Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Thread: Countdown for E4 Venice..the return of the OC king
    Dec 2004
    E4 Venice..a disabled dual core ?
    AMD will stop production on E3 Venice ...3000+3200+3500+...but i dun really care about this coz they gonna roll out the E4 stepping venice which is cut-down version of Opteron/sandiego...so wat do u think about the overclockablity??
    but juz wonder wheter AMD already start to ship it ?? cant wait to see the result...already push my local amd dealer to get it as soon as posible :P
    Nov 2004
    Denmark
    Yummy
    Well, the good batches are probably going to be hitting 2.9-3.1GHz on a very good air cooler , with the cut-down cache and all...
    And they'll probably be running a bit cooler than their 1mb cache-counterpart...
    But genrally I think the same steppings are gonna be good as before, though they'll probably tape out a lot of new cores now...
    Best Regards
    Silverstone RAVEN RV02|
    Core i5 2500K@4.4GHz, 1,300V|
    Corsair A70|ASUS P67 Sabertooth|Creative X-Fi Titanium Fatal1ty|
    Corsair Dominator DDR1600 4x4096MB@DDR3-1600@1.65V|Sapphire HD7970 3GB 1075/1475MHz|
    Corsair Force F120 120GB SSD SATA-II, WD Caviar Black 2x1TB SATA-II 32mb, Hitatchi 320GB SATA-II 16mb|Silverstone DA750 750w PSU|
    Dec 2004
    aiming for the early batch steppnig of opteron ... CABNE 0530 such....
    Xtreme Guru
    Jul 2004
    Isn't AMD making 940 pin A64's soon with DDR2 support? when is this going to happen?
    Aug 2005
    Wasn't that going to be socket A2?
    Aug 2005
    Perth, Australia.
    Socket M2.
    ___I am Xtreme... are you?
    Nov 2004
    Japan
    Just Info the code will be "CG" for E4 Revisions
    from anandtech
    The new E4 chips carry the "CG" code name in the SKU. For example, the new 3200+ retail kit is labeled as ADA3200CGBOX. Don't let this confuse you with the "CG" stepping of older Hammer SKUs; those were labeled as "AR" and "AS" in the OPN (SKU).
    Dec 2004
    Click look here
    Xtreme X.I.P.
    Aug 2004
    Chile
    what if this are bad sd cores??
    Mar 2005
    Absolutely nothing new here. These new Processors are AMD way of getting rid of Manchesters (And in a few weeks, Toledos should come too) that got a defective Core but with the other one working flawlessly. With the size of those Cores, is quite probable that they getted a lot of them with a damaged Core.
    s7e9h3n already did a Thread some time ago saying that he getted two Processors with the OPNs ADA3700DKA5CF and ADA4000DKA5CF that in a Screenshot of Central Brain Identifier are identified as Revision JH-E6, exactly the same that Toledos. Avoid to confuse them with a Venice or Palermo Rev. E6 because the full Revision name of those Cores is DH-E6. Check here. So, the new ones with OPNs ADA3200DKA4CG and ADA3500DKA4CG are nothing more that Manchester (Revision BH-E4). Everything fits properly if you include the full Revision name
    What about overclocking? They will run amazingly cool because they got twice the Core surface to dissipate heat while consuming only what a Single Core Processor because the other Core will be disabled. Like with Thortons (Bartons with half of its Cache L2 disabled), running cooler due to a bigger Core surface while using the same amount of Transistors that a Thoroughbred should allow them to overclock a bit more than a physically Single Core Venice or San Diego.
    Nocturnal
    Guest
    I can't wait, heard about this from Kris from Anandtech himself and was very excited to hear this big announcement.
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by zir_blazer
    but only part of that core is really putting out heat
    Got a fan over those memory sticks? No? Well get to it before you kill them
    Dec 2004
    if these REV venice is actually base on manchester E4 ...well..cross my finger to wait news from athlon64 unlock thread... it might be able to open tat defect sec core as well..could be working on slower speed only...
    2 hope on these stepping,better overclocking or could be unlock !!?? :P
    Jan 2003
    Knoxville, TN
    http://labs.anandtech.com/alllinks.php?pfilter=4105
    for availability of the new CG rev 3200+ venice
    Main Rig:
    CPU Intel i5 2500K @ 4500mhz
    Mobo Gigabyte GA-Z68X-UD3H-B3
    Memory 4x4GB Corsair Vengeance DDR3 1600
    Video Cards Sapphire 5850
    PSU Silverstone ST75F Strider 750W
    Hard Drive OCZ Solid 3 60GB | OCZ Vertex 2 60GB | Samsung 103SJ's 4TB
    Cooling Thermalright Ultra 120 | 1 Yate Loon D12SM 120MM
    Mar 2005
    Quote Originally Posted by ozzimark
    And what I sayed?
    Jun 2005
    And what I sayed?
    This:
    And he correctly pointed that as only one core will be working, heat will come of only that part of the core.
    Mar 2005
    Quote Originally Posted by Piotrsama
    This:
    That exactly what I sayed...
  18. #18
    Jun 2005
    So what?
    Heat is produced only in half of the die
  19. #19
    Dec 2004
    So what?
    yup,but better connecting between the core and IHS mean heat will more easily to transfer out ..due to large die(large surface contact to the IHS)
    AMD's KAKI
  20. #20
    Phenom™
    Sep 2002
    Quote Originally Posted by HolyAk
    Don't forget that they also run @ a lower default vcore. Here's a couple of tests on air with the ADA4000DKA5CF:
    Idle Default:
    Loaded default:
    Idle @ 2800:
    Loaded @ 2800:
  21. #21
    Jun 2005
    Quote Originally Posted by s7e9h3n
    Can't argue with that
    Now, you have to prove that heat will be distributed equally along the entire die (which won't happen ).
    That's the point, it won't be dispersed equally in the whole die, it will be concentrated in the used core, and the other area will be "warm" (much cooler). The heat physically goes "up", to the cooler, not sideways. (I remember reading an article about heat disippation, can't find it).
    Anyways, until a Physician tell us the opposite ( ), I will mantain my opinion.
    I might be wrong, anyways.
  22. #22
    May 2004
    Super Pi 1 M is far from ideal to evaluate the heat output.
  23. #23
    Dec 2004
    lol....basicly it will help abit will larger core ... not much maybe but better than nth
    AMD's KAKI
  24. #24
    Dec 2004
    guess need to wait a quite long time b4 it reach malaysia...US shud get within next month...haihz
    AMD's KAKI
  25. #25
    Phenom™
    Sep 2002
    Quote Originally Posted by LowRun
    FWIW, the cpu topped out @ ~38C loaded on 32m (I'll have to look for the pic of it running). Here's the finished run:
