Page 1 of 9 1234 ... LastLast
Results 1 to 25 of 204
Thread: Post your Best 1m ss on any opty@3.0 or less
    Apr 2005
    I'd like to see some ss of any opty running any memory timings at 3000 or less. I say or less because a super tweaker might do just as good even if his cpu can't hit 3000.
    Please post a cpu-z ss of cpu and memory and a tweaker ss. I don't really care if it takes 1.32v or 1.8v, as this is just to see how much difference there is in the memory and tweaking skills.
    Here's a novice for the first post.
    ocz4000vx
    This one is with ocz4800plats
    Turkey Man
    Mar 2005
    Jakarta (ex-Australia)
    heres one i did the other day while mucking around with someone else's 144.
    RAM timings werent tweaked at all, and CPU wasnt at its max clock.
    Win XP SP2 tweaked, and OCZ 4000vx
    Oct 2004
    Bedford, England
    I tried for 11 x 272 1:1, but this opteron will not work at all with the 1:1 setting
    2 x 256Mb OCZ PC3500 Platinum LE + Opteron 148 @ 9 x 333 5:6 unoptimised.
    I'll post some 2x 512 BH-5 results shortly
    Q6600 G0 L720B058 @ 3.8GHz | Asus Maximus Formula (Rampage 0403 Modded) | 4x2Gb GSkill PC8000 PQ @ 1015MHz | XFX 9800GX2 XXX @ 680/2080 | 2 x WD Raptors RAID0 | 1 x WD5000KS | Samsung S203B DVDR/W | Samsung SM245B + Panasonic TX37LZD80
    D-Tek Fuzion | PA120.3 + Shroud + Nexus Fans | MCW30 | Laing DDC w/ Petra's DDCT-01s Top Combo | Tygon 1/2" Tubing | T-Line
    Aug 2005
    Germany; Niedersachsen; Schaumburg; Bad Eilsen
    AMD Opteron 144 @ 2955MHz @ 1,7V @ Arctic Cooling Freezer 64
    Infineon 6A @ 2-2-2-5-8-8 @ 264MHz @ 3,4V
    MSI Neo2 and OCZ Booster
    I know my english isnīt the best ...
    my pc
    oVerkill.OC - Technic3D
    I am Xtreme
    Feb 2003
    Netherlands
    Here's mine @3GHz:
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Apr 2005
    148 the hard way
    My 4000vx wouldn't do 273x11 1:1 ,so I went the hard way.
    CABYE's aren't the that bad.
    Apr 2005
    [QUOTE=Zeus]Here's mine @3GHz:
    Nothing like good ram.
    Feb 2005
    USA
    looks like all SPI 1M runs are in the 27s at around 3.0Ghz, mine also did the same.
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    Apr 2005
    Quote Originally Posted by ben805
    It will take some really good ram and tweaking to break into the 26's.
    Aug 2005
    Quote Originally Posted by dogsx2
    I think there must be more than some tweaking!
    Look at my run. I had my ram at 2-2-2-5 @ 264MHz and 2,95ghz and i am at low 28 sec .... i think under 3ghz you cant rech 26 sec.
    I posted the wrong image ...
    Here is the right one
    my pc
    Apr 2005
    Quote Originally Posted by 0verl0ad
    You have to be alittle closer to 3.0 and I don't think your ram's tweaked all the way. Post a tweaker ss.
    Your ram is at 246 not 264, big difference.
    Jul 2004
    France
    with my old died 0517 EPAW watercooled
    with mem at 275 i can past under 27.6
    i'll compare with my future opty 146 this week but i think 26 is easy possible
    French Overclockers roxxxxxx
    OCM Team addict
    Aug 2005
    Right. i had 264mhz on the screenshot i posted before. For a tweaker ss iÂīll have to insert the booster and the other memory .... maybe tomorrow.
    my pc
    Apr 2005
    Quote Originally Posted by overcrash86
    Good, think you can do mid 26s?
    Jul 2004
    France
    at 3G yes its possible, with best optimization
    i need ~3050-3060 for 26.9 with the venice :
    http://wowgame.free.fr/3000+%20939/L...vok26.843s.jpg
    OCM Team addict
    Feb 2005
    USA
    I'd already tried 300 x 10 and put my Redline XP4000 on divider so ram was running at 250 @2-2-2-5 1T with tight timing, I was still getting 27s, the only way to break 27s is 11 x273 1:1 @2-2-2-5 1T. My Redline can do 270 spi32m with 3700SD but not sure how the opty's memory controller going to cope with it, whenever I have a chance I'll try it tonight when i get home from work....27s is definitely breakable at or under 3.0Ghz
    Apr 2005
    I agree, but you have to be in the 270's@2-2-2 or the hard way 375x8 with a 5/06 and very good TCCD 2.5-3-3.
  18. #18
    100% Load 24/7
    Mar 2005
    Seattle
    Here is 11x273. OCZ plats tcc5. This is about as high as my memory will go with 2.5-3-3 timings. Cooling with big typhoon. I also have this posted in the opty thread. Not prime stable, but good enough for my first ever 3.0ghz
    Main Rig
    i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
  19. #19
    Apr 2005
    Quote Originally Posted by 4X4N
    OCZ ??? plats, which ones? Will they run 300@2.5-4-3 ? If so, drop down to 10x300 1:1.
  20. #20
    100% Load 24/7
    Mar 2005
    Seattle
    I can do 295 2.5-4-3, but it's slower than 270 2.5-3-3
    Main Rig
  21. #21
    Feb 2005
    USA
    I've been trying 273 x11 with my Redline XP4000 running at 273 1:1 @2-2-2-5 and 2-2-2-6 1T with 3.70v, very tight timing(to the point where the 1m almost failed), but still can't breach 27s, the mod1.4 version didn't cut it either so 26s ain't gonna happen...dammit! I would love to see someone else with better quality BH/UTT to give it a try, my Redline is maxed out at 273, I'd even cranked them up to 3.90v but didn't do jack! I give up.....27s is all I got with either Ballistix or Redline <3.0Ghz
  22. #22
    Love and Peace!
    Dec 2004
    hiding somewhere!
    almost made 27's with my opteron 144, i think if i had 10mhz left in it, it would have been done
    also, voltage was really 1.6, not 1.4, and the ram was 2x512mb ballistix.. one stick of which is having "issues". it was more of a max cpu speed test than a min sPI 1m bench session
    i need to play with the 146 and see if i can get much more out of it.
    Got a fan over those memory sticks? No? Well get to it before you kill them
  23. #23
    Apr 2005
    Good try, it sounds easy, but.... I think the hard way 375x8 with a 5/06 and very good TCCD 2.5-3-3 will do it. Sure would like to see someone with good memory and a good mb do it.
    May one of the big dogs will show us how it's done.
  24. #24
    I am Xtreme
    Feb 2003
    Netherlands
    Sorry but i beg to differ.
    Have a look at my screen, this with 300x10 1:1 2,5-3-3-7 perhaps i can tighten the subtimings a very little but i don't think sub 27 seconds is possible with an opteron @ 3GHz.
    I might be wrong though.
    Soon as my new RAM arrives i'll give it another shot.
    Looking at the results, TCCD 1:1 with good timings seem to be the way to go for SuperPi.
    edit: just found out that your example will bring thr RAM up to 312, so that might bring 26.xxx seconds home.
  25. #25
    Turkey Man
    Mar 2005
    http://wowgame.free.fr/3000+%20939/L...v3006.4Mhz.jpg
    erm, opterons only man
