Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: DFI EXPERT NF4 Died after 2 hours!!
    Apr 2005
    Birmingham, UK
    Angry DFI EXPERT NF4 Died after 2 hours!!
    Well I have to say firstly that I was mighty impressed with this board.
    Best overclock with old board was 263*12 with 1.65v on a 4800 X2
    I managed to get this board up to 297*11 100mhz more with less volts (1.6v) and better CPU temps (BIOS read -26degrees versus -13degrees in old) - that was 3dm05 stable ran 3dm03 at 264*12 too.
    But while in windows log-on screen it suddenly shut down in the same way a computer shuts down if you switch the power off.
    It has not restarted since. I have tested individual components and they all check out - reset cmos still no go,
    Checked PSU and thats okay - there is a light on theboard to say power is present but she just wont start.
    Has this happened to anyone else - is it really dead?
    Mav
    Sep 2004
    Boston, MA
    have you shut off your PSU (either unplug or throw the switch), wait for the lights to turn off on mobo, then star the PSU up again? If you haven't, try that and then try and boot...i'm currently having this problem...I shut down and I can't turn on again until i recycle the power on my PSU...so give it a shot and let us know..
    Intel 3930k @ 4.55ghz
    Asus Rampage IV Extreme
    Intel SSD 520 480gb
    AMD Radeon 6990
    Corsair AX1200 PSU
    Apr 2005
    Birmingham, UK
    Thanks for the quick reply - yes I tried that (4 times to be sure) and it did not work.
    Help
    Nov 2004
    Brighton, UK
    Condensation? If everything still works in another board then it looks like the expert died.
    Apr 2005
    Birmingham, UK
    Unfortunately yes, all components do still work in a diff board - is it common for these boards to blow up like that? Mine is revA02 and has the trace repair on the SPDIF.
    I did check for condensation - dry as a desert.
    Mav
    Nov 2005
    New Zealand
    Quote Originally Posted by maverik-sg1
    Do you mean it suddenly initiated the Windows Shut Down? (like if you pressed your Soft On/Off powerbutton) ... or if it just suddenly turned off, ie. like someone pulled the plug out?
    If the latter, my first Athlon XP motherboard died on me in similar circumstances one morning.
    I power it on when I got up, like I had everyday for months, and after a few seconds it turns itself off... hmmm... I try turning it back on and nothing...
    After extensive troubleshooting I deemed the board dead and had to buy a replacement because it was secondhand and probably would have been over it's warranty period anyhow.
    It was a GA-7VAXP, I still have it sitting in a box, it was a great motherboard
    Evil Kitty
    Jun 2002
    Detroit, MI
    I haven't seen this trend myself. I've beaten two Experts up pretty hard...one on air, and another on phase change. Both have handled the punishment of 24 hour prime sessions with serious volts and overclocks. However, 2 boards don't make a valid sample.
    We'd need a full description of your set up and cooling to make any good guesses. We assume you've tried the usual like clearing the cmos with the jumper (not the button), removing the battery etc.
    9900k @ 5.1Ghz
    Asus Maximus Hero XI
    32GB (8 x 4) Gskill @4000
    Strix 2080 Ti OC
    OS & Apps: Samsung 970 Pro 512GB
    Games: Samsung 970 Pro 1TB
    Storage: Crucial M500 2TB
    Seasonic Platinum 1000W
    Phanteks Evolv X
    Xtreme Legend
    Dec 2003
    Northern California
    The board may still be alive. Same thing happened to me about a week and a half ago. Board would suddenly shut down. I let it dry out for a few days and did a better job of insulating. Board is fine now.
    Audentes fortuna iuvat
    "Fortune favors the bold"
    Evil Kitty
    Jun 2002
    Detroit, MI
    Quote Originally Posted by sierra_bound
    Yep...been there too. If your sub ambient cooling and you have sudden instability this is something to consider. You can't always see the condensation either. It gets between the socket and board from the pins.
    ^This is good advice.
    9900k @ 5.1Ghz
    Strix 2080 Ti OC
    Phanteks Evolv X
    May 2003
    Holland
    I also have this problem but im using air :S
    When i press the power button in just 2-3 seconds it completely shuts down.
    To resolve this i have to power off the power supply and power it on when the lights on the mobo goes out.
    Then it boots up just fine ........
    Once iit booted up it runs and resets fine but when you shut down and want to start it again ....
    This is my second eXpert the other one also had this problem but that one just went dead after 3 days of work ......
    I have to say im getting a bit paranoide with these boards .... thinking of going with the A8N32 .......
    Somebody has got some tips to resolve this .... ?
    Cpu: Core i7 930 @ 4.5 Ghz 1.4V (24/7)
    Mainboard: Classified E760 @ B3 X58 + EK Waterblock
    Memory: 6GB Kingston Hyper @ 2150Mhz 8-8-8-28 -> 1.72V
    Graphics Card: HD5870 + EK-Waterblock
    Soundcard: Auzentech X-Fi Forte
    Boot HDD: WD Velociraptor 300 GB
    Stuff HDD: 4x 1TB Samsung HD103UJ @ Raid5 (Perc 5i + 512MB)
    PSU: Corsair 1000Watt Modulair
    Water Cooling Setup: WC Setup --> Swiftech Apogee XT / Black Ice 360 GTX / 3x Triebwerk TK-122 / 2x DDC 355 Plus + XSPC Dual Top / EK-Spin Bay Reservoir
    All build in a Corsair Obsidian 800D
    XIP
    Nov 2004
    NYC
    The same here with RDX200 which have the same power systems and mosfets.
    Condensation probly the culprit since I ran it with cascade, but my Ultra-D and SLI DR went w/out problem for months with xtreme cooling on cpu.
    I just wonder if it something to do with 4V jumperless system on this boards (xpert and rdx 200).
    Nov 2004
    I've had this happen to me once, on my Ultra-D.
    I just left it alone for a whole day, reset CMOS and then fixed everything back. IT worked after that.
    Work Rig:
    Proc: AMD Opetron 175 @ 2.7GHz [Scythe Ninja]
    Mobo: DFI Lanparty NF4 Expert
    RAMS: Gskill 4x1GB HZ PC4000 [UCCC]
    Display: Sapphire 512MB X1900XTX
    Drives: WD Raptors 74GB RAID-0 [x4] - Hitachi Deskstar 500GB 7200RPM [x6] - NEC 3540A 16 DVD+-RW [x2]
    Audio: Creative EMU0404 -> DIY AMP -> Aego2
    Case: Lian-Li VB-2000 -> Enermax Coolergiant 600Watts - 4, 120MM fans
    Apr 2005
    Birmingham, UK
    Unhappy
    Quote Originally Posted by Betaboy
    IT died suddenly like the power was cut-off.
    My rig looks like this:
    X2 4800 12x261 1.60v
    BH5 261 2-2-2-5 3.65v
    DFI-NF4-SLI-DR EXPERT Release BIOS (never stayed alive long enough to change)
    2x 7800GTX voltmodded
    850w PCP&C cooling
    2x 75GB Raptors Striped
    2x 200GB Storage Drives
    2x92mm Fan Ram cooling
    Lian Li PC70 Case
    ASUS 16x DVD R/RW
    AKAS Fan Controller
    Mach2GT R507
    EXOS2 Cooled GPU's
    The rig itself is proven on the NON-EXPERT unit and I am unable to fins any condensation traces anywhere - the unit AFAIK was properly insultated (all coments covered inside the cpu kit covered with seal string, dilectric on rear components and neoprene filler to reduce the possibility of air gaps in the kit itself,
    Tried it again this morning and it's stll dead
    Maybe a new one for Oskar Wu?
    Xtreme Legend
    Dec 2003
    Northern California
    Unless you need a replacement board right away, I would remove the seal string and the evaporator head and let the board dry out for a few days. My board came back to life after I did that. In my case at least, I think condensation formed somewhere under the socket.
    Apr 2005
    Birmingham, UK
    Lets see if it works.
    Putting it in the airing cupboard now - temps are around 35degrees in there so I'll leave it there for a few hours and try again.
    I have 7-days to send it back under RMA from date of receiving RMA advice so I am willing to try anything (within reason) to get it working before that date expires.
    It has to be noted that I could not find any traces of condensation at all with this - but gonna give this a go..... just in case
    Mav
    May 2003
    Holland
    It is not an condensation only problem guys im on air and experiencing the same problems ...... (This is my second board !!! the other one also had these problems and after 3 days it suddenly died !!!!)
    My guess its a manufactering flaw ....
    Apr 2005
    Birmingham, UK
    I think we should find more and more people experienceing the same issue - I have borrowed my mates ot test now and see if this holds it together a bit longer.
    Funnily enough my mate has applied for an RMA under distance selling rule - just in case
  18. #18
    Apr 2005
    Birmingham, UK
    Okay - 35degrees celsius warm store room (airing cupboard) for 3.5 hrs - left to cool to 27 degrees room temperature - connected up and still dead.
    Think this was a duff and it's on it's way to join the 'RMA an EXPERT Series Mobo' Club
  19. #19
    Banned
    Jun 2003
    Broomfield, CO
    I'm not only the president, I'm also a client.
  20. #20
    Evil Kitty
    Jun 2002
    Detroit, MI
    Quote Originally Posted by SmokeyTheBandit
    I doubt it. Too many folks are running just fine without any signs of these types of problems. Air cooled, water cooled, phase change, LN...you name it. Its likely a specific issue to your system or mobo. When it comes to stuff like this, it usually is.
    9900k @ 5.1Ghz
    Strix 2080 Ti OC
    Phanteks Evolv X
  21. #21
    Xtreme Recruit
    Nov 2005
    what was your old motherboard?
  22. #22
    Apr 2005
    Birmingham, UK
    My previous MOBO was the non-expert DFI NF4 SLI DR - I think it just might have been one of those things, but has anyone ever killed a board using incompatable temp monitor (in this case speedfan 4.27)?
  23. #23
    Dec 2005
    850w PCP&C cooling
    Lian Li PC70 Case
    ASUS 16x DVD R/RW
    AKAS Fan Controller
    Mach2GT R507
    EXOS2 Cooled GPU's
    I would never use so high memory volts on expert.
  24. #24
    Xtreme News Addict
    May 2005
    Winnipeg, Manitoba, Canada
    3.65V
    that could be yoour answer there. Thats damn high.
    "There's no chance that the iPhone is going to get any significant market share. No chance." -- Microsoft CEO Steve Ballmer
  25. #25
    Apr 2005
    Birmingham, UK
    Quote Originally Posted by DFI Expert
    Interesting, why would you say that?
    Also I have no choice the board (my replacement board that is) wont accept OCZ PC5000 TCCD/TCC5 RAM that runs on 2.7v.
    The BH5 is the only RAM I have that it will post on.
    I have actually dropped the volts to 3.6v and it seems to be okay right now - but hearing you say that scares the life out of me now thinking she's gonna blow any minute now
