Results 1 to 10 of 10
Thread: The fruits of our labour. :toast:
    Aug 2004
    Sydney, Oz.
    Its all built now and running sweet. :D
    Well guys I asked you lot for help with my watercooling rig and which components to go for for my system of X2 4800 and 2x7800 GTX.
    A special thanks to Kris at this point.
    In the end went with:
    120.3 PA (3x120mm Silenx)
    Swiftech Storm
    2 x 1/2" Maze4 Acetal Top
    AquaXtreme 50Z-DC12 Mag Drive Inline 12V Pump
    T-Splitter
    7/16" Tygon tubing
    and the results?
    Well lets just say I never expected the X2 to clock that greatly, nor the GTXs in SLI to do so well with all the heat that they and X2 puts out. I was in for a shock!
    The fans are running on silent settings here via rheobus, showing what the PA can really do.
    Here you go(and also worth pointing out that CPU1 is the weak link here, CPU0 will do over 3GHz at same volts):
    These are the settings for the GTX that was able to go to and pass "Test Changes" within the control panel. they work fine on games etc. is it possible to overclock beyond these
    speeds even though control panel wont test them as working? Obviously I want that 527 on core for the magic 27MHz steps but according to control panel its not achievable but is it?
    Also are there any pencil mods for the 7800GTX? I dont have any decent soldering equipment for a voltmod though I have the skills having been a debug tech for a while a few years ago.
    Banned
    Jun 2003
    Broomfield, CO
    Looking good! 3Ghz on a DC setup with water is an excellent result! You can definately go higher with those GTX cards with some more volts. The 256MB cards can go as high as about 1.75-1.8v with watercooling and this will take you into the 600+ range on the ROP/Shader domain with a Geo in the 650-675 range. What are you idle/full load temps for those SLI'ed cards?
    -FCG
    aka Kris
    Aug 2004
    Sydney, Oz.
    Quote Originally Posted by freecableguy
    -FCG
    aka Kris
    thanks Kris, you were definitely one of the stronger influences on me choosing that setup.
    the GTXs idel @ 33C and load at 39C!
    hmm voltmods, well i will need to source a better soldering iron for starters, what wattage do you suggest as a minimum, this 30W joke I have is useless. :p
    Skulltrail Junkie
    Jan 2005
    Milwaukee, WI
    you could probably drop the temps down a bit by getting some more powerful 120mm fans, but very nice results nonetheless
    • Lian Li PC-75B • Corsair Professional Series 850w •
    • 2x Intel Xeon E5420 @ 3.0GHz (400x7.5) • Intel D5400XS Skulltrail •
    • 8GB (4x2GB) A-Data DDR2-800 FB-DIMM ECC (1:1 @ 400MHz) •
    • MSI Radeon HD4870 1GB • Creative X-Fi Titanium HD •
    • 2x WD VelociRaptor 150GB (RAID 0) + 2x WD Caviar Black 500GB •
    • 2x EK Supreme HF CPU • EK S-MAX NB • EK VGA Supreme GPU • Blastflow Tidal SB •
    • Thermochill PA120.3 • Swiftech MCRes-Micro • Laing D5 w/ Bitspower Top •
    Heatware • http://www.heatware.com/eval.php?id=34593
    Nov 2004
    Redmond, WA
    pombertot, about what voltage are you running the Silenx fans on? With anything less than 12v, I would imagine you'd be less than ~49 cfm for each fan (assuming Silenx fans are rated correctly.)
    I only ask because it relates to a separate thread I posted.
    Awesome results on a pretty much silent setup.
    System /CPU- 3800x2 /Mobo- DFI LPUT SLI-D /Memory- Ballistix z503x 2gb /Video- XFX 7800gtx /PSU- OCZ 600w /Case Lian Li PC-75b- Rad Top Mount
    Cooling /Rad- BIP3 /Fans- 3 YateLoon 120mm /Pump-D5 /CPU- Storm /GPU- Maze 4 w/ OCZ Copper HS
    Aug 2004
    Sydney, Oz.
    Quote Originally Posted by PorkchopExpress
    roughly about 5V through each one.
    Xtreme Legend
    Nov 2002
    Melbourne, Australia
    Quote Originally Posted by pumbertot
    LOL - so about 20cfm with each fan then...if that.
    Good job. Nice setup and results.
    Aug 2004
    Sydney, Oz.
    Quote Originally Posted by Cathar
    yep just shows how good the design of the PAs is and also that guy that designed the Storm knows his ass from his elbow.
    has to be siklent, computer in bedroom, downloading 24/7 and wifey dont like no noise.
    Feb 2004
    yay, just order myself the pa120.3 today. hope 50 dollars extra over the he120.3 is worth the money. I think I'll have exactly the same setup as you do but instead of Maze4 I have this old swiftech vga block
    Mobo: MSI P35 platinum
    CPU:e8400
    Mem: 4x512mb Patriot fatbody
    Vid Card: 8800gts 512mb
    Cooling: Thermalright 120 ultra
    HD's: 80x2 raid and 320gb
    Case: cooler master cm690
    Nov 2003
    Midwest
    How is that masterkleer tubing? flexible like tygon or more like clearflex? Just wondering because I've never bought anything but tygon.
    ALIENS are bringing my next kentsfield based rig in a UFO case!
