Results 1 to 24 of 24
Thread: Which air cooler for Dothan
    Slovenian OC Master
    Nov 2004
    Slovenia
    Hello, can sb tell me which cooler is mountable without resoldering jumper and power pins or any big modification. I am kinda looking for TT Big Typhoon, Zalman CNPS9500, or sth big.
    May 2005
    Brownsburg, IN USA
    If you are using the CT-479 adapter you won't be able to use any form of cooler that requires you to bolt through the mobo because the CT-479 blocks 2 mounting holes. That pretty much leaves just the Zalman 7xxx series and the stick ASUS cooler that comes with the adapter.
    If i were you i would just use the stock cooler with some AS5 and maybe replace the stock fan, the dothan chips really don't need excessive cooling
    en4cer's system!
    DFI LANPARTY DK 790FX-M2RS
    AMD Phenom 9850 BE @ 3.4Ghz 1.35v
    4GB Corsair Dominator @ 1066MHz 5-5-5 2.2v
    Visiontek ATI Radeon HD4870
    Creative X-Fi Xtreme Gamer
    2x Western Digital 320GB SATA-II
    Lian-Li PC-A17B Case
    Corsair 750TX 750W Power Supply
    Klipsch Promedia Ultra 5.1 Speakers
    Windows Vista Ultimate x64
    HEAT
    Slovenian OC Master
    Nov 2004
    Slovenia
    i have seen some of the coolers, eg. macci has CNPS9500 on dothan, but i can't see from his picture what he did with jumpers. I haven't seen Big Typhoon, maybe it doesn't need any big modifications. I allready have those alu sticks which zalman uses to mount their coolers, with the help of P4 retention module!
    Can anybody tell me what mod do i have to do, to remove jumpers from front (top) side of adapter and that power connector.
    Oct 2005
    Belgium
    Some people have mounted an hsf than uses the bolt-through method, search for dothan mounting if you want to see that.
    i have another cooling related question; my dothan hits a wall at 2483, temps are in the low 50s with the ct-479 cooler. Would i be able to clock it higher with a better (air)cooler?
    Oct 2005
    Salo, Finland
    Skane: I don't think so. What voltages are u using? I had 730 @ 1.6v with stock cooler. I didn't get any improve for speed after i installed Zalman's 7700. Just temps got much lover, but couldn't overclock that any further. I think only way is to go higher voltages, but maybe theres no sense use over 1.6 voltages?
    And back to thread, it seems theres no difference between 9500 Led and 7700 actually. Maybe little temperature advance could be for 9500, but is it really worth that price? I don't think so... And 7700 is at least very easy to install. Or was it there none problems with 9500 also? Well anyway Big Typhoon seems to be able to install, but really thats not woth of it!
    I just suggest u to save some money and buy Zalman CNPS7000Cu or CNPS7700.
    C2D E6600 @ 3400 | P5W DH Deluxe | X1900XT | 2x1024 Corsair
    Oct 2005
    Belgium
    it is stable at that speed, at any voltage between 1.4 and 1.6.
    i dont think the 9500 will be harder to install than the 7700 as it uses pretty much the same mouting mechanism as the 7x00, the only difficult thing seems to get the little clip between the heatpipes.. The 9500 does have one advantage over the 7700, namely that in cases with little space between the mobo and psu, it can be installed where the 7700 cant. The question if it is worth the money remains though..
    The un-extreme XIP
    Jul 2004
    7000alcu. mounting is simple, temps are great
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Nov 2005
    I have a 7000B Cu LED and I love it... max temperatures are around 40 to 45 while benching or gaming.
    Alex
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by AgonxOC
    hehe I wanted the cu LED one but was twice the price of the 7000 alcu i got, so wasnt really worth it..
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    xtreme energy
    Oct 2004
    Europe, Latvia
    I have 7700AlCu, had to mod it a bit for proper mounting. Can't tell you temps though since my MB is reporting incorrect values. But it was like 10C lower than stock heatsink.
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Has anyone tried a Vapochill Micro on the CT-479?
    770 sitting here, waiting for the P4GD1 to arrive.
    Also(off topic) any ram suggestions?
    any and all imput on this project appreciated.
    read too many horror stories so far..
    The un-extreme XIP
    Jul 2004
    Quote Originally Posted by Movieman
    the 7000alcu is really the best heatsink you're going to get without modifications. the 7700cu can be done, but i had to shave my floppy connector (the one connected to the power supply, not the adapter's plug) down a bit to get it all to fit properly.
    as for ram, i recommend two gskill 1gb value ram, pc3200cl3. its 71 bux for a 1gb stick . i just dropped one in my dad's ultra-d based box, i'll play with itlater
    Jan 2005
    I have a CNPS9500 on my M740
    I am Xtreme
    Apr 2005
    Upstate, NY
    LMFAO!! Nice man! How heavy is that monster .
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Slovenian OC Master
    Nov 2004
    Slovenia
    thx man, that i was talking about. I am going to buy that monster.
    I would like to know, is there no other option for mounting, except bending that power conncetor. And do you have any pic, how that power connector looks without cooler, or can you just describe what exacly did you do.
    thx
    Jan 2005
    Quote Originally Posted by zbogorgon
    thx
    I just bend the pins of the powerconnector 90 degrees and solder the wires from the molexconnector to the pins.
    Jan 2005
    Quote Originally Posted by NickS
    It's not that heavy,it weights 530g.
  18. #18
    Slovenian OC Master
    Nov 2004
    Slovenia
    thx mate.
  19. #19
    Nov 2005
    New Hampshire
    Quote Originally Posted by cirthix
    Thanks for the info!
  20. #20
    Jun 2005
    France
    XP90 is greatest than 7000 AlCu in my experience
    bend the pins of the powerconnector 90 degrees and mount the stock XP90, that's all
    Dothan 740@2,85, P4P800-SE, XP90+SE2, 2x1024 GSkill ZX, Asus X850XTPE, Tagan 420 i-Xeye
  21. #21
    Apr 2003
    Quote Originally Posted by JeanY
    Pics ? Sounds like an interesting mod. I think alot of the people are going CNPS's because of their quietness though. Although a 120mm panaflow on it would be nice.
    Ryan
    Banias 1.5G SL6F9 @ 1.8G {200*9 @ ~1.59vCore} :: P4C800-E DLX w/ CT479 :: 2x 512M Samsung TCC4 2.5-3-3-6 :: 9800 {380/330}
  22. #22
    Slovenian OC Master
    Nov 2004
    Slovenia
    cooler looks nasty, one of the things that makes him serious is that tunnel effect with 120 system fan.
    i'll probably mount a 120mm fan on it.
  23. #23
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    I agree that a 7000 is the way to go.
    I use a 7000B-AlCu myself till a new pump arrives. Its quite, cools well, and required no modifiaction to mount it.
  24. #24
    Jun 2005
    France
    Quote Originally Posted by Banzai
    Ryan
    SE2 is running at 850 rpm for 24/7 use @181x15 1,55V, DDR 226 2.2.2.5 PAT On with 3V
