Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: Has anyone killed an A64 from voltage?
    I am Xtreme
    Aug 2003
    A certain someone will not let up on thinking voltage kills them and insists I will fry all my chips. I've run all my A64s (a claw, venice, 2 diegos, and a diego opteron) to to 2v for extended periods of time and they all run just as good as always. So has anyone killed a chip from voltage?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Aug 2004
    NYC
    ive seen my current chip degrade a little after running 1.9 volts for a few months...
    "Monolith" - [ Xeon W3540 (4.22) - Rampage 2 Extreme - 12 GB Ripjaws 1600 - GTX 570 - 120 GB OCZ Vertex - Antec TruePower 750W - Corsair 700D - Apogee XT CPU Block - XSPC 360 Rad ]
    Old Box - [ E4600 2.4 @ 3.7ghz (11x335) - P5W-DH - 4gb Gskill @ 893mhz - Radeon 3850 ]
    Sep 2004
    DFI and Oskar Wu have.
    Sorry, couldn't resist
    I think its pretty well common opinion though that running that sort of voltage is definately going to shorten the lifespan, this is xtremesystems.org though, you break it and you buy something newer and hopefully better Getting a new goodie is half the fun of it.
    | DFI NF4 SLI-D | 3700+ | SLI 7800GT | 2x512 PC4400C25 Corsair XMS | 1x120gb WD SE | 1x200gb WD SE | 2x200gb Maxtor DMP10 16mb cache RAID0 | Antec True Control 2.0 550w |
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    i killed about 15..
    and an additional 3 in the process of trying to unlock them...
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
    Xtreme Mentor
    May 2005
    San Diego, California
    Quote Originally Posted by nn_step
    i killed about 15..
    Wow, so what'd you do?
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    just go to the A64 unlocking thread for the 3
    The others were simply too high for too long...
    Hence my current chip and it's overclock is at 1.4v
    I could go farther but I love this chip...
    Xtreme X.I.P.
    Dec 2003
    i killed about 15..
    You must really have some "special skills" to be able to pull off something like that
    I've had maybe 15 different AMD CPUs (4 A64) and have never killed even one from overvoltage All were seriously "vcore-tortured", on a daily basis.
    I only killed one A64 (Winchester) but that was because I was stupid It died at +95C @ 1.7v
    Xtreme Mentor
    May 2005
    What voltage were these chips run at? What cooling was used, what were the max load temps, and how long before they died? If you don't mind sharing of course. If you have lost that many chips, you should share your experience so we can avoid the situation.
    Intel Rig
    Nov 2002
    NO... then again I haven't had the same one for more than 2 months.
    I did kill one with homemade phase kits, too much mounting hardware created a short I guess. Speaker wire from the mobo melted and other notices. The mobo and the newcastle died together. They smile down on me and my SD, as they know there will be no letting up.
    May 2005
    Montana, USA
    I killed a 3700 Clawhammer about a year ago when I was insisting that it bench 3D@ 3ghz on water. As I recall, I was pumping 2 volts even thru it at the time.
    Dec 2003
    Canada, BC
    Ya, when my old dfi nf-3 screwed up and gave 2.3v to the cpu, It posted I went into the bios saw that huge number and hit the switch on the back of the psu. But the cpu never posted again.
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    Quote Originally Posted by Absolute_0
    1.7v, 1.8v,1.9v and they were all phase change cooled to -60C
    They died over the course of 1-2 Years
    I now strongly suggest that you keep your Vcore at 1.55v or less when ever possible..
    Oh and these chips were pushed to their max 24/7 to boost my folding score..
    They just seemed to wear the out..
    other chips set at 1.6v and below seem to still be working nicely with no probs..
    Phenom™
    Sep 2002
    As I've always stated, high vcores are more damaging to your cpu's that high temps. The A64 may be able to withstand 2.0+Vcore for short periods of time, but you're definately cutting the life expectancy of the cpu way down. BTW, I can thank a faulty DFI for somehow killing one of the most awesome cpu's I've owned to date - an 0435 CLAW FX55
    Jan 2005
    just out of curiousity, when you guys report ur vcores, is it what you set in bios or what displays in windows?
    for example, i have my vcore on a dfi at 1.45+110%
    so when stating my vcore, would you state its:
    1.45v
    1.55v (what windows states it as)
    or 1.45x1.1 = 1.595v?
    and finally, assumings its 1.595 and running 24/7 at around 32-33c (full load of both cores, ambient when idle)...its not too high is it?
    Dec 2004
    I fried a 3400 clawhammer. pumped 1.8 into it for months,one day wont post.
    Apr 2003
    USA Tampa FLA
    yup sure have it was a DTR3400 was trying to push 1.8v thru it with a v-dimm of 3.4v using a mach1 pasechange unit.... to this day the cpu sits on my desk in an ashtray to remind me that voltage kills......
    peace perc,
    Dec 2004
    mine was a mobile 62w on water. couldnt take the beating lol
  18. #18
    -100c Club Member
    Jul 2005
    England
    figers cross never
    the thing is
    if you really want the mhz you just have to do it period
    how could you just sit there and say are well thats all the oc i can get @ 1.55v and call your self an over clocker
    and as for life expectance of the chip who here intends to have the same chip next year
    1. The first rule of Bench Club is, you do not talk about Bench Club
    2. The second rule of Bench Club is, you do not talk about Bench Club
    3. If someone says stop, goes limp, taps out, the the benching is over
    4. No bummers in the batcave, apart from unkie dave
    5. One Bench at a time
    6. No air, no water
    7. Benching will go on as long as they have to
    8. If this is your first night at Bench Club, you have to Bench
  19. #19
    Jan 2003
    Montreal
    I run Phase Change and I never exceed 1.6v. Folks we are talking a 90nm process here, electron migration is a reality and will be even more so once we go to 65nm process.
    DFI Ultra-d
    X2 3800+ @ 2.5ghz Thermaltake Heatpipe
    Leadtek 6800gs 515/1300
    1gb OCZ Rev 2 Platinum @ 500 (2.5/3/37/1t)
    2 x 250gb DiamondMax 10 (RAID 0)
  20. #20
    Xtreme Mentor
    Aug 2005
    Boston, MA, USA
    Quote Originally Posted by chinkgai
    Excellent question. Run-time display is usually 0.07 volts lower than what I set in the BIOS on my SLI-DR.
  21. #21
    May 2005
    Slovenia
    I burned my old wini 3200+ CBBFD when i pumped 1.95V in to him
    i7 980x @ 4500Mhz 1.45V
    Rampage III Extreme
    6GB A-Data 1866Mhz+
    2x XFX 6970
    Crucial SSD 128GB M225
    X-Fi Titanium Fatal1ty
    Corsair HX1000W
    GSX-R 750 Rider
  22. #22
    Apr 2005
    Ok, you guys need to stop basing voltages off Windows readings. You need to compare your BIOS settings with a multimeter and then tell us hwo much your voltage really is set at... USually BIOS settings are quite correct for me (DFI LP NF4 Ultra-D)
    Intel Core i7 930 @ 4ghz | Gigabyte X58A-UD5 | 6GB G.Skill Ripjaws DDR3 | Radeon 4850 | Crucial m4 128GB SSD
    Intel Core i5-2400 | Asus P8H67-M EVO (Waiting to change to Z68) | 8GB G.Skill Sniper DDR3 | 8x2TB Samsung F4-HD204 | OpenIndiana | ZFS raidz2
  23. #23
    May 2005
    With my destiny :)
    Not yet!
    But I burned a Barton two years ago!
    I think A64s are stronger!
  24. #24
    Xtreme 3DTeam Member
    Jul 2004
    "The Land of Chocolate", USA
    Quote Originally Posted by bachus_anonym
    Quote of the day?
    6800U 31.7K '01*15.8K '03*7.2K '05
    ...building a dual 254 rig on the MSI K8N Master2-FAR SLI
  25. #25
    Phenom™
    Sep 2002
    Quote Originally Posted by bazx
    figers cross never
    the thing is
    So I guess I can't call myself an overclocker because I don't want to take the risk and kill a cpu which costs $600+ or one which is a pre-release sample and won't even be available for a few months.......
