A little revisit to the modded BIOS.
What does not seem to help any:
tighter timings on the memory
any type of delta
any voltage table work - needs a physical VMOD
What does help:
loosen memory from BIOS settings to Samsung spec - allows memory to exceed 1800 easily
That's about it. But, you will not see much change unless you get the core to aroun 620 or so, since the memory easily exceeds anything the core throws at it.
The rev3 BIOS is for people who want to improve scores but need to keep the core a little lower since their card does not OC well.
![Send a message via AIM to [XC] moddolicous](images/misc/im_aim.gif)
