Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: Sneak Peek
    Unoriginal Macho Energy
    Dec 2002
    Sneak Peek
    For those of you that don't venture to OCforums:
    Well it's that time again, a new build in the works. Finally got my custom UFO after a long 5 week wait. Note the color and the 3 SEPERATE panels for the sides and the top, no more clamshell one piece like my current case. This is the main reason for the switch, though there are some other cool little bits I'll be doing as well. I have the PA120.3 and the aluminum Coolermaster 120 x 38mm fans which I have tapped to accept normal threaded metal screws, I have chose black allen bolts. I think I will be tapping all fans and using these bolts all around as I like the look. Well, gotta run ATM but here are a few pics.
    Sorry for the blur the case now only uses 120mm fans
    Test fitting of the PA120.3
    Sorry for the blur... Screws (dont look as black as they really are here)
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Nov 2005
    Pottstown, PA
    Wow that is one sweet looking case! Do they normally come with separate side panels or is that an option?
    -pickles
    beefin' it up!
    Dec 2004
    WPI
    nikh, you rich little...
    i presume you'll be putting your RD-30, G5, etc in this rig? or do you have even better stuff somehow (G7?)
    Jul 2005
    Atlanta, GA
    gorgeous nikh. i like the lime green with forest green acrylic window, nice contrast. and i'm loving the tap screws. i have something similar in my rig. ugh can't wait to post pics. will have my stuff ready by end of week.
    keep us posted, i'm curious about the plans for internal aesthetics.
    "premature optimization is the root of all evil" - Donald Knuth
    <('_'<) <('_'^) (^'_'^) (^'_')> (>'_')> OMG ITS T3h POWER RANGERS!
    Xtreme Recruit
    Jul 2005
    Nice job man.
    Keep us informating.
    Dec 2002
    Quote Originally Posted by moonlightcheese
    Thx d00d except the plexi is just smoked... not green at all. I guess the color of the case makes it look tinted in the pics but they are not. I was going to go with UV tinted green plexi, glad i did not.
    Jul 2005
    Atlanta, GA
    Quote Originally Posted by nikhsub1
    ah cool, i see it now. so what can we expect on the inside? is this a solid green or two-toned setup? LEDs or UV cathodes? can't wait to see the finished product d00d. nice so far.
    i did notice the silver power and reset buttons and the two screws there. any plans to paint those black or replace with black switches to match the rest?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    woah nice very nice
    Dec 2004
    Hesperia, Ca
    That is awsome Nik! I love green, now I'm jealous since my UFO is black...
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    nik your sig needs to have "Because cost is no object" put in it somewhere.
    I have heard a little bit about those aluminum fans. How are they compared to the denkis and panaflows?
    One thing I have to shake my head at though, is the green paint job.. Why oh why.. that thing will be visible from space.
    Dec 2002
    Oh maxxx money is an object... when I sell my black one, well, the cost will be minimal. And it isnt a paint job, it is powdercoated
    Mar 2005
    Nik... you hax my brain?
    That is almost exactly how I wanted to get my next U2. Skip the green though. hehehe
    No better case around in my opinion. Looking nice as always.
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    - Thomas Jefferson
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by MaxxxRacer
    Haha, yea, don't know if I'm too keen on the green either Maxxx, but more props to Nik for wanting to 'express himself'.
    And about the coolermaster aluminum fans, they have excellent specs. 120x38mm, around 55cfm, and low 20's for the dba. Good static pressure due to their 38mm width, but nice and quiet.
    Formerly XIP, now just P.
    Aug 2004
    Los Angeles, Ca USA
    I call dibs on naming niks machine. I shall proclaim it "The mean green machine"
    nik: I know its not paint but rather powdercoat.. paint job was a figure of speech... the guy at the powder coating shop must have had a pair of welders goggles on when working with your case.. its nearly radioactive its so brite.
    BUT as enjoy said props for expressing yourself if thats what you want to call it.
    Feb 2004
    how are the fans? I have pretty much the same setup as you. Right now I only have the panaflo's
    Mobo: MSI P35 platinum
    CPU:e8400
    Mem: 4x512mb Patriot fatbody
    Vid Card: 8800gts 512mb
    Cooling: Thermalright 120 ultra
    HD's: 80x2 raid and 320gb
    Case: cooler master cm690
    Dec 2005
    Cany you give us an estimate of the cost of that case? It looks interesting. The green is awesome!
    XS in Sin City
    Dec 2004
    Las Vegas
    Pretty sweet!
    It almost looks like a watermelon; you know the ones that are engineered to grow in cubes so they fit in fridges easier
  18. #18
    Jul 2005
    Atlanta, GA
    Quote Originally Posted by lv_dicedealer
    Pretty sweet!
    WHOA HE'S RIGHT!!! add some red cable sleeves and some red UV dye in the water and you have a watermelon!!!!! AWESOME!!! the first fruity watercooled case HAHA!
  19. #19
    XIP - can sit on his hair
    Jun 2002
    Wakefield, West Yorkshire, UK
    All MM Cases now feature separate panels... tis a recent change... looks stormin' d00d... ya just need a kawasaki to match it
    How was case > fan > rad alignment? All line up nicely??
  20. #20
    Apr 2005
    New York, USA
    what a beast!
    What fans are those?
    Yan
    i7
    Dell 30" 2560x1600
  21. #21
    Apr 2005
    New York, USA
    Quote Originally Posted by YanBooth
    what a beast!
    Yan
    Bump!
    Yan
    i7
    Dell 30" 2560x1600
  22. #22
  23. #23
    beefin' it up!
    Dec 2004
    WPI
    wow, 150 dollars in fans. speechless.
  24. #24
    Nov 2005
    Los Angeles, CA
    damnn 25 dollars each?! thats expensive for a fan.
  25. #25
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by mindwreck
    He got them on a big deal from a site a few weeks ago. Something like $7 a fan it worked out too.
