XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 11-18-2005, 05:47 PM   #1
ben805
ben805's Avatar
Asus A8N32-SLI General OC Discussion
I just received my Asus A8N32-SLI mobo from newegg today, I checked every single inch of this mobo for that rumor's "Rev 2.0 sticker" but it is no where to be found....I"d called Asus tech support and he denied such revision so I really don't know what that ebay seller is smoking but Rev 2.0 doesn't exist!! The package came with loads of cable, optional fan, SLI link and other stuff that I don't really care for Alright, so let's get down to the business, for those who wonder what kind of heatsink is compatible with this mobo, well...let's just say it has plenty of room and clearance for the TT Big Typhoon!! I love the layout of this mobo, all cables are out of the way, installed was painless, and definitely can fit a soundcard perfectly on PCI slot# 2 and still leave plenty of room for the first video card to breath, though PCI slot #1 and 3 are kinda close to the gpu fan but nevertheless they still fit ok.
to be continue.....
__________________
Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
ben805 is offline   Reply With Quote
Old 11-18-2005, 05:49 PM   #2
ben805
ben805's Avatar
The aluminum mosfet heatsink looks kinda out of place, should of been copper to match the SB and NB heatpipe thing, and I was surprised that there were absolutely no thermal compound or sticky pad whatsoever to aid heat transfer either, so I popped off the mosfet sink and apply a thin layer of AS5 on all those little mosfets then slapped the aluminum sink back on.
For those who couldn't get the vcore to over 1.58v, your mobo have to be either defective or it need bios update? I set the vcore to 1.40v and enable the v-core boost(200mv) and gets 1.61v instantly!! setting it to 1.5v with the vcore boost also gave me around 1.78v....not that I would ever use more than 1.70v but it's nice to know I can get close to 1.80v of vcore if ever needed.
Moving my raid from DFI Ultra-D to this Asus A8N32 is painless, don't need to delete the array though Windows XP need to be wipe and reinstall, I'm doing it now as I type on my laptop how well does this mobo overclock? I'll find out soon enough and will post back result as soon as I'm done loading all my apps back on.
__________________
Old 11-18-2005, 05:55 PM   #3
Psyche911
Looks great so far, keep us updated.
P.S. Is it really smart to have it on your carpet? lol
Psyche911 is offline   Reply With Quote
Old 11-18-2005, 06:00 PM   #4
trza2k
What bios are you running? Also what version of motherboard is it.
trza2k is offline   Reply With Quote
Old 11-18-2005, 06:01 PM   #5
PuNiShEr
PuNiShEr's Avatar
Send a message via MSN to PuNiShEr
Beautifull Indeed
Now let's go for the tests
Please, when you can, check out the maximum vcore and vdimm...
Did your board came with wifi card?
Which revision your board has written in the PCB?
__________________
Intel Core 2 E6600 @ 3.8GHz @ DangerDen WC
4 x 1 Giga CellShock
ASUS Striker Extreme nForce™ 680i SLI
BFG nVidia 8800GTX
BFG AGEIA PhysX
SoundBlaster X-FI Fatality
2x WD Raptor 150GB 16MB Cache @ RAID 0
3x WD Caviar 500GB 16MB Cache Sata II
SilverStone TemJin TJ03
DELL 2407WFP TFT 24'' Rev A03
Logitech Z-5500 Digital
PuNiShEr is offline   Reply With Quote
Old 11-18-2005, 06:05 PM   #6
ben805
ben805's Avatar
look closer...I'm using the DFI mobo's white color foam pad under the Asus mobo sometime I also use static bag The bios is relatively easy to setup, memory timing tweak is comparible to my DFI Ultra-D and most of those value looks familiar except a few that I've never seen or heard, I'll have to play around with it and keep you guys updated. By the way, I'm using my 148 CABNE opty on this mobo and it has absolutely no problem picking up the stepping, the bios recognized it properly
__________________
Old 11-18-2005, 06:06 PM   #7
DAK1640
Riptide's Dad
DAK1640's Avatar
Send a message via AIM to DAK1640
Very nice indeed, nice pix too...I want that mobo
__________________
Q6600 Farm with nVidia GPU's
DAK1640 is offline   Reply With Quote
Old 11-18-2005, 06:39 PM   #8
Supertim0r
INTEL inside
Supertim0r's Avatar
that's a real nice board
waiting results
__________________
24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
Supertim0r is offline   Reply With Quote
Old 11-18-2005, 06:42 PM   #9
Herbal
You might want to check the mosfets are making good contact with the heatsink.
On my A8N32-SLI I've found the mosfets on the outer edge are slightly 'lower' than the others and thus make poor contact....I need try and sort that on my board.
Herbal is offline   Reply With Quote
Old 11-18-2005, 06:46 PM   #10
Major
Moderator
Major's Avatar
Send a message via ICQ to Major Send a message via AIM to Major Send a message via MSN to Major Send a message via Yahoo to Major
@Ben805
I'm glad to see someone that I know and trust with this board !!
I'm going with one after the first of the year, maybe sooner !! lol
Good to know that 1.7v is a go too, that was a major concern of mine. What memory bios settings are missing ? any ?
__________________
WORK/PLAY - - PCMark05 8,163 - - 3DMark05 15,749 -
DFI NF4 SLI DR Expert, Vapochill LS, FX60 ES SPMW 0536 "Naked" @ 3430mhz 1.70v 2xPi32 Stable
Mushkin Redline XP4000 2x1gig @ 264mhz 3-3-2-6 1T 2.8v, 7800GTX 540/1404, PC Power & Cooling 1KW
2x 74g WD Raptor Raid 0, 2x 300g Maxtor 16mb Raid 0, Maxtor 250g External, Creative X-Fi
KIDS -
MSI Neo2 w/3200+, Asus A8V Dlx w/3400+, Abit IC7-G w/2.8c, Asus P4C800 Dlx w/3.0c, DFI NF2 w/2500+
Major is offline   Reply With Quote
Old 11-18-2005, 07:02 PM   #11
chunkylover77
XS News
chunkylover77's Avatar
Send a message via MSN to chunkylover77
It's too bad that this is not compatible with my LL v2000 or I would jump all over this. Maybe I will get it and just remove the heatpipe. Show us some good oc's Ben and I will have to. Would love to pair this with an Opty 175 and call it a day for a year.
__________________
RIP Dad. I will miss you always.
Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
chunkylover77 is offline   Reply With Quote
Old 11-18-2005, 07:10 PM   #12
[XC] moddolicous
XS_THE_MACHINE
[XC] moddolicous's Avatar
Send a message via AIM to [XC] moddolicous
Nice to see asus made a nice 939 mobo. Cant wait for the oc results. What was there under the copper pipe thing for the northbridge & southbridge?? Thermal tape or Thermal paste? Only 3.2 to the ddr?
__________________
"Victory is always possible for the person who refuses to stop fighting"
clicks to save kids
[XC] moddolicous is offline   Reply With Quote
Old 11-18-2005, 07:14 PM   #13
lowdog
You must be using the bios 502 that shipped with the board, can you confirm this please.
Bios 703 and beta 805 WON'T give 1.77vcore using the overvolt cpu option. Max with these two bioses is 1.58vcore.
You can flash to these newer bioses and confirm that for all of us if you like. If correct it looks like only bios 502 gives 1.77vcore.
I'm running 805, 703 was ify for me. I don't want to flash back to 502 atm.
lowdog is offline   Reply With Quote
Old 11-18-2005, 07:15 PM   #14
trza2k
Well after seeing this thread i decided to go try and get my a8n32 to give me more vcore(trying every combination of settings). Still doesnt give more then 1.58volt as per the other thread. Will be interesting to know what version of the motherboard and bios you are using.
Old 11-18-2005, 07:21 PM   #15
trza2k
I tried 502 lowdog. Still no go... I think it might be something on the mobo stopping it.
Old 11-18-2005, 07:36 PM   #16
lowdog
Yeah well I'll be phucked then because there's no way my board will go over 1.58vcore. Not that I'd use over that anyway but non the less tis a strange issue this one.
Old 11-18-2005, 07:39 PM   #17
ben805
ben805's Avatar
OMG....This motherboard overclock like dream I have NOT encounter a single hiccup so far and you guys are going to be in for a very nice surprise when I finish running the SPI 32M!! more screenie coming in 20min....stay tune
by the way this motherboard is rev 1 and I'm using the default BIOS 0703 build date 10/27/05
__________________
Old 11-18-2005, 07:44 PM   #18
Supertim0r
INTEL inside
Supertim0r's Avatar
finally, there's no rev2 board ?
__________________
Old 11-18-2005, 07:48 PM   #19
trza2k
Is that 1.00 revision? Because mine is 1.01.
Old 11-18-2005, 07:52 PM   #20
Supertim0r
INTEL inside
Supertim0r's Avatar
man this board is my next purchase
__________________
Old 11-18-2005, 07:52 PM   #21
arctic-k20
arctic-k20's Avatar
sweet
__________________
Case: Coolermaster Stacker 830 SE w/ Corsair TX750
Mobo: Giga-byte EP45-UD3P
CPU: Intel e8400 Q832A163 @ 4000mhz
RAM: Mushkin 996593 @ 500mhz
Display: Dell 2405FPW
Video: BFG 8800GT 700mhz core / 950mhz memory / 1620mhz shader
Cooling: TRUE /w 2x SFF21F
arctic-k20 is offline   Reply With Quote
Old 11-18-2005, 07:53 PM   #22
fareastgq
fareastgq's Avatar
It's been six minutes Ben, why haven't you updated us???? Hehe, anyway, that freaking rocks, I'm glad the v-core issue has been fixed, With the 8 phase power+ 1.7+ v-core, I think this board will smoke the ultra-d and SLI in sales now. Mine will be here monday, I'm SOOOO.... wanting it to get here, I was almost going to have it overnighted because I'm DYING to get my damn opty under a real board. Good to know it will be doing some real H2O clocks. Keep it coming
__________________
ALIENS are bringing my next kentsfield based rig in a UFO case!
fareastgq is offline   Reply With Quote
Old 11-18-2005, 08:14 PM   #23
cronic
Banned
looks great so far. Can't wait to get mine.
cronic is offline   Reply With Quote
Old 11-18-2005, 08:26 PM   #24
ben805
ben805's Avatar
Thumbs up
This is the most painless mobo I've ever overclock, yes the print out on the board said rev 1.01 which is the same as everyone else, vcore 1.78v is a confirm as I test it out really quick but since I do not have my phase change hook up I do not want to keep it there for any more than 20 sec incase I fry my opty, I really do not understand why some of you can't get more than 1.6v as I and my colleague do not have any problem with our opty running it over 1.75v, maybe it's cpu related? I'll try to answer as many question as I can but let's get down to business for now, how well does it overclock??
here....
no problem hitting a rock solid 334 HTT, the anandtech's review of this mobo had theirs up to only 310 but I think they didn't push the board hard enough
It appears to have more memory tweaking options than my ultra-d as well, but I'm not familiar with some of them but I'll have to mess around with those values to see what kind of impact they have on performance and stability.
__________________
Old 11-18-2005, 08:30 PM   #25
ben805
ben805's Avatar
Thumbs up
Here's a few more bios screenie, I'll have to tweak more and run other benchmarks, will post more results later on, but so far I'm loving this mobo!!
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
