Here are CPU & RAM stretcher
Although I have opened a thread for supporting O/c Bible I don't want to be many pages long...
There I add/remove/edit my posts cos maintaining up to date but your feedback is appreciated.
In this thread I will describe step by step how I find MSFs using O/c Bible and my burn-in guide and more stuff.
Let's start!
System specifications:
CPU: A64 3200+ Venice core.
Default Vcore: 1.350 Volts (other pages say 1.400 anyway).
Default multiplier: 10X.
RAM: 1X512 MB Kingston HyperX PC4300.
PSU: Enermax 465 Watts.
Cooling: Hand made watercooling.
Mainboard: MSI K8N Neo2 nForce3 250 chipset.
O/S: Windows XP with SP1.
Burn-in program CPU stretcher (included in O/c Bible's package).
Step 1 --> Choosing multiplier
Usually Venices achieve around 2.7GHz or higher (OK it depends on stepping/cooling/Vcore etc)...
2700 MHz = 9 * 300 MHz --> my mainboard could not POST with FSB=300 MHz (I tried all HT settings).
So I choosed the default multiplier.
Step 2 --> Choosing BIOS settings
Hyper Transport speed should be around 1 GHz.
270 MHz * 4X --> 1080 MHz > 1 GHz --> I set HT=3X in BIOS.
The closest voltage in BIOS which gives default Vcore for my CPU is Vcore=1.350.
I measure Vcore with a multimeter (see O/c Bible's tutorials how if you don't know) and Vcore was 1.361 Volts.
As you can understand this mainboard overvoltages (a bit).
In addition I set relaxed timings in BIOS --> 3-4-4-8/2T and divider (RAM / FSB = 133 / 200).
I repeat here I must be 100% that my RAM is 100% stable at any FSB.
Some notes
1) RAM is stable around 310 FSB using 3-4-4-8/2T, Vdimm=2.82 (I tested on a previous Gigabyte K8NS Pro 754 socket).
2) RAM is one years old (at this moment)so it is not recommended to apply RAM burn in process.
3) My mainboard (visit MSI forum for more info) has a bug:
SATA1 + SATA2 are not locked.
Thus I could not enter in Windows using FSB > 239 MHz.
Moving my hard disk to SATA3 + bannedSATA1+SATA2 in BIOS all are OK!
4) We must measure all voltages at full load and see if they are stable.
5) I put some extra small heatsinks on CPU MOSFETs cos they are hot!
6) I measure voltages at coil node.
7) We apply CPU burn in process when our CPU is new not after 2 months!
8) When achieve a MSF we don't change settings --> All change and not CPU stable settings makes our CPU a bad stepping! --> consider the proverb "All work and not play makes Jack a dull boy"..![]()
9) This process is similar any CPU you may have.
See here for Intel burn-in (thread at XtremeSystems also)...
[in water , soon with subzero ]
