default
691/1628
R520 9,444 Point VS GTX 8,042 Point
More
default
691/1628
More
that just makes me want one even more
Lanparty Ultra-D DEAD|REVIVED
X2 3800+ LDBHE 0606 EPMW 2950 @ 1.55v DEAD|STILL DEAD
Powercolor X1900XT 725/873
dell 2005fpw 20.1''
Originally Posted by afireinside
Originally Posted by Mr. Popo
very nice oc, have to see what 2 cards in crossfire score
nice![]()
Now has two X1800XT, but does not have run crossfireOriginally Posted by forey
Does your driver version support voltage adjustment for the card?
Any hope for some WC results?
edit: Could you also post pic of the core(s)? THanks.
How was this OC'd? CCC or ATi internal proggy?
stock cooling, 9444marks![]()
CPU: XEON W3540 & Gulftown Q3FE
MB: Asus Rampage III Extreme
RAM: Corsair GT2000C7 2G X 3 ADATA XPG+ 2200+ 2G X 3
SSD: Adata S596 120G
Display Card: Asus EAH 5870
WaterCooling:
Laing D5 Pump + Koolance D5 Top
Radiator: KP 120.3
CPU Block: HeatKiller 3.0 + EK full MB Block
PSU: Antec TPQ 1200W OC
Case: SilverStone TJ-07BW
That was actually stock clocks on the 3.06GHz FX!! Stock cooling also acheived 10195![]()
Wow those cards look realy nice:O.. Can somebody plz give me some prices .. Like what every model of the X1xxx serie will cost?
Regards
Bench System:
CPU:Intel core 2 duo E7400 2.8Ghz @ 3.4Ghz
CPU:Intel core 2 duo E6400 Conroe Batch L629A7XX
CPU:Intel core 2 quad Q9400 2.66Ghz @ 3.0Ghz
MOBO:Asus P5Q Pro
RAM:Corssair 2x1 GB PC6400 DDR2-800
RAM:Corssair 2x2 GB PC6400 DDR2-800
RAM:Avexir DDR2-1066 w/ Handpicked Elpida's
VGA:Asus GTX 560 1GB
HD: Westerdigital 160GB SATA
HD: Westerdigital 500GB SATA
PSU:Coolermaster Silent Pro 700W
GTX gets 10300 at 625/1500 and 3.06GHz FX....or there abouts without LOD tweaking.
XT gets 9444 with the same clocks....so 850 points difference. But one is HEAVILY OC'd while the other is at stock clocks
If nothing else, the XT is a great benchmarking card!![]()
I'm impressed given the stock cooler and no indication of whether volts were overstock or not. Should see some impressive increases with some homebrew air cooling.![]()
DFI UT X58-T3eH8 (being replaced with Giga UD5)
Core i7 920 D0 mostly stable @ 4Ghz
TRUE 120
6GB OCZ Platinum 7-7-7 (still in testing
XFX 4890 1GB @ 1050/1190
Corsair HX850W
CM Cosmos S
Still testing...
True that....I hope we can see them used together sometime soon, it'd be an ORB killer (well, for single card of course...I REALLY doubt the X1800XT's ability to get 18k on 05 in single card mode).
trakslacker....with the software vmodding it really looks like this will be an amazing card for moderate 'special' cooling like homebrew air and wawa![]()
wow... nice numbers... has anyone slapped a water block on it yet? Also - it looks like it's got a four hole patern which looks like the nvidia 6800/7800 four hole patern for the gpu (only) block.. is it the same? Or is it a new or old ATi patern?
Gigabyte x58 UD5 / core i7 920 @ 3.8 / 6G ddr3 / 100G Patriot Inferno + 500G WD / gtx470 SLI watercooled / x-fi / 1KW enermax / 5760x1080 surround
Gigabyte z68x-ud3-b3 / core i5 2400 @ 3.6 / 8G ddr3 / 120G Intel 510 + 120G Adata S599 + 2x 1T WD blue / Zotac gt430 / x-fi / 500w ocz / 1920x1200
DFI pro875B / pressy 2.8 / 2g corsair xms pro / 6800gt agp / 150g raptor x / 500w ultra x-connect / lots of UV lighting / smiles
MSI K7N2 Delta-L / Athlon xp2600+ / 1G ocz platinum / chaintech TNT2 / 2x Diamond Monster 3D II SLI / Audigy / more smiles
its been confirmed that any WBs for the 7800's will fit the XT as well. They use the same hole config.Originally Posted by revenant
TRUE 120
Corsair HX850W
CM Cosmos S
Still testing...
Yeah, thank god they do too....no need to leak test or get new mountings or anything for those of us that already have it
I wonder if the nV Silencers for the 6800/7800s fit this (are they even compatible between each other?) and how the stock cooler competes with them.
Looks good sx, thanks for the results you lucky guy![]()
Fine then you can also disable 4 of the GTX's pipes, what do you think might happen thenOriginally Posted by Troman
I'd say that the default ATI cooler is better than nvsilencer..actually the ATI cooler is not bad at all:I wonder if the nV Silencers for the 6800/7800s fit this (are they even compatible between each other?) and how the stock cooler competes with them.
I'm getting around 740/1680 clocks (artifact free for 3DMark05) with the default cooler (GPU +0.15V above default, fan running at full speed).
Already posted on the other thread but just in case someone missed em =)
my results so far w/ the Zalman CNPS-7000CU on GPU:
3DMark05 => 10707 (3GHz, 759/1738)
Wow....good pics of the cooler Macci....it's pretty beastly for a stock cooler (my GTX's cooler was a disappointment frankly). Looks like you only gained 19MHz going to the chopped 7000CU....must be good!
Like to see you run these in CF macci, hope your gettin/have another card to play around with![]()
I don't think there are any fully functional X1800CFs out available, unfortunately.![]()
Hmm, what about come November?
Hey macci, what do you think of current X850's in CF? Are they worth the time?
I'd bet they're available in Nov
Look at his sig--that's how worthwhile the X850s in CF were to him.![]()
I honestly want people to get only 49999 for fear of the 01 orb getting taken down at 50k
Never the less 01 numbers from this combo would be nice sxs!
