisbane, Australia
    sweeeeeeeeeeeeeeeet
    would match this perfectly http://fileshosts.com/videocards/HIS/X1800XT/html/
    Nov 2003
    maze4 gpu + ramsinks > this
    Live Long And Overclock
    Sep 2004
    Weight of the gpu w/c cooler is making the card lean right !! Not good
    Perkam
    Feb 2005
    Scandinavia
    Perkam,
    Imagine then when the motherboard is seated in a case, will be even worse.
    -k0nsl
  18. #18
    Jul 2003
    No it won't, the card is supported by the flange when setup in a case. If you notice the flange is missing from the card in these pics so it can sit on a flat surface.
    These look really nice to me, perfect for a gaming rig.
  19. #19
    Dec 2004
    The card depicted is missung the mounting bracket but when mounted in a standard case the bracket retains the card and it doesn't lean. The card leans even with the stock cooler because it's not balanced. Postive locking slots help a little but not much. It's all the bracket that holds it.
    Quote Originally Posted by perkam
    Perkam
  20. #20
    Mar 2005
    Texas
    Is the GPU wb low profile enough for cf? Probably a stupid question but dont want to assume this.
    Lian Li V1200B
    DFI CFX3200
    FX-57 CABNE 0530apmw 310x11
    Saphire X1900 CF Mastercard
    HIS X1900XTX BenQ FP241W
    Iwaki RD-20 Meanwell PSU S-150-24
    Crucial Ballistix 2X1 GB Z503.16TD 2.5-3-3-7 2.68V
    WD Raptor 74X2 Raid 0
    Vapochill LS
    Corsair HX 650W
    Sond Blaster X-FI XtremeMusic
  21. #21
    I am Xtreme
    Dec 2004
    France
    time to get a nb waterblock to match.
  22. #22
    Dec 2004
    The NB heat sink is glued down, didn't want to remove it on this particular board. However the waterblock that's covering the CPU power mosfets is the same as the NB one. They are interchangeable.
    Quote Originally Posted by sin0822
  23. #23
    Dec 2004
    Here's what the Crossfire set will look like (attached is a 3D rendering of the assembly)
Name:	DD Crossfire Assembly Render.jpg
  24. #24
    Mar 2005
    Texas
    Grayskull, how about space using crossfire?
    thanks
    Lian Li V1200B
    DFI CFX3200
    Vapochill LS
    Corsair HX 650W
  25. #25
    I am Xtreme
    Dec 2004
    France
    let me say this is one of the coolest things ive seen in a while
