Dothan, X800 XT, Audigy 2 Problem
I've had my rig running my Asus P4C800-E, Dothan 725, Audigy 2 and Radeon 9800 Pro for months. I recently bought a ATI X800 XT PE and have been experiencing numerous problems;
First, I installed the graphics card to find that on reboot it would freeze during the XP boot screen. After many attempts on re-installing the drivers I sent back the graphics card. During the period between getting the replacement card, I bought a new Tagan 520w PSU as I thought there might not be enough power being supplied.
After all my new parts came, I installed these and I still get the same problem (the card now has its own rail so it isnt a power problem). I've reinstalled with only XP SP1, tried different drivers and found that the pc will not boot with the Audigy 2 and the x800 at the same time, it will boot but once the drivers are installed and you restart, it then freezes. The rig does boot and works fine with the onboard sound but I'm a bit gutted really as it is rubbish, and I'm really wondering if anyone has tried an Audigy 2 with the X800 XT? I'm starting to think it may be just because of my dothan, I'm really not sure ... I need help because im pulling my hair out here.
Cheers
- You may not post replies
- You may not edit your posts
Forum Rules
