Page 1 of 15 123411 ... LastLast
Results 1 to 25 of 375
Thread: Swiftech Apogee Discussion ( The Cat is Out of the Bag )
    Unoriginal Macho Energy
    Dec 2002
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Jul 2005
    Atlanta, GA
    better than the storm!?
    ZOMGWOW. let's see some XS testing ^_^
    "premature optimization is the root of all evil" - Donald Knuth
    <('_'<) <('_'^) (^'_'^) (^'_')> (>'_')> OMG ITS T3h POWER RANGERS!
    Dec 2002
    Quote Originally Posted by moonlightcheese
    Don't be so sure...
    Jan 2005
    Houston,TX
    what was it? links dead
    Technologically Challenged
    Aug 2004
    page cannot be displayed
    Jul 2005
    Atlanta, GA
    Quote Originally Posted by nikhsub1
    Don't be so sure...
    that's why i requested the testing... it doesn't seem like it would outperform the storm at all. that "diamond grid" seems like so many other channel style blocks. it seems unlikely that it would outperform jet impingement. but hey, who knows.
    Dec 2002
    Haha, they pulled the page, good thing i got some pics...
ID:	39998   Click image for larger version.
ID:	39999   Click image for larger version.
ID:	40000   Click image for larger version.
Name:	TR vs HP SM.gif
ID:	40001   Click image for larger version.
Name:	TR vs FR SM.gif
    Jul 2005
    Atlanta, GA
    pics of graphs
Name:	PD vs FR.GIF
ID:	40003   Click image for larger version.
Name:	TR vs FR.gif
ID:	40004   Click image for larger version.
Name:	TR vs HP.gif
ID:	40005   Click image for larger version.
Name:	TR vs PD.gif
    Jul 2005
    Atlanta, GA
    pics of block
ID:	40007   Click image for larger version.
ID:	40008   Click image for larger version.
ID:	40009   Click image for larger version.
ID:	40010   Click image for larger version.
    beefin' it up!
    Dec 2004
    WPI
    actually, i recall seeing a graph a while ago with the STORM versus the MCW55 on the same die in a C/W versus hydraulic power comparison and it had the diamond pin of the MCW55 beating the storm as it was. I also remember seeing a picture a few years ago of Jason AKA MickeyMouse running an MCW50 on a CPU. There's definitely a lot more to the diamond pin grid than most people give credit. *pokes cathar* wanna shed some light?
    Jul 2005
    Atlanta, GA
    BasePlate
    Quote Originally Posted by swiftech
    The CNC machined C110 copper base plate is at the heart of Apogee's cooling efficiency. The Patent Pending Diamond Pin Matrix was optimized using Computational Fluid Dynamics analysis to yield the remarkable results recorded by the water-block. In the process, thickness of the base was reduced to 3mm. This resulted in a higher compliance of the base with its mating surface (i.e. the CPU heat spreader) thanks to the base plate added flexing ability.
    PD vs FR
    It can be seen that the pressure drop of the Apogee is lower than that of the MCW6002 at equal flow rates, and substantially lower than that of the Storm. In the real world where the range of flow rates is limited by the power of the pump, this will also translate into noticeable gains when multiple water-blocks are connected in series. A simple example illustrates this point quite clearly: using the same MCP350 pump, it will take three Apogee water-blocks in series to drop the flow rate to that of single Storm.
    TR vs FR
    Here it is apparent that the Apogee has the lowest thermal resistance at all flow rates and more importantly features a wider performance advantage at "real life" flow rates between .3 and 1.5 GPM.
    The above two graphs can then be combined below to illustrate the pressure drop / thermal resistance relationship
    TR vs PD
    From the above curve, it can be seen that the Apogee water-block does not necessitate a high pressure pump to be extremely efficient. It yields in fact lower (better) thermal resistance values than the MCW6000 and Storm water-blocks at all pressure drops.
    Another way to consider the relationship between the water-block's thermal resistance and the pump capability is to plot the hydraulic resistance, which is literally the work that the pump must do.
    TR vs HP
    As in the preceding graph, the Apogee outperforms all previous solutions whether a small aquarium pump or a high pressure industrial pump are used.
    It should be added that under certain circumstances, the Storm water-block may perform better than the Apogee water-block. We cite for example earlier generations AMD Athlon XP, MP and Duron processors where the die size is smaller in surface area (100 to 140mm2) than current microprocessors. In such instances, the difference in temperature was found to be 1.4°C at 100 Watts, and at the maximum flow rate allowed by our test equipment (about 3.3 GPM for Apogee, and 2 GPM for Storm). Such test were conducted using the alternate testing procedure described in the link below.
    Xtreme Recruit
    Mar 2005
    Looks interesting. I shall await a procooling.com review and the review on OC.com
    Did BillA do the testing on this before he left Swiftech?
    Jun 2005
    Dulles, VA
    Impressive but I hope I don't need a firehose type pump to get slightly better cooling.
    Any word on the cost? Maybe why the Storm block has been seen recently at a reduced price? Although I did nab one for $60 while the gettin was good
    2600K @ 4.8 w/H70
    ASUS Sabertooth P67
    16GB G.Skill DDR3 1600
    ATI 5870 2GB
    Thermaltake 750w
    OCZ Vertex 2 120GB
    2x2TB WD Greens
    Thermaltake Level 10GT
    Xtreme Legend
    Nov 2002
    Melbourne, Australia
    Quote Originally Posted by Bloody_Sorcerer
    No, there is no more to diamond pin. The issue is with the testbed.
    Independent tests will reveal the truth of the matter.
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    Wow block releases within months of each other. I bet they jsut don't wanna give their profits to Cathar anymore. THe less they sell of the storm, the less they would have to give up.
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
    Xtreme Legend
    Nov 2002
    Specifically this bit:
    I'm guessing that the results described in the above paragraph would've been done on BillA's old small-die testbed (10x10mm). The Storm was better by 1.4°C.
    Now the results in the graphs were all done on a testbed that does not measure the actual die temperature, but rather the IHS surface temperature. Irregularities in how the waterblock is applying contact between the heat die and the IHS can vastly alter results (by +/- 4C) when measuring at the die instead.
    To date, when measuring on-die temps, as opposed to IHS surface temps, I have not been able to reproduce anything that could describe the results presented in the graphs.
    Once again, independent testing will reveal all.
    [Edit: I am not saying that Swiftech's results are incorrect. I am saying that I have legitimate concerns over their testbed's ability to predict what the actual CPU die temperature will be, and I await independent testing to verify the results shown.]
    Sep 2005
    DFW
    jet imp. on a diamond pin
    Quote Originally Posted by freecableguy
    I'll come blow on your heatsink for a dollar. Thats pretty ghetto
    Quote Originally Posted by Xeon th MG Pony
    sorry to sound harsh but so would you if some one asked if nitroglycerin was a good coolant for his car!
    Check out my forum: http://www.anarchyst-it.com
  18. #18
    Jun 2005
    Harrr.
    I'm sad because I was going to do the same design with a little saw and some thick plastic.
  19. #19
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    Cathar, you must admit, this WILL be the block to have simply because of the affect on flow versus the storm. anyone with a multi block loop will want this block over the storm.
    offtopic a bit:
    Any wonder how dangerden is going to go with this? they really need to get a new CPU block out.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
  20. #20
    Xtreme Legend
    Nov 2002
    Quote Originally Posted by WeStSiDePLaYa
    No, I don't accept that at all.
    If you have a multi-block loop, the flow rate differences will be MUCH smaller because with the added blocks, the correspondent effect of the CPU block on the overall system resistance is much lower.
    Then again, for those who think that more flow rate is more important than greater performance, then their minds will already be made up.
  21. #21
    Feb 2004
    offtopic a bit:
    then people would be using the maze4 instead of a g4/storm or even a tdx... just looking at that design you should know the storm would outperform it.
    930 @ 4.4 & P5WD2 (vcore + droop, mch vdd, ddr2 vdd)
    4x512 Micron D9
    7800gtx 600/1470 (vgpu + vdd)
    h20
    my heat
  22. #22
    Jun 2004
    Quote Originally Posted by Cathar
    But with performance being so close, but yet this new block being less restrictive. and the most common secondary block is most often a maze4 gpu which is low restriction, this would be the more ideal block.
    Single block/no ihs: Storm>apogee
    single block/with ihs: storm<apogee
    mutliple block w/with out IHS: storm<apogee
    so yeah storm is still better idealy, but with common multi block set ups, i think the slighlty less effeciency is much offset by lower restriction, that would be much needed when running gpu or sli blocks.
    Specs
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    Audio Setup
  23. #23
    Xtreme Legend
    Nov 2002
    I prefer good data to speculation myself.
  24. #24
    Jun 2005
    If this new design was that much better I think we'd have heard of it before .
  25. #25
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    I say we support Cathar all the way. A lot of the design of the new block was inspired by the storm and Cathar. Of course this is just all speculation. I do feel that Swiftech is trying to make a statement that "we can make a block that's better or matches what Cathar can make...and mass produce it at an affordable price."
    Palit 4870x2
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
